12-11-2015 10:47 AM - edited 07-05-2021 04:22 AM
Based on the 7 point recommendation post to "How to get your 792x wireless phones performing reliably" it recommends setting power levels in all 5GHz deployments but the very densest ones, to simply set a power level of 1 (maximum).
Does this impact the phones and produce one-way audio when the UNII-2 channels operate at 200mW and the phones are only capable of 40mW?
12-11-2015 11:00 AM
Yes, you should never set AP power level to its max.
If AP power matches the client, that is the best case scenario.
Rasika
01-13-2016 01:17 AM
01-13-2016 03:54 AM
We have a few thousand 7925s and we have an all Wirleess office with 300 + users all of whom have 7925.
A solid RF survey is a must. We survey at unii1 12.5 mw on 5 ghz. Then follow all the best practices. Avoid DFS channels if you can.
