11-24-2016 12:01 PM - edited 07-05-2021 06:09 AM
Is it possible that a 802.11n client to join to a 802.11ac AP configured with 80/160Mhz channels?
If yes, what is the behavior of the legacy client?
11-24-2016 12:03 PM
Not remotely possible.
11-24-2016 12:21 PM
Devices should be able to connect 802.11n even when you use 80/160 as the device will only use 20/40. Don't know why you would use 80/160 because it uses up your channels and your devices need to support 80/160. Stick to 20/40 so you have more overlapping channels and your RF would be cleaner.
-Scott
11-24-2016 12:44 PM
My question is theoretical. I haven't tested it but I found some materials that state that a 802.11n clients are not able to connect to 80mhz at APs.
11-24-2016 12:47 PM
I have 80mhz running on my AP's at home and don't have issue with any 802.11n devices connecting to the 5ghz.
-Scott
11-24-2016 01:58 PM
Keep in mind that 802.11ac is backward compatible with 802.11n. I have even tried 160mhz just to test and I still had 802.11n clients connect on the 5ghz. Again, I wouldn't use 80/160 in production.
Good luck!
-Scott
