8.0MR4 Beta Availability
Javier Contreras
Release 8.0.140.0 is now posted in CCO, the beta program is over
Thanks for your interest!
Updated August  26h.
Resolved Caveats up to 8.0.134.71:
CSCuq28038
Hop2- multiple attempts to rejoin WLC in very-fast convergence
CSCur63031
AP error: %ENTROPY-0-ENTROPY_ERROR: Unable to collect sufficient entropy
CSCur68316
802AP-891 in flexconnect mode are losing vlan mapping after power cycle
CSCut51019
observing error message adding oeap mode ap to apgroup
CSCut71612
BGL-Alpha: OUI string should be synched across HA
CSCuu08012
AP2700 CleanAir sensord died (src/dspm_main.c:389) - slot 0
CSCuv09019
Cann't set authentication response timeout value thrgh SNMP MIB browser
CSCuv33255
AP CDP neighbor information is missing/outdated
CSCuw48118
ASR920 - crash in bcopy called from 'addnew' during reassembly
CSCuw67167
SNMP set on device is failing for fields under Interfaces
CSCux19371
8500 emweb crash on browsing mDNS Policies
CSCux90031
intermittent multiple packet/ping drop between RAP and MAP 1572
CSCuy32349
NDP timer change for 7.6 parity
CSCuy53072
SNMP cLMobilityGroupMembersTable returns wrong  value from WLC in PI
CSCuy53596
CleanAir fatal error and radio reset on Flex+Bridge AP
CSCuy70474
Missing device information in Local profiling device stats
CSCuy94534
3700/2700 on DFS dont see 3700/2700 as neighbor when Rxsop High/Med/Low
CSCuz18317
WISM2 doesn't provide  all respective license OIDs in SNMP response
CSCuz22367
3502 AP crash in "LWAPP RM Receive process"
CSCuz24719
AP joined to  out of box rf-gr,  radio change to enable after reboot
CSCuz34660
controller Interface overide issues  when user changes
CSCuz34818
FlexConnect External WebAuth ACL in Flexconnect group not removed
CSCuz35221
Mobility handoff fails in new mobility dot1x CWA client reconnect
CSCuz49941
Watchdog Countdown:20/10 warning messages on 5500 HA console
CSCuz52435
Evaluation of wlc for OpenSSL May 2016
CSCuz57472
IPV6 not getting disabled 8510  code 8.0.120.0 causing mcast Q full
CSCuz71587
Not able to push the flexconnect template from Prime to WLC
CSCuz74046
Unable to create default snmp community from GUI
CSCuz78555
Bulk sync status "In-progress" after standby boots up
CSCuz91317
Foreign not exporting client information to anchor
CSCva03376
UX-AP3702i After primed carrier set 5GHz only allowing four UNII3 ch
CSCva14667
GET on Ap groups Table after set - response missing
CSCva15190
WLC CCX client location calib shows low cLD11ClientCalibSamplesCollected
CSCva17630
WLC sends warm-start trap instead of cold-start during autoprovisioning
CSCva26821
Auto Anchor Deployment: Scheduling deletion of Mobile Station fails
CSCva27711
FlexConnect: AP radio reset during FT when Central DHCP is enabled WLAN
CSCva28061
WLC crashed on "emWeb" task when adding flex AP to a customized ap-group
CSCva33212
Re introduce auto provisioning feature on WLC 2504 running 8.0
CSCva33807
wlc crashed with test location locsumperap CLI
CSCva41732
debug log flooded with "*mcListen:" message when client filter is enable
CSCva49651
Flex Data DTLS enabled, WLC to flush old data DTLS sessions on WAN flap
CSCva55011
Task Name redXmlTransferMain crashed with HA SSO
CSCva55782
WLC sending wrong NAS ID when AAA override is enabled .
CSCva59172
RF - Profile paramaters are not pushed for optimised roam
CSCva59715
WLC crashes when pre shared key of length 46 is given in HEX
CSCva71341
Flexconnect: Group specific ACLs are cleared from AP
Resolved Caveats up to 8.0.134.50:
CSCuq75748
multicast config SET failing to commit
CSCuq86263
False DFS detection on 1600
CSCus50404
AP Name is Mismatched Between Controller and AP
CSCut12606
Remove auto-containment from high security level setting
CSCuw29539
1552E series AP running lightweight IOS will not discover WLC using DNS
CSCux25143
WLC: SNMP task memory leak in 8.3 in k_mib_cisco_lwapp_ap
CSCux51833
Client fails on RAP with AAA Override ACL when AP is in Flex+Bridge Mode
CSCux57925
Controller entering yellow zone at 1.6 GB with Teredo traffic
CSCuy13829
AIR-CAP2602I crash on dot11_pmkid_timeout
CSCuy52607
Data Plane crash - cvmcs_StaToDS
CSCuy70671
Client's mobility role becomes local during F-F roaming in GA webauth
CSCuy82754
5508: Process Queue. enqueue failed. due to local auth failures
CSCuy84467
Flex: AP specific WLAN - VLAN change is not pushed to the AP
CSCuy92423
CWA broken in beta image 8.0.122.50
CSCuz15763
Flex Data DTLS enabled AP gets stranded with WAN link flap
CSCuz23758
Local Profiling Not Sorting Correctly, not corrected on 8.0.132
CSCuz31305
Random blank field in  Rogue summary > active rogue ap > detail page
CSCuz40066
Guest Anchor:Foreign to Foreign roam fails on GA scenario
CSCuz47786
FlexConnect AP sending IGMP report to WLC for local switching WLAN
CSCuz49482
FlexConnect: WLAN config stays in ap-specific on moving fro
CSCuz49802
band select fails for Client  RSSI field > 8.0 WLC
CSCuz49968
8.0 MR4 WLC crash during SNMP set opeartion
CSCuz53866
RF group is not formed. group Memeber is not added to static leader
CSCuz56009
Client reassoc not happening when central dhcp enabled
CSCuz56479
WLC cLReapApVlanInheritance object not taking WLAN-Specific value (3)
CSCuz58011
FlexConnect: WLAN is not removed from the AP
CSCuz59734
Proper support for 1572 B domain : VID:02 FCC requirements
CSCuz63274
mDNS snooping drops IPv6 mDNS traffic
CSCuz63877
F to F roam failed with L3 raom 8510 anchor with 5508 foreign behind NAT
CSCuz72994
Samsung S6 11r clients reassociation denied leading to full association
CSCuz78359
Guest anchor CWA: Client may lose ip while moving to RUN state
CSCuz81415
1msec delay in processing IGMP packets causing Bcast queue to remain ful
CSCuz96264
Rogue Client detect is showing 0, there is rogue client on Rogue AP
CSCva08662
Sleeping client entry on  session timeout
CSCva08694
FlexConnect: WLC crash while adding Central DHCP in FlexGroup
Resolved Caveats up to 8.0.134.38:
CSCuz23501
Wimax Register changes for Ch 153 for issues with Broadcomm & QCA Client
CSCux28775
WLC per-WLAN client traffic stats accuracy enhancements
CSCuz65797
New mobility: Guest anchor controller crash observed at mmMaListen
CSCuz70131
GUI not show rogue AP/clients tilll we hit" show rogue summary" from CLI
CSCux73555
8.0MR3: Make 11v DMS on WLAN configurable using Web UI
CSCuz62013
WLC sends system name as NASID in accounting stop instead of wlan NASID
CSCuz73971
Sleeping client entry deletion for AAA reject
CSCuy41330
Error in setting Trap Port Number on SNMP system summary page
CSCuy82849
Memory leak found@mm_heartbeat module on Guest anchor WLC
CSCuz74146
can't edit dynamic interface if wlan is enabled and mapped to management
CSCuz49801
Active configs not syncing to standby when rogue detection security high
CSCuz75862
disabling sleeping client on the WLAN should clear the cached credential
CSCuz77747
Flexconnect: AP 1602 loses native vlan config on reload
CSCuz83936
AP1572 doesnt list the newer -B channels
CSCuz77859
Flexconnect: AP specific DHCP-NAT-PAT config does not apply in the WLC
CSCuz79869
8510 silent crash
CSCuz86679
5508 HA SSO crash on SNMPTask
CSCuz34615
FlexConnect: External webauth ACL plumbed in AP incorrectly
Resolved Caveats up to 8.0.134.26:
CSCuy60049
Observed ap crash in local mode aps.
CSCug98522
PMIPv6: MAG delivering multiple DNS servers to clients
CSCuw66299
wlc msglog showing NMSP Transmit Failure even when there is no MSE
CSCux74970
MAG w/PMIPv6 does not assign secondary DNS to clients via DHCP
CSCuy37694
WLC crash running 8.0.120.0 at task apfRogueTask_1
CSCuy57687
No RF-group membership information when RF-gr member is MA
CSCuy87337
FT and adaptive option disappears in GUI with L2 security as WPA+WPA2
CSCux28775
CSCuz48979
AP: radio reset/core dump: FW: cmd=0x2C seq=6, @7601422F,s@76013F12
CSCuq71837
Control Path Last Flap Time shown wrong on mobility statistics
CSCuv86345
Upgrade Jian wlc from 8.1 to 8.2 & performing SSO changes mobility mac
CSCux96500
WiSM2/WLC crash on bcastReceiveTask
CSCuy47407
Client leak at anchor controller
CSCuy65492
Clean-air details not showing up on GUI On Mobility controller
CSCuy86827
SNMP community, ipsec PSK configuration with HEX is not working
CSCuy95327
802.1x frames are not marked with DSCP CS4
CSCuz33087
GUI does not allow config of SSID with beginning space in Rogue rule
CSCuz39417
WLC crash with SHOW LICENSE FILE command
CSCuz22387
New mobility: NAT public IP change and reverting bring down control path
CSCup85228
AP IO memory leak in DPAA module
CSCuy52757
GUI does not display any rogue APs information
CSCuy87117
Not able to add the MIC with cert type as MIC under AP policy.
CSCuz18014
GA Hardening : Enhancement of mobility msg(EA/EF msg) - phase1
CSCuz39340
Capwap payload aggregation while join of APs.
CSCuz45298
Enhance the cli for client summary to include akmtypes
CSCuz47732
WLC crashed task name "radiusTransportThread"
CSCuw30644
702W 2.4g radio showing low to no throughput at random times
CSCut96691
BGL-Alpha:TFTP address for AP core dump is goofed up after HA switchover
CSCuy14547
HA Config Sync failed
CSCut61668
AID errors on the controller for Flexconnect APs
CSCur94843
External web auth URL  goes through loop  and never gets the Login page
CSCuw61132
Need 5508 to support sleeping client as single Anchor with NGWC
CSCuz03657
New mobility:** LOCK ASSERT ** (mmMaListen) !! crash on WISM2 GA WLC
CSCuz18040
GA Hardening : Enhancement of mobility msg(HC/client del msg) - phase2
CSCuz18869
WLC picking up the unicast DHCP for unknown destination
CSCuz42595
'debug mac addr <ap-mac>' broken in 8.0 unable to get per ap capwap logs
CSCuz47863
SHA256 self-signed cert for WLC web admin
CSCuz02871
Webauth acl is not pushed from flexgroup when a new wlan is added to AP
CSCuz05437
System crash with task name: sshpmMainTask
CSCuz18811
Flex: Local Switching WLAN is changing to Central Switching WLAN on add
CSCuz34485
Rogue AP entry page showing incorrect no of rogue entry range
CSCuz39368
NOS module sometime showing as Interface no:2(unknown type), in trap msg
CSCuz40263
WIPS crash on memory corruption during fuzz testing
CSCuz45831
Adhoc rogue classified as friendly  internal is not showi sh adhoc rogue
CSCuz49616
WLAN-VLAN Mapping incorrect when AP moves across AP-Groups of diff WLANs
CSCuw03318
GUI doesn't pop up an error when a duplicated PSK key provisioned
CSCuz11663
8.2 MR1 Longevity - 5508 Primary crashed, taskname - aaaQueueReader
CSCuz33933
Config upload and download with mobility Config shows group error
CSCuz40055
Actual AP doing containment is more than manually set containment level
CSCuz49333
time zone index was changed.
CSCuu60475
CI - 3702 AP in CI crashes in Process: Net Background
CSCuz18914
8.0 MR4 : FT Over-the-air roam doesn't work
CSCuz44066
AAA shared secret is shown in clear text on flex AP.
CSCuy34975
WLC 5508 8.0.120.0, Crash when adding SSID to friendly rule
CSCuy58091
Evaluation of wlc for OpenSSL March 2016
CSCuu07744
interface not created when we have both acl and wlan-vlan mapping
CSCuy02853
DNS-ACL:debug profiling events/error print junk characters in AP console
CSCuw21213
Downstream: QoS Bronze Profile not marking traffic to AF11 on Flex
CSCuy78583
Invalid AID reported by Standby for client joining in Flex AP
CSCuz38059
Anchor WLC does not free Client Sessions - client entries stale
CSCuz70197
Auth fails junk characters seep clients in GA & session timeout issues
Resolved Caveats up to 8.0.134.13:
CSCup97263
Ambassador: System Crash, Dot1x_NW_MsgTask_2
CSCuq36265
Cisco Aironet 3600 with 11ac module  non bcast SSID client connectivity issues
CSCus06589
2700AP flooding AP sourced packets out of Aux Gig 1
CSCus46848
WLC Hangs on rf-profile page if too many rf-profiles are created
CSCus52826
8:1 rogue client detection on serving channel on wips enabled non mon AP
CSCus52828
snmpv3 rw user creds not working if key length >32
CSCus55192
WLC8500 crashed during removing SNMP Communities
CSCus58120
traplog is wrong about Temperature status
CSCus58468
Multicast Address set issue using SNMP
CSCus68363
Rogue Policies are not apply correctly
CSCus71140
Bonjour service learnt via Mdns AP is being forwarded to wired.
CSCus79056
CT5508 - management frames are not marked with CS6
CSCus80562
Power Client does not work.
CSCut10131
WLC fails to resend ciscoLwappDot11ClientMovedToRunState traps
CSCut40765
WLC reporting incorrect "remote address" to TACACS sever
CSCut44986
wlc throwing error when accounting is disabled on wlan
CSCut55043
FlexConnect Group with space in name renders terminal session unusable
CSCut60058
CTLR does not deauth client when AAA Flex-ACL is not present on AP
CSCut63868
Khanda crashes - Taskname emWeb
CSCut64180
AP holds BW after call when WLC HA SO happens during call setup
CSCut88319
Jira: FF08::/16 range of organization-local IPv6 multicast addresses
CSCut92934
VWLC - AP with expire mic not able to join with Ignore mic settings
CSCuu13860
'autoconvert flexconnect' is stored as 'disable' on startup-commands
CSCuu16052
Don't set DF bit for non-capwap traffic from WLC such as Radius
CSCuu21625
Session not cleared on 5508 anchor with 3850 foreign causing auth issues
CSCuu33740
WLC crash while editing SNMP community - waFormSubmit_snmp_comm_list
CSCuu52409
SNMP: Providing MIBS support for out-of-box feature.
CSCuu59340
SNR alarms for mesh aps have invalid content, not working as expected
CSCuu89294
Master AP in Flex Group not saved in WLC CFG nor commands backup
CSCuu97320
Flex+Bridge&SE-Connect filtering back to uncheck after "Change Filter"
CSCuv03380
During Mesh Roam sec error,Gtway Nt reachable leading to CAPWAP Restart
CSCuv16756
WLC Crash Khanda coredump spamApTask4 spamSendConfigRequestInfo
CSCuv16895
MAP count shown wrongly in "show mesh ap summary" command in WLC CLI
CSCuv29025
Mobility domain name displayed as Junk if created in UTF-8 character
CSCuv34176
SF3:Transmitter Stop Radio reset due DTIM Multicast Pak stuck[BZ 976]
CSCuv36306
AP  sensord_crashFile No CleanAir msmts
CSCuv43466
garbage character are shown in CLI "show run-config startup-command"
CSCuv97132
Show ap image all output will not fetch spamPreDownLoadInProgress
CSCuw02258
Severity Filter for Monitoring CleanAir Interferers does not work
CSCuw10445
SNMP Optimization for the Client and AP MIBS
CSCuw18306
Mesh AP 5GHz channel on non-cofigured channel in DCA list on WLC
CSCuw30129
Debugging logging quickly falls behind real-time
CSCuw34565
7500 Wlc crash after deleting ap crash logs from GUI
CSCuw36069
Threshold MIBs incorrectly set for WSSI modules.
CSCuw41092
AP not send traffic indication in beacon for power-save client after FT
CSCuw61901
Local auth EAP-FAST not working for Flex AP Auth user with anyconnect
CSCuw62172
crash on HA standby while setting auth  priority order from PI in 7.6
CSCuw86320
AP had multiple issues with reason 'offchannel request stuck'
CSCux08557
Reaper reset because of SNMPTASK : VALIDATE_GUEST_SESSION_FAILED
CSCux23003
8dBm max power for -Z, -T domain APs in channels 36 through 64
CSCux45077
AP3500 crashed due to "LWAPP CLIENT" process.
CSCux53607
WLC SNMP for cLAPGroups802dot11bgRFProfileName returns wrong value
CSCux58427
clients cant connect, drops and high latency pings to wlc mgmt interface
CSCux58953
Can't set channel from web interface
CSCux59359
8510 behind NAT on New mobility & client stuck in DHCP_REQD state
CSCux59592
wrong msg in msg log about ACL
CSCux69221
HP printer not seen by iOS devices after returning from sleep mode
CSCux78389
Radius Failover should failover both authacct server on WLAN
CSCux78464
WLC crashes in Process Bonjour_Process_Task
CSCux95662
Pmipv6 client fails to get an IP if there is no DHCP server configured
CSCuy02774
PMIPv6 client binding clean up issues
CSCuy08305
Client deleted because of Intra AP Roam event
CSCuy12943
WLC8.1 : Unknown emWeb error message
CSCuy13549
Flex group push eap-md5 supplicant config to APs
CSCuy20175
Windows clients machine/user auth failing when doing inter-WLC roaming
CSCuy31302
AVC profile on a local policy not removed on re creation of the policy
CSCuy33247
AP send disassociation frames twice and Optimized roaming go wrong
CSCuy4245
FlexConnect ACL allows ACL names with spaces in CLI
CSCuy48983
AIR-CAP2702 radio reset due to Encryption Engine STUCK BZ738[BZ1180].
CSCuy53556
Radius deactivated message should  define  authentication or accounting
CSCuy53775
8.3-Multiple crashes observed on Talwar 5500 WLC with Task: osapiReaper
CSCuy61463
PM4:%AAA-3-CALLED_STATION_ATTRIBUTE_GET_FA: aaa.c:3021
CSCuy63671
Not able to edit mobility group member with edit all option from WEB GUI
CSCuy64520
Access Points (AP) sending CDP packets to the wireless clients
CSCuy73622
Time sync failure for mmMsg_HandoffComplete on MC not printed on debugs
CSCuy73979
WLC dataplane possible crashes
CSCuy75241
5508 system crash with task mmMobility
CSCuy78583
CSCuy83690
BackupController config fails to sync to standby.
CSCuy83951
HA:Config sync failure in mdns profile
CSCuy86428
New mobility: Able to configure same multicast for MC and SPG
CSCuy92693
Flex: ACL returned from AAA is not synced to Standby
CSCuy98783
AP crash: [CAPWAP CLIENT] memcpy(0x17945ec)+0xc source string null
CSCuz02387
Mobility tunnel does not come up after changing the mobility group
CSCuz16883
Address registration issues for mobility scenarios
CSCuz17680
7510 WLC crashed after enabling the enhanced client traps.
CSCuz24121
Bonjour/mDNS incorrectly disabled on 2500 platforms
CSCuz24258
memory leak due to openssl debug infra
CSCuz26426
UI:Adding URL Domain to ACL is throwing error.
CSCuz26463
New mobility:Switch peer group multicast ip address not shown
CSCuz26773
FlexConnect: Split ACLs cannot be pushed to the AP
CSCuz28501
FlexConnect APs fail to join WLC after Fault tolerance
CSCuz28853
Background scanning enabled in 8.0.
CSCuz29259
Traceback is seen when Message queue RLDP-Q  is nearing full
CSCuz33818
profiler:  double free issue
CSCuz40970
8510 anchor WLC Crash on task osapiBsnTimer
Resolved Caveats up to 8.0.134.7:
CSCuo04528        Way to save MSGLOGS/TRAPLOGs in a buffer on the WLC flash when rebooted
CSCup29095        Mesh: PI not showing the neighbor details in mesh links page of Parent
CSCup92480        Xale crash due to PCI reset
CSCuq45110        M1 is sometimes encrypted, leading to M1 refusal on station side
CSCuq89123        WLC: No debugs enabled, but debug invalid module messages in log
CSCur02514         8.0.100.0 : SNMP trap is not sent out on HA switch-over
CSCur17406         AP impersonation appearing for 1530 AP(s)
CSCur53809         AP2702 sometimes unable to receive packets/ACK from STA with 20MHz wide
CSCus06589        2700AP flooding AP sourced packets out of Aux Gig 1
CSCus52828        snmpv3 rw user creds not working if key length >32
CSCus58120        traplog is wrong about Temperature status
CSCus61679        Problem in Client Stats Reports - Follow up CDETS
CSCut10668         ap1570, RADIO_OVER_TEMPERATURE, controller still shows ap radio up
CSCut76824         Anchor WLC will not forward DHCP request to the DHCP server
CSCut91086         Client associated to MAP doesn't get AAA override in Flex+Bridge mode
CSCuu17338        AP 1142 Config loss after cold reboot
CSCuu42378        RX-SOP threshold not working correctly
CSCuu59340        SNR alarms for mesh aps have invalid content, not working as expected
CSCuu83548        Traceback observed in export-foreign standby wlc while disassociat clien
CSCuu91943        8510 WLC crash while accessing the controller crash file info thro GUI
CSCuv40794        Ap Impersonator alarm for AP 3602i
CSCuv99415        AP should bootup even if capwap IOS download was corrupted
CSCuw23023       3700 AP Sniffer Mode not capturing on 5ghz radio with Rx-SOP set
CSCuw30129       Debugging logging quickly falls behind real-time
CSCuw36069       Threshold MIBs incorrectly set for WSSI modules.
CSCuw38795       5508 WLC crash upon pushing RF calibration template from PI
CSCuw65933       Client Stats mismatch in client roaming scenarios
CSCuw81352       Unwanted debug messages : Wired client head is NULL
CSCuw95126       Optimized Roaming Rejection function does not work
CSCux00803        New Mobility clients stuck in DHCP_REQD state with NAT IP on Foreign
CSCux23003        8dBm max power for -Z, -T domain APs in channels 36 through 64
CSCux24575        8.2.15.5 - MAPs are unstable if convergence is standard ...
CSCux32328        Token Bucket leak with QoS Roles and with WebAuth on 8.0.120.2
CSCux34439        11ac clients can not connect to CAP3600 Radio slot2 -- 11ac module
CSCux45077        AP3500 crashed due to "LWAPP CLIENT" process.
CSCux53607        WLC SNMP for cLAPGroups802dot11bgRFProfileName returns wrong value
CSCux60012        With New Mobility - Mobility Members Don't survive reload
CSCux62529        LAP crashes at disc_client_txq_dump
CSCux62936        IPv6 address delete in MSCB failing when client hops between wlans
CSCux63218        Upgrade to 8.0 moved APs to EAP-MD5 authentication on wired dot1x
CSCux63449        WLC 8.0.120.0 Crash on TransferMsgPeerSend
CSCux82955        Anchor WLC not forward DHCP reqest to server as vlan set as 0
CSCux85357        WLC sends GARP for flex local switching clients after HA switch-over
CSCux96731        DP crash on 8500
CSCuy04572        Wrong timestamp sent on rogue traps when delta value set on controller
CSCuy08305        Client deleted because of Intra AP Roam event
CSCuy11885        3500AP crashed by the Pid 128: Process "CAPWAP CLIENT "
CSCuy12943        WLC8.1 : Unknown emWeb error message
CSCuy31962        APs detect different WPA Support value from Rogue AP
CSCuy33247        AP send disassociation frames twice and Optimized roaming go wrong
CSCuy64520        Access Points (AP) sending CDP packets to the wireless clients
CSCuy73979        WLC dataplane possible crashes
CSCuy92693        Flex: ACL returned from AAA is not synced to Standby
CSCuy98783        AP crash loop after upgrade on 8.3 and 8.0mr3
7 Replies 7
harveym31
Community Member
I was told this patch is going to fix the issue where the MSE won't render floor plans when syncing from Prime. Can anyone confirm? I don't see anything listed that mentions this bug.
this beta is focused on WLC side.  To see if there is a related MSE interaction issue, could you unicast to me the bug ID or case number, so I can check ?
Hi Javier,
The case ID is 638517151.
This is what I was told a few months ago "I have been updated from the BU that the bug is supposed to be resolved in the 8.0MR4 release which is due out around June 20th."
Thank you
Kevin McCormick
Frequent Visitor
Frequent Visitor
I see 8.3 was recently released with NBAR2 update.
Support for NBAR2 Protocol Pack 19.1.0
Support is added for NBAR2 Protocol Pack 19.1.0 for Cisco WLCs, which will be the default protocol pack PP for Release 8.3. The AP protocol pack is upgraded to NBAR2 Protocol Pack 14.
Will we be seeing this NBAR2 pack available for download and use on other releases?
Been like a year since there was an update available, and would like to have newer NBAR2 definitions in 8.0 MR4 or 8.2 MR2 release. Either built in or for download.
Thanks.
hi Kevin
let me check with the release manager, there are some dependencies on engine version and testing requirements, so not a direct publish.
I will get the info from the owner, and report back here.
regards
rpillon91
Community Member
Hi Team,
Is there any updated ETA for the 8.0MR4 release ?
hi
we just posted it on CCO last night 🙂
regards
