3800 Access Point Speed Configuration
Kelvin C
Afternoon/Morning Community,
I have a bit of an issue here with a 3800 Cisco AP that for some reason is only pulling about 40MBPS at max for anything connected to it. However our connection should be twice that at least. It's currently linked to a 2500 WLC so is there something I have set wrong somewhere that's throttling it to only 40?
Thank You!
kareem ahmed
can you check under WLAN is it enabled 5G & 2.4G or its only 2.4G
Sandeep Choudhary
Post "show client detail <mac_address>" output when you have 40Mbps speed. Also pls attach "show wlan <wlan_ID>" output as well
Dont forget to rate helpful posts
