PWRINJ4
malsaadi2
Frequent Visitor
Frequent Visitor
Hi everybody,
i have new access point 3702E with directional anntena, i think it needs power more than 15.4
the access switch 2960x 24 370W, that's mean each port 15.4.
my question is have i go with PWRINJR4 or  PWRINJR5 to increase the power.
7 Replies 7
Scott Fella
You need the PWRINJR-4. You can reference this day at sheet that mentions that specific model number:
http://www.cisco.com/c/en/us/td/docs/wireless/technology/apdeploy/8-0/Cisco_Aironet_3700AP.html
-Scott
-Scott
Hi scott Fella,
can i use access switch 2960x no poe with that pwrinjr4
because pwrinjr4 will provde 20w, l think no need to purchase switch POE while there is power injector 4 available
what I mean is if there is switch 802.af plus pwrinjr5 how many W can we take
15.4+15.4= more than 20
is that correct?!
You need to either have a 802.af or use a pwrinjr4.  There is no combination of power, bottom line, use one or the other.
-Scott
-Scott
Mr. Scott Fella,
i am confused, do mean i can go with switch no poe with power injector4
You can use the switch as long as it supports the recommended power.
-Scott
-Scott
