819HW, external and separate 2.4GHz and 5GHz
norberto.padin
Hello team, is it possible to have separate antennas for 2.4GHZ and for 5GHz in the 819HW?
As far as I can see, the RP-TNC connectors are dual band, so, it is not possible to use the AIR-ANT2440NV-R and the AIR-ANT5140NV-R simultaneously, is that correct?
How can this be solved?
The main idea is the 819HW be a 5GHz UWGB client of a WiFi mesh network and provide 2.4GHz services inside the truck.
Nor.
norberto.padin
I saw that exists the following antennas for the IR829: ANT-2-WLAN-D-O and ANT-5-4G2WL2G1-O. I think that using this antennas can do the trick even those Cisco antennas doesn't figure in the ISR819HW data sheet.
Am I right?
Nor.
