Bookmark
Subscribe
2334
5520 wireless controller command's output to a file and then ftp
lpalpac
i have the following problem:
on a 5520 WLC i can execute the following command from the CLI
show netuser summary
is there a way to save the output (say output.txt) of this command to a file on the 5520 filesystem and then
use transfer upload and specify output.txt as the source and transmit that over sftp to a remote server?
could someone give me a complete example of the command sequence that would do that?
and then:
is there a way, a command, for the 5520 to view the content of a file? something  like a unix cat?
and a command to delete a specific file?
thank you everybody
6 Replies 6
Leo Laohoo
Why not just log the session?
Hi !
because the next step would be to automate the task, running it each day at a certain hour..
 - Standard methodologies would imply, a syslog-server for general logging purposes, and the value(s) you are looking for, try if they can be fetched or are supported in any of the snmp  MIBS.
 M.
SNMP and/or API
marce1000
 - These items or questions are generally not possible, note that AireOS is not Unix or Linux. You could use operator-terminal tools such as Putty , which can usually save a session or from a Linux, you can first type % script my_controller_log.txt , then connect to the controller.
 M.
and another option "ssh 5520wlc | tee mysavedoutput.txt"
that logs your entire ssh session to file.
You can then use script to extract the part you're looking for from the file.
Like the others have said AireOS was not designed to do what you want to do.  It doesn't provide user access to the file system.
