3600 Series Access Point Problem
rgoble
Have a AIR-CT5508-K9 Controller running 7.0.116.0 software.
Just purchased 3 AIR-CAP3602I-A-K9 access points.
When these try to join the controller we receive the following error message.
%CAPWAP-3-UNSUPPORTED_WLC_VERSION: Unsupported version 7.0.116.0 on WLC Plt-72-Controller-1
Do the 3600's require a certain revision of code?
Also I read were the 3600's require a GE connection. Will they work on a FE connection?
Please advise.....................
I believe that version 7.1 also supports the 3600's and may support more of the older ones if that is an issue.
5 Replies 5
Stephen Rodriguez
Yes, you need to be funning 7.2 code for the 3600 to join and work.
Make sure you check the release notes for hte supported AP, incase you are running any that are not supported in 7.2
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Thanks.....That is what I was afraid of.
Thanks I will  look at the release notes on this version of code.
7.1 does, but for the full features of the 3600 to be used, you would need to be on 7.2, as it's the 'full' release.
Steve
HTH,
Steve
