4400 code
evarner
Level 2
Level 2
Waht is the latest code for the 4402-50 controllers that is compatible with the AIR-LAP1242 APs? Any help would be appreciated.
Scott Fella
The latest is the 7.0.234.0. The model you have can't I higher than the 7.0.x.
-Scott
Scott Fella
-Scott
Always check the release notes also. The release notes will have the APs supported along with new feature, caveats etc. the newer WLCs (5508, 2504, WiSM2) can use the 7.2.x and newer code, and the 1242 is still supported with the latest 7.2.110.0 code.
-Scott
