350 Work Group Protocol Limitation ?
ptuttle
Does anyone know if the 350 Work Group Bridge has any limitation on protocols it supports and can pass. Trying to get Novell clients to pass through a WGB to an access point that sites on the Network whrere ther servers reside.
-pat
ED CARMODY
Level 5
Level 5
If you set the client to workstation only mode and let it boot, can you ping the server?
Thanks for the reply. I ended up getting it to work by manually entering the MAC addresses into the WGB.
-pat
