cfajardo1_2
Level 7
Level 7
which access point could be use on 4400 controller?
Is the AIR-AP1010 fitted on this?
mx
Level 5
Level 5
the 1010, 1020, and 1030 series will work but I think are now discontinued. The 1130 LWAP will as well as the 1230 once they have been 'upgraded' to the LWAP code.
Rob Huffman
Hi Celso,
Have a look at the following;
This guide will help you to install a Cisco Aironet Lightweight Access Point Protocol (LWAPP)-enabled access point on your wireless network. The following Cisco Aironet access points currently support LWAPP:
•Cisco Aironet 1130AG
•Cisco Aironet 1200 series with 802.11g or the latest 802.11a radio (or both)
•Cisco Aironet 1240AG
LWAPP-enabled access points are part of the Cisco Integrated Wireless Network Solution and require no manual configuration before they are mounted. The access point is configured by an LWAPP-capable Cisco wireless LAN controller.
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_quick_start09186a00805100f5.html
Hope this helps!
Rob
Please remember to rate helpful posts........
