WLC 5760 and AIR-LAP1131G-E-K9
Ivan Marinovic
I am unable to join AP 1131 to new wireless controller 5760.
I found that they are not supported:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/3-2_0_se/release_notes/OL28115_3_2_se_rn.html#98367
Maybe there is some workaround :-))
Thank's,
Ivan
Hi Ivan,
No workaround if you only got a 5760 as WLC. Here is the supported AP list as of IOS-XE 3.6.0E code release.
http://www.cisco.com/c/en/us/td/docs/wireless/technology/5760_deploy/CT5760_Controller_Deployment_Guide/Supported_Features.html#pgfId-1071753
If you have many of those AP, I would suggest to buy a 2504 WLC to manage those. Converting to Autonomous would be another option, but it will not work well with if your AP are in mix setup (WLC managed & autonomous)
Regarding 2504, there is a bundle offer (AIR-AP3702I-UX-WLC) when you buy 2x 3702I, you will get 2504 with 25AP license for almost free.
Rasika
**** Pls rate all useful responses ****
Hi Ivan,
Rasika
