5508 Wireless Licensing
Dan Man
Level 3
Level 3
I purchased two licenses.  One that's for 250 AP's, the other is for 50 AP's.  I have two 5508's that I'd like to apply these license files to.  Is there any way to split the 250 licenses into two 125 licenses, and the 50 licenses into two 25 licenses?  That way I can distribute evenly.  Thanks!
Rasika Nayanajith
You can't split like that.
You have to purchase in break down (100, 100, 25,25) instead of 250 single licence. You can check with Cisco AM & see wether you can get break-downed licence.
Rasika
**** Pls rate all useful responses ****
