2802i restarting due wcpd and coruppted wifi dev
Vice Lacmanovic
I have one 2802i with corrupted system on both partitions. wifi dev is missing so watchdog is restarting system every 5 minutes or so. I do not have enough time to upload and unpack correct image using archive download-sw command because of the system restart caused by wcpd. That is the reason part1 is corrupted, system was restarted while tar archive was unpacked and installed. Is there any way to disable watchdog (or radio 0 and radio 1) so that system is not constantly restarting. Image is lightwheight 8.5.140. RMA is not easy option because of off-shore system installation and unreliable Internet access.
Vice
5 Replies 5
Vice Lacmanovic
or is it possible to reset watchdog counter?
Leo Laohoo
Let the AP join TWO (2) controllers with a totally different firmware and then get the AP to go back to the original controller.
new controllers with fw 8.10.130 and 8.5.161 are not helping
ap is still restarting after 8 minutes
[*09/21/2019 04:29:27.8615] Failed to decode discovery response(status = 4).
[*09/21/2019 04:29:27.8615] CAPWAP SM handler: Failed to process message type 2 state 2.
[*09/21/2019 04:29:27.8615] Failed to handle capwap control message from controller - status 4
[*09/21/2019 04:29:27.8616] Failed to process unencrypted capwap packet 0x27d3000 from 10.31.27.4
[*09/21/2019 04:29:27.8616] Failed to send message to CAPWAP state machine, msgId 0
[*09/21/2019 04:29:27.8616] Failed to send capwap message 0 to the state machine. Packet already freed.
[*09/21/2019 04:29:27.8616] IPv4 wtpProcessPacketFromSocket returned 4
[*09/21/2019 04:29:27.8616] Discovery Response from 10.31.27.3
[*09/21/2019 04:29:27.8617] Discovery response from MWAR ''running version 0.0.0.0 is rejected.
[*09/21/2019 04:29:27.8617] Failed to decode discovery response(status = 4).
[*09/21/2019 04:29:27.8617] CAPWAP SM handler: Failed to process message type 2 state 2.
[*09/21/2019 04:29:27.8617] Failed to handle capwap control message from controller - status 4
[*09/21/2019 04:29:27.8617] Failed to process unencrypted capwap packet 0x27d5000 from 10.31.27.3
[*09/21/2019 04:29:27.8617] Failed to send message to CAPWAP state machine, msgId 0
[*09/21/2019 04:29:27.8617] Failed to send capwap message 0 to the state machine. Packet already freed.
[*09/21/2019 04:29:27.8618] IPv4 wtpProcessPacketFromSocket returned 4
[*09/21/2019 04:29:30.7031] wifi dev open failed: No such device
Init of radio 0 failed!!!!!
[*09/21/2019 04:29:30.7033] wifi dev open failed: No such file or directory
Init of radio 1 failed!!!!!
Open a TAC case. If they say that the AP needs to be replaced, then you know the only option is to figure out how to replace it.
-Scott
