5508 Controller Controller
boitumelo69
Visitor
Im configuring a 5508 controller on a layer 2 network. Im only able to access the controller through the service port and not through the management interface. I can see the controller on the CDP neighbour table on the switch that it connects too. I have configured another controller in my lab and found that i have the same problem with the second controller.
SDNCTNSW-Century_SW1#show int Gi2/0/1
GigabitEthernet2/0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0017.5983.2281 (bia 0017.5983.2281)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:09, output 00:00:15, output hang never
  Last clearing of "show interface" counters 6d01h
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 2000 bits/sec, 2 packets/sec
     8830 packets input, 12805388 bytes, 0 no buffer
     Received 8830 broadcasts (0 multicast)
     76755 runts, 0 giants, 0 throttles
     76755 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 8769 multicast, 0 pause input
     7859928 packets output, 833702013 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
SDNCTNSW-Century_SW1#show run int Gi2/0/1
Building configuration...
Current configuration : 124 bytes
interface GigabitEthernet2/0/1
 switchport mode trunk
 channel-group 5 mode on
end
SDNCTNSW-Century_SW1#show cdp nei Gi2/0/1 de
Device ID: ZA377-SMHWC-MBCENTURYCITY-WLC01
Entry address(es):
  IP address: 53.32.224.15
Platform: AIR-CT5508-K9,  Capabilities: Host
Interface: GigabitEthernet2/0/1,  Port ID (outgoing port): GigabitEthernet0/0/1
Holdtime : 124 sec
Version :
Manufacturer's Name: Cisco Systems Inc.  Product Name: Cisco Controller  Product Version: 7.6.130.0  RTOS Version: Erro  Bootloader Version: 1.0.1  Build Type: DATA + WPS
advertisement version: 2
Duplex: full
Management address(es):
Entry address(es):
Interface: GigabitEthernet2/0/1,  Port ID (outgoing port): LAGInterface0/3/1
Holdtime : 124 sec
Version :
Duplex: full
Sandeep Choudhary
Try to allow specific vlan on WLC connected port and try again:
Example:
interface f0/12
switchport trunk native vlan 10
switchport trunk allowed vlan 1,2,10
Don't forget to rate helpful posts
This change in vlan configuration didnt help and im still not able to get to the device via the management port.
SDNCTNSW-Century_SW1#sh run int Gi2/0/1
Current configuration : 195 bytes
end
SDNCTNSW-Century_SW1#ping 53.32.224.15
Sending 5, 100-byte ICMP Echos to 53.32.224.15, timeout is 2 seconds:
Success rate is 0 percent (0/5)
