3355 Mobility Service Engine failed to start
After I initial MSE with the wizard. MSE take so long to start the service (more than 1 hour) with "Starting MSE Platform, waiting to check the status"
Then I decide to reboot the appliance, after that MSE shows the message "
Traceback (most recent call last) File "/usr/sbin/yum-updatesd", line 40, in ?
import gamin
ImportError: No module named gamin
Sent from Cisco Technical Support Android App
7 Replies 7
Amjad Abdullah
You possibly need someone from TAC to tell you what this things is!
Rating useful replies is more useful than saying "Thank you"
It still failed to start. take so long lol. TAC may help me about this.
Try to run "setup.sh" then get the same result. Should I need to RMA this appliance ?
After unpack the box, plug power, login and run "setup.sh" after that get the result as report.
Pongsatorn M.
Craig Le-Butt
HI
I kept getting this, wouldn't conenct as wasn't the same version as the WCS.
Soon as I got to the same version, fifn't ahve this problem any more.
cheers
Hi Craig,
My NCS firmware version is 1.0.2.29 and WLC firmware version is 7.0.235 also with MSE3355 firmware version is 7.0.230
NCS and WLC is working great but when I setup an MSE, not working
Any idea ?
Pongsatorn M.
Craig Le-Butt
Just looked back at my notes, this is what I got as well
Traceback (most recent call last):
file "usr/sbin/yum-updatesd", line 40, in?
import gamin
Importerror: No Module named gamin.
Do you find that it keeps loosing the settings , type ifconfig, the ip has gone?
Faulty unit most likley, we're on a 3rd box at the moment.
cheers
Are you not able to access the cli?  If so, try to issue the following:
/etc/init.d/network status <--- check the status
/etc/init.d/network reload <--- if a service isn't running
/opt/mse/setup/setup.sh <--- to review or make changes to what was entered on the setup script.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
