5508 wireless controller, How to access ASDM/gui?
saidfrh18
How is the ASDM for the 5508 wireless controller accessed?  Require to configure the above.  Thanks in advance.
If you don't like CLI then there's a GUI for it:  WLAN Express Setup
9 Replies 9
saidfrh18
The system version for the Cisco 5508 wireless controller is:
Product Version.................................. 8.2.141.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Web GUI is pop the IP address into a browser and use either HTTP or HTTPS.
Is there a default IP address ?
Console into the controller and post the complete output to the command "sh sysinfo".
Unable to terminate autoinstall.  ' terminate autoinstall? [yes]:'
Carrige return to accept 'Yes' isn't accepted, nor typing 'Yes'.
Yesterday morning, was able to enter the controller.
Unable to terminate autoinstall. Any advise?
"Would you like to terminate autoinstall? [yes]: yes
System Name [Cisco_b1:11:a4] (31 characters max):
AUTO-INSTALL: process terminated -- no configuration loaded
reset system
Enter Administrative User Name (24 characters max): reset system
Enter Administrative Password (3 to 24 characters): *********
Re-enter Administrative Password : *********
Service Interface IP Address Configuration [static][DHCP]: static
Service Interface IP Address: 192.168.90.1
Service Interface Netmask: 255.255.255.0
Enable Link Aggregation (LAG) [yes][NO]: yes
Looks like you were able to go through the setup wizard. You need to complete that piece before you can access the WLC via the GUI.
-Scott
Leo Laohoo, Thanks.  Can you assist on configuring a Cisco ASA5520 firewall, key is for the outside, g0/0 to receive dhcp address.
