5520 Controller Network Summary Timeline
Stefan_954
Community Member
Hi all,
Does anyone have any idea what the time period is set to when you're on the Network Summary page?
I see Rogue APs, Top Application Usage, Top Client Usage but there's no option/indication for the timeline of this data.
My top application is Facebook with 5.1TB (1.1 Gbps Throughput) usage but I have not idea if this is in the last day or 97 days that the controller has been up for.
"When the dashboard timeout is turned off, the session will expire after 4 hours."
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/guide-c07-743627.html
Hi Flavio,
Thank you for the info.
I see that link is for the 9800 controllers, is it the same for the 5520's?
I would also like to add that very early in the mornings, the top client usage and top applications usage is still very high (+-5TB for Top Application Usage), which wouldn't make sense if the timer is 4 hours.
I have the 9800's and my dashboard even if I logout, will have the data.  There is an option to clear it out and of course a reboot would also do the same.  On the 9800's the application visibility page goes up to 48 hours.
-Scott
