03-27-2015 01:14 PM - edited 07-05-2021 02:48 AM
I'm having issues getting a WGB bridge (autonomous) connected to an SSID. The SSID is broadcast from a centralized WLC with lightweight access points. It supports WPA/TKIP or WPA2/AES with 802.1x/cckm for authentication key management. PEAP(MS-Chapv2) is used for the authentication. I've referenced the document http://www.cisco.com/c/en/us/support/docs/wireless/virtual-wireless-controller/115736-wgb-peap-00.html for a base config.
The goal is to have a single client connect to the ethernet on the bridge and be on the SSID subnet. I want the bridge to connect with WPA2/AES and use CCKM for key management. I keep getting the following error:
"Mar 27 19:50:07.831: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: No WPAIE exist for the ssid SSID"
I suspect that my layer 2 settings are incorrect on the WGB, but am not really sure what commands I should be using to set the WGB to use WPA2/AES with CCKM. I have also confirmed that the user account works on another device. I've pasted the config below. I suspect I may need to change the dot11 ssid key-management and/or the encryption cipher on the radio. Any feedback would be welcome. Thanks
logging rate-limit console 9
enable secret 5 $1$sO03$.ZrpsOQ2EBjUvDUsUmHF6.
no aaa new-model
no ip routing
dot11 syslog
dot11 ssid SSID
authentication open eap PEAP
authentication network-eap PEAP
authentication key-management wpa
dot1x credentials PEAP
dot1x eap profile PEAP
infrastructure-ssid
eap profile PEAP
method peap
crypto pki trustpoint CA
enrollment terminal
subject-name CN=CA
revocation-check none
rsakeypair CA 2048
crypto pki certificate chain CA
certificate ca 3057DA5426DF3EA048350C6DD769B056
308203ED 308202D5 A0030201 02021030 57DA5426 DF3EA048 350C6DD7 69B05630
0D06092A 864886F7 0D010105 05003068 31133011 060A0992 268993F2 2C640119
16036564 75311430 12060A09 92268993 F22C6401 19160477 69736331 14301206
0A099226 8993F22C 64011916 04686F73 70311530 13060A09 92268993 F22C6401
19160575 77686973 310E300C 06035504 03130555 57484341 301E170D 30393037
32393230 33383532 5A170D31 38303430 35313632 3634305A 30683113 3011060A
09922689 93F22C64 01191603 65647531 14301206 0A099226 8993F22C 64011916
04776973 63311430 12060A09 92268993 F22C6401 19160468 6F737031 15301306
0A099226 8993F22C 64011916 05757768 6973310E 300C0603 55040313 05555748
43413082 0122300D 06092A86 4886F70D 01010105 00038201 0F003082 010A0282
010100AA 62C0456A 53563DCA 84D40A81 219D7E16 00945048 DA95453D 3C5F0EB1
9B2E11D5 D6DA87DD C980D91B C7FDF2AB A4701370 370D4A0C C7BAD7D8 E2B615EC
09F287E8 43ED8C1F 12F8DBC1 4A7B802E 186AB39A 848B7C15 BFBF9438 4579C418
71A26135 C1B38FEA BABD7BBA 4ECF3DEB 9250F794 51012EFD E5017D38 5B12BDD5
3E90D5E3 A476767C B1E4A80E C450B340 2C98F487 7CB18B12 F3577114 8B1CFCDF
73F2AD89 FFBE5B5B 6D380E39 A3B4D2F2 FCC1681E 5FB56CCC D39C721A C67236F3
28856880 638A5295 5E93899B 8F703488 382635E1 32789BEA C07E7A6A E9ACA279
2C2FD1D6 6F09BA3D 329F9178 44BE984E 01CA8357 070C29A4 99F79038 F9F40B98
C2F12502 03010001 A3819230 818F3013 06092B06 01040182 37140204 061E0400
43004130 0E060355 1D0F0101 FF040403 02018630 12060355 1D130101 FF040830
060101FF 02010030 1D060355 1D0E0416 0414B170 6D220DAC 07D152FE 9ED44681
BAD0A4D5 B70E3010 06092B06 01040182 37150104 03020101 30230609 2B060104
01823715 02041604 14B20FE4 68E0AB5A 65D85C8F 7E3E1AA1 E876B64F 68300D06
092A8648 86F70D01 01050500 03820101 00207415 CA958BA5 C4CD4B7A 39393A3C
00E398FB EF9AA2FA DE2FB90A 82C624D8 7BCBCA9A 9E6117B7 C46489DB 9B2522C2
3A58E0D5 8EA62948 0B22C18F 7ED32F90 0FEC1C96 DC12080D 92EB9377 6B6E6FD6
7C9079ED 9D8A6E9F FFC740CF CFAF4172 E75A0A11 6EA42B13 230A9971 E9CC8430
0BB4AD0B E5312EB7 1E39AFE0 774F2282 5A903D89 CC0AA514 7F7E070E BECF4594
041ED411 6A71F7E8 D65D6926 FBC4D8FE EC32A6B1 5A3EA69E CB740E68 A29EB347
B2BA5B5B BC44BABF BF3C456F 6D9CC62C 52C45981 A7ECD182 58246227 45D5980F
E3AC8F56 FC102AB8 FC9F7865 1084C7B1 9D696116 16BAF6A8 68F68D1A 306A0274
E53CF52B 1B1738DD 4A18AFAA 0E181E3F F1
quit
username ****\*******
password 7 ******
pki-trustpoint CA
username Cisco password 7 123A0C041104
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid SSID
antenna gain 0
stbc
station-role workgroup-bridge
bridge-group 1
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
Solved! Go to Solution.
03-27-2015 07:35 PM
Hi Josh,
Yes, create a test SSID with WPA2/AES only for this WGB setup & test it.
Rasika
03-27-2015 01:43 PM
In WLAN security setting, untick WPA/TKIP options & leave only WPA2/AES.
Test it with that & let us know
If no success, try to change WGB SSID config as shown below & see if that make any difference.
authentication key-management wpa version 2
Rasika
****Pls rate all useful responses ****
03-27-2015 01:54 PM
I'm unable to disable TKIP because its a production SSID that has some handhelds that are manually configured for TKIP. I'm working on getting those clients updated or removed. I've tried the command you recommended "authentication key-management wpa version 2" and I'm still getting the same association error.
"Mar 27 20:47:27.815: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: No WPAIE exist for the ssid SSID"
I could try spinning up a separate test ssid with wpa/tkip disabled if you think that might help.
-Josh
03-27-2015 07:35 PM
Hi Josh,
Rasika
