802.11ac How to increase connection rate up to 1.3 Gbit/s
Mahmoudhbm
Dear all,
I have set up at home Cisco 2702i Series AP. My PC has a Wireless NIC with two Antenna and the model is D-Link which supports ac.
As you can see from the picture, the speed is 54 Mbps, how can i increase it to the maximum with good performance and the benefit from the AP?
Thank you very much.
Below is the out put from the config
ap2702i#sh run
Building configuration...
Current configuration : 2447 bytes
! Last configuration change at 10:25:43 UTC Sat Mar 6 1993
version 15.2
no service pad
service password-encryption
hostname ap2702i
logging rate-limit console 9
enable secret 5 $1$hrL4$YG5E1.WFNYdw3FRcfu/b40
no aaa new-model
no ip cef
ip domain name sybex.ae
dot11 syslog
dot11 ssid GoodLuck
band-select
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 7 082F495A5C4D5242435F5B
dot11 ssid GoodLuck-ac
authentication open
guest-mode
wpa-psk ascii 7 011D03100E5F515A701819
dot11 guest
username Cisco password 7 0802455D0A16
username mahmoudmdce privilege 15 secret 5 $1$wuVw$TMbx/Xm0EnnQyDlv4LFYL0
ip ssh version 2
bridge irb
interface Dot11Radio0
no ip address
encryption mode ciphers aes-ccm
ssid GoodLuck
antenna gain 0
stbc
channel least-congested 2412 2437 2462
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
encryption mode ciphers tkip
ssid GoodLuck-ac
antenna gain 0
peakdetect
dfs band 3 block
stbc
channel width 80
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
duplex auto
speed auto
bridge-group 1
interface GigabitEthernet1
no ip address
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.7.7 255.255.255.0
ipv6 address dhcp
ipv6 address autoconfig
ipv6 enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
exec-timeout 0 0
password 7 111A0007120A5E5D507D
logging synchronous
line vty 0 4
logging synchronous
login local
transport input ssh
line vty 5 15
logging synchronous
login local
transport input ssh
end
Leo Laohoo
"support" 802.11ac and "can do" 802.11ac are two very, very different things.
You'll need to find (good luck!) a wireless client that can really do 802.11ac to be able to see 900 Mbps.
With 802.11ac wave 1, the real speed is approximately 900 Mbps.
patoberli
Besides needing a client that supports 802.11ac (with 4x4:4 or at least 3x3:3), you need to enable 80 MHz channel on the 5 GHz interface on the AP (which you have done).
Which is the exact make and model of the Wireless card in your client?
Disable the 2.4 GHz interface on the AP for testing, that way you make sure that your client only connects to 5 GHz.
Also make sure this is enabled:
dot11 qos mode wmm
Might already be enabled in default configuration (and thus hidden).
