Guest wireless network creation
farhanegal77
Frequent Visitor
Frequent Visitor
Hello follow networkers,
I need to create a guest network and ensure that users go STRAIGHT to the Internet without connected to my other wireless network. I will also want to create new SSID for this Guest wireless network.
I am using 5508 Wireless Lan Controllers for this implementations.
FE
2 Accepted Solutions
millerlw
Level 3
Level 3
That should not be a problem.  Create a new interface on the controller for guests, connect that to your guest network, create a new SSID on the controller and associate it to the new interface you created.
See this
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70ovrv.html
Leonard
mohanak
The Guest Access solution is self-contained and does not require any external platforms to perform access control, web portal, or AAA services. All these functions are configured and run within the anchor controller. However, the option exists to implement one or all of these functions externally and is discussed later in the chapter.
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Mobility/emob73dg/emob73/ch10GuAc.html
millerlw
Level 3
Level 3
See this
Leonard
Saurav Lodh
Level 11
Level 11
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-vlan/70937-guest-internal-wlan.html
mohanak
