802.1x flexconnect wlan issues
dmbnex
Hi All.
We have this strange wifi issue with 802.1x-flexconnect(switch vlan breakout) on vwlc(and wlc 5520) and 2802i
everything looks fine, authentication works fine.
APs er registered in controller and work fine
but often client looses network access, internet stops working, sometime it looses authentication alltogether and connection drops. then the client need to forget ssid and reauthenticate but sometime it just takes time and connection comes back..
this often happens when roaming and more often when roaming between floors(signal leaks through)
this is confirmed with both mac, windows and android client devices.
there is no particular timeframe when the issue occures and it happens at different times for different users/devices.
"LOCAL" tunnel works fine all the time.
vWLC/AP code 8.5.140
STAR LAN infrastructure:
DELL as "core"
cisco as access towards APs
dot1x auth is a AP->NPS->NPS/Active Directory
we have reset all APs to default and check all setup without finding anyting.
any help on how to troubleshoot this would be helpfull
patoberli
On the WLC enter:
debug client heretheclientsmacaddress
And then walk around with the client while the debug is running. If the problem appears again, please post the result of the debug here.
 - Or use the wireless debug analyzer which can be found on this page :
                https://developer.cisco.com/docs/wireless-troubleshooting-tools/
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
