5508 Wireless controller SSID change
farhanegal77
Frequent Visitor
Frequent Visitor
I know this is really easy, but I was not able to find solution for this.
 I wanted to change the name of the SSID without re-creating all the settings for that WLAN.  I also need to export the running configs on the wireless controller and perhaps load them on WLC.
I also need to implement SSO (single sign on) with Active directory integration.
Please help.
Saurav Lodh
Level 11
Level 11
You cannot edit it after implementation, you have to recreate the WLAN profile.
https://supportforums.cisco.com/discussion/11380261/wlc-configuration-script-or-backup
Hello Lodh/anybody,
I need to see  instructions on how to re-create/rename SSID without changing other WLC configs.?
