5520 untagged management vlan/SSO
craigshawm6
When setting up my HA pair of 5520, I can only put them in SSO if I tag the managment vlan. Our existing 5508 have untagged management vlan and when I tag the vlan on the 5520, I do not have connectivity into the gui through the management IP. I can only connect locally through the service port IP.
Hi @craigshawm6 ,
You have to tag the VLAN on WLC as a best recommendation for HA SSO deployment. Please refer Management Interface Vlan Tag
For an example if you have a VLAN 10 for your management. You have to tag the VLAN 10 on the WLC interface and on the switch you will be required trunk with no native VLAN as 10.
HTH,
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Hi @craigshawm6 ,
HTH,
omz
Release 8.0 onwards, it is mandatory to tag the RMI and management interfaces.
