802.1x with wireless - pls help :(
marek_max
I am trying to configure 802.1x on my wireless router (877) but no luck. Here is a part of my config. Radius is on Small Business Server 2008
aaa new-model
aaa group server radius rad_eap
server 172.16.1.x auth-port 1812 acct-port 1813
aaa group server radius rad_acct
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
dot11 ssid xxxx
   vlan x
   authentication open eap eap_methods
   authentication network-eap eap_methods
   authentication key-management wpa'
   mbssid guest-mode
radius-server host 172.16.1.x auth-port 1812 acct-port 1813 key xxxx
With this config above I go to my laptop and try to connect like to a normal wiif, I can see username/pass box. I type and it fails. But at least the router tries to go to Radius (I can see a lot of debug messages). On Radius it fails with 'IAS INVALID AUTH'. probably because the card is not set up with 802.1x
When I remove the line 'authentication key-management wpa' I am able to configure my wirless card with 802.1x but when I try to connect, my router does not contact with Radius at all (I know it as I turned on debug for radius and dot1x)
Surendra BG
Here is the configuration example link which gived step by step procedure to complete the task.. please follow the same and let me know if this helps!!
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080608364.shtml
Please dont forget to rate the usefull posts!!
Surendra
Surendra BG
