3850 to control 2702 APs - license errors
zzman55
Community Member
I'm trying to setup my 3850 as a controller to run 2702 APs.  The AP have been previously used with a different switch that is now gone.  I get the following errors on the 3850 when AP is trying to connect:
*Jan 13 04:10:49.586: *%LWAPP-3-AP_DB_ERR1:Switch 1 R0/0: wcm: Unable to find AP 843d.c63e.8b70 entry in the database, could not process delete request
*Jan 13 04:10:49.587: *%CAPWAP-6-DTLS_CONN_ERR2:Switch 1 R0/0: wcm: DTLS connection not found for AP 10.10.0.7 (15015), Controller: 10.10.0.2 (5246) dtls payload
*Jan 13 04:10:49.876: *%LWAPP-3-AP_LICENSE_REQUEST_ERR:Switch 1 R0/0: wcm: License request failed for AP 843d.c63e.8b70 - Check for Controller Licenses
*Jan 13 04:10:49.877: *%CAPWAP-3-AP_DB_ALLOC:Switch 1 R0/0: wcm: Unable to alloc AP entry in database for 10.10.0.7:15015
I think the 3850 has the right license:
switch1#show license right-to-use
Slot# License Name Type Count Period left
1 ipservices permanent N/A Lifetime
License Level on Reboot: ipservices
Any ideas or suggesions what else can I check?
Rich R
And you also need AP licenses: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-1/converged_access_deployement_guide/m_conAccess_deploy_guide/converged_access_enabling_wireless.html#concept_5F0A509DB4074B5AA21488E5285A112C
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
6 Replies 6
Leo Laohoo
What firmware is the switch running on?
3850 is running version 16.3
version 16.3
Rich R
zzman55
Community Member
How can I tell if I have the right licenses?  Here is what I get from RTU license:
switch1#show license right-to-use summary
apcount base 0 Lifetime
apcount adder 0 Lifetime
Can I use an evaluation license for now just to get it going? What kind of license would I add? An AP adder license?
zzman55
Community Member
So I tried to add the adder licenses by typing the following:
license right-to-use activate apcount 25 slot 1 acceptEULA
And the AP was able to register and join. So it all works!!
Thanks very much for all your help!!
