11-24-2006 11:26 PM - edited 07-03-2021 01:17 PM
I'm working on a project to deploy a wireless network on a wide open area( 3 Kms, for ip telephony mainly. The big question is: how far can I go with a 7920 without problems? Is it possible to extend this range (using another antenna or something like that)?
Thanks in advance
11-25-2006 11:45 AM
The 7920 will use the highest data rate when on call and can tx up to 100mw for Americas domain (50mw for everywhere else). The 7920 has a 0 dbi gain antenna. For AP side, 11 mbps can go up to about 360 feet depending on the antenna.
11-29-2006 09:06 AM
The best way to know for sure is to test. I have a working environment with seven access points in a half acre space (about six building). I can use my 7920 within 15 to 20 feet of an access point and then the call quality starts to degrade.
