702W APs out of box not showing on WLC
Lovleen Arora
We have a 2504 WLC with existing 11 APs which are 3602-I.
We want to add 5x more 702w APs. I have installed the license on the 2504 WLC and that was fine.
I have added new APs mac to my dhcp server, so they get an IP now and I can telnet/ssh into them using their IP (and default Cisco username/password).
The problem is that they are not showing up on the WLC. I see on the APs ssh session that its running the (ap1g1-RCVK9W8-M), Version 15.2(4)JB5, image.
Can someone please explain how I can get the APs showing up on the WLC?
Thanks in advance.
2 Accepted Solutions
What code running on your WLC, it has to be 8.x to support this AP model. refer this
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
If you have compatible code on your WLC  & still AP not register, pls attach AP console output while booting & trying to register
Rasika
**** Pls rate all useful responses ****
Yes, go ahead with the upgrade & let us know.
If all good, you can mark thread as "answered"
Rasika
Rasika
thanks, the code on the WLC is 7.4, I will upgrade the WLC and then see if that helps, thanks for the suggestion.
Rasika
