3700 Integrated Wireless Switch - configure Ethernet ports
cisco.balch
I have a 3750 wireless controller with 24 Ethernet ports on the front.
How do I configure those ports (vlan etc) - if I connect to the console port on the box I can configure the wireless controller but I dont see how to can access to the switch so I can configure the wireless ports.
jeff.kish
Level 7
Level 7
If I recall correctly, there should be another console port for the 3750 itself. It's been a while since I worked on it though, so maybe I'm wrong?
Check the back of the switch for another console port.
You are quite correct - Many Thanks.
hi cisco.balch..
Apparently there a 2 console ports at the rear of the 3750G WS.
I am able to console to the switch console port. However i am unable to console to the controller console port.
Do i need proceed with express setup to the Switch GUI to enable that?
please advise
