5 GHZ band on cisco 7921G phone compatibility problem with AIR-AP2802I-I-K9 indoor AP !!
OOHTelecom
is there anyone who can help me to solve the compatibility problem between the cisco 7921G phone and the AP 2802i indoor on the 5 GHZ band thanks in advance
7921G used firmware : 1.4.4.3
AIR-AP2802I-I-K9 IOS version : 8.3.150.0
7 Replies 7
What's the issue you are having ?
Here is the deployment guide, if you want to check feature support of this 7921G model
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cuipph/7921g/6_0/english/deployment/guide/7921dply.pdf
Rasika
*** Pls rate all useful responses ***
Hi Rasika and thanks for your relply,
I just consulted on the link you sent to me about 7921G deployment that AP-1802i access point is not on the list of AP's so can you confirm that the 7921G is not compatible with the access point AP -1802i !
if you want more information please tell me
7921 is compatible with AP1800.
What is the issue you are seeing?
Sorry I wrote 1802 instead of AP 2802 i I meant apt AP 2802 i
Leo Laohoo
What issue(s) are you seeing?
What is the issue?
