10-31-2013 12:43 AM - edited 07-04-2021 01:11 AM
I have 5508 wireless lan controller and 3502 AP. I did all configuration on WLC using the configuration guide. But AP don't join the WLC. AP can assign an IP address and i can ping this IP from WLC. When i connect the AP from console i see the logs below;
*Mar 1 15:36:57.128: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLL ER
Not in Bound state.
*Mar 1 15:37:42.637: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar 1 15:37:46.730: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar 1 15:37:46.793: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP addres s 10.17.25.13, mask 255.255.255.0, hostname AP4c00.82e9.a218
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Mar 1 15:37:53.638: %CAPWAP-3-ERRORLOG: Did not get log server settings from DH CP.
I research similar problems in forums and i implement all they said but i can't solve the problem. there are also DHCP options below;
ddns-update-style interim;
allow bootp;
option space Cisco_LWAPP_AP;
option Cisco_LWAPP_AP.server-address code 43 = string;
subnet 10.17.25.0 netmask 255.255.255.0 {
authoritative;
option routers 10.17.25.1;
option subnet-mask 255.255.255.0;
range dynamic-bootp 10.17.25.10 10.17.25.20;
default-lease-time 300;
class "Cisco-AP-c3500" {
match if option vendor-class-identifier = "Cisco AP c3500";
option vendor-class-identifier "Cisco AP c3500";
vendor-option-space Cisco_LWAPP_AP;
option Cisco_LWAPP_AP.server-address f1:04:0a:11:07:0a; (Management IP : 10.17.7.10 )
What could be the cause of problem ??
10-31-2013 03:55 AM
Try changing your option 43 address to look like this:
f104.0a11.070a
Steve
