3502i versions
Jeremy Patrick
Level 2
Level 2
Quick question: On the 3502i APs, what is the primary difference between versions? (V01 vs V02) I have a V01 model but at work we have V02. Im guessing not much of a difference but wanted to ask. Thanks!
Saurav Lodh
Level 11
Level 11
There is not much difference b/w VID01 and VID 02, just VID02 are free of booting issues which VID01 had
http://www.cisco.com/c/en/us/support/docs/field-notices/635/fn63537.html
Saurav Lodh
Level 11
Level 11
Jeremy Patrick
Level 2
Level 2
excellent, thanks for the info.
I already have these APs running one or two versions short of the current cisco listing.  So according to the article you mentioned the issues were covered in those newer versions.
Haven't had any issues so far, but all of the cisco APs I've had are so solid the'll go months before an occasional power cycle forces a restart.
