3rd party antennas with Cisco
ericgarnel
Level 7
Level 7
This antenna seems like the same one as part # ANT-2465
http://www.tessco.com/products/displayProductInfo.do?sku=456947
if the specs are the same, is there any reason why it should not work with a 1020 series AP?
scottmac
Level 10
Level 10
If the specs are the same, and you have the connections, it should work fine.
Good Luck
Scott
Hey there,
Not officially supported but will work if connection type is the same.
Aaron
Agreed, it will work. We have one customer who had a Cisco Yagi blown away (they fitted it, not us!) We happened to have a Lucent one spare and they had the connectors to join the two. Result; back in action and still working several months later.
