802.11n antenna spacing
dgausepohl
I am still looking an answer for the antenna spacing when using 802.11n. When using a 1252 the antennas are marked A,B, and C. My question is what is the maximum distant between antenna A and C? Would it be 20 or 40 inches?
Don
Roman Rodichev
Level 7
Level 7
Minimum distance between left and right antennas should be around 5" and maximum should be around 20". The middle antenna should be in the middle.
Is this for indoor only?  I think it would be hard to mount 3 sector antennas within 20" of each other.
