7925G/8821 Signal Issue
alexanderkieser
So trying to isolate this and it's driving me nuts ... recent deployment replacing WisM's with 8540's and new 3800 AP's (around 300). and I have both model phones between the 7925/8821 and when standing right below an AP my RSSI is between 30-80, and when going around the corner it sits at 80 and 1 bar/no bars on signal .. yet my person phone on the same 5Ghz band is fine and shows good signal ...
WLAN:
a- Band only
QoS - Platinum with WMM policy allowed
Coverage Hole/Aironet IE Enabled
DTIM Period - both set to 2.
802.11a:
Beacon period: 100
Fragmentation Threshold: 2346
DTPC Support: enabled
6-9 disabled
12-Mandatory
18-supported
24-Mandatory
36-54 disabled
CCX Enabled (60)
TPC:
MAX: 17
Min: 11
Threshold: -70
DCA: 1 hour timing
Avoid Foreign AP interference: enabled
Avoid non-802.11a noise: enabled
DCA Channel Sensitivity: low
Channel Width: 20
DCA Channels: 36, 40, 44, 48, 149, 153, 157, 161
EDRRM: enabled
Sensitivity Threshold: low
Coverage:
Voice RSSI: changed to -72
EDCA Profile: Voice Optimized
DFS: 0 and no options selected
802.11n/ac: unchecked and MCS rates all checked
I've been through multiple guides and tweaking back and forth but still signal is an issue in weird area's.
Leo Laohoo
The 7925G, if loaded with the correct firmware, is a mature system.  The software is mature and it could roam (compared to older firmware) very well.
The 8821 and, if I was to be diplomatic about it, still a "work in progress".  There are known issues about the way the 8821 "roams".
The 8821 had a firmware update (SR2) released Thursday.
