350 IOS HTTP authentication using RADIUS not TACACS
candv
Level 2
Level 2
I am trying to get "ip http authentication aaa "to a 350/1200 ios wireless access point to work using RADIUS (using ACS 3.2 and Cisco IOS/PIX RADIUS Attributes).
I can get the 350 vxworks to work by adding
"aironet:admin-capability=write+snmp+ident+firmware+admin"
to the ACS server.
I can get CLI authentication to the IOS 350 by adding
"shell:priv-lvl=15"
but am having no luck with radius authenticating.
I have been able to use tacacs+ to do ip http authentication but I want to use radius. Does anyone know where I am going wrong. When I look on the ACS server it doesn't fail (it passes authentication), it just seems like there is something weird happenning with enable level 15. I have removed the local authentication, I think I am not passing the correct attributes even though debugging does pass username etc correctly
thanks
pradeepde
Level 11
Level 11
The following are the steps I followed and its working fine for me,
On the AP
1. Setup -> security -> Authentication Server - Make sure that User Authentication is checked.
2. Setup -> security -> User Information -- Add a user
3. Setup -> security -> User Manager -- Enable user manager
On the ACS
1. Setup a group
2. Look for "Cisco IOS/PIX RADIUS Attributes" which will not show unless you have a AAA client
authenticate using the 'radius (cisco ios/pix)'
3. Check "[009\001] cisco-av-pair"
4. Add "aironet:admin-capability=write+snmp+ident+firmware+admin"
5. Add a user in that group
