3802 Aps not showing up in Controller 3850 GUI after being configured
I tried configuring the controller so the APs auto-join in with CAPWAP but when I open the controller GUI no APs show up  and I get these error messages in the AP :
config down up [*06/15/2020 22:26:13.4856] [06/15/2020 22:26:15.6000] wired0 emac 0: link up [06/15/2020 22:26:15.6500] wired0: link up [06/15/2020 22:26:15.7000] wired0: started [*06/15/2020 22:26:15.7505] aptrace_register_sysproc_fn: duplicate registeratio n for 'wired'
6 Replies 6
rafafilho11
Can you confirm if the access-point is on the capwap mode ?
In case the access-point is in the mobility express mode you'll need to convert them:
Converting an AP from Mobility Express to CAPWAP Type
To convert a Mobility Express AP into a CAPWAP AP, ap-type capwap from mobility express to lwap
Connect to the Console Port, Telnet or SSH to the AP.
Login to the Mobility Express controller console.
Type: apciscoshell (connect to the AP console)
Login to the AP console using the username Cisco and password Cisco. Both are case-sensitive.
Enter enable.
Type command: ap-type capwap, and confirm .
(Cisco Controller) > apciscoshell
APxxxxxx> enable
APxxxxxx capwap ap primary-base mywlc_name x.x.x.x
yes the access point is on capwap mose
Leo Laohoo
Time and date is wrong.
I changed the date but it still didn't fix my problem
Mark Elsen
 - What software version is the 3850 running ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
16.3.9
