09-07-2013 02:32 AM - edited 07-04-2021 12:47 AM
We have just gone live with our wireless refresh, using a Cisco 5508 (v7.5) and Cisco 3602i's with the 802.11ac module.
I am having some issues trying to get the AC modules to come up. The AP's are powered by a PoE 3750 switch, which is only capable of producing 15.4w of power per port, so I appreciate that the AC module will not work in conjunction with the 2.4-GHz radio. I have tried Google and these forums, but this is a new technology and unfortunately there is not a great deal of documentation available yet.
802.11ac high throughput is enabled, and the channel width is set to 80MHz. WMM policy is also enabled.
I've disabled the radio and the different networks, and still cannot get to the desired scenario where the AC module is working.
Does anyone have any ideas as to what I could try next?
Thank you all in advance.
Alex
Solved! Go to Solution.
09-07-2013 07:00 AM
Yes, if you do not have an 802.3at or enhanced PoE switch or power brick then you would need to disable the 2.4 GHz radio then reboot the AP to renegotiate power requirements.
Then ensure you can enable the 11n radio (slot 2).
Also ensure you are using an SSID utilizing WPA2.
09-07-2013 07:00 AM
09-07-2013 08:12 AM
Thank you - that worked perfectly.
I could not find any documentation that said to reboot it. Thank you again for your swift response!
