3850 WLC Web Auth
scottbreslin
Level 2
Level 2
Hi Guys,
I need to integrate a 3850 WLC into an existing library Wi-Fi solution .  The library has an existing web authentication solution which comprises of the portal page and authentication services.    Therefore, I need to add the 3850 into this solution.
Does anyone have any configuration guides etc. that would point me in the right direction.
Basically, the clients will associate the to the SSID broadcast from the AP connected to the 3850 and then need to be directed to the portal page on the 3rd part server where they will then need to authenticate with a username and password where finally the authentication server sends the accept/accept back to the WLC to enable the guest device to access the internet.
Scott
