I understand there are two ways to prioritize traffic via wireless; by AVC and the Lync SDN API.
My questions are:
1. Do you use AVC or the Lync SDN API to prioritize traffic? Are they mutually exclusive or do you use them as an overall combined solution?
2. If you use the Lync SDN API running on the front end LYNC server, does the server have to be onsite with the WLC or can there be a central Lync Sever located across a WAN in a data center serving multiple WLCs?
My current infrastructure includes 22 sites, with a primary WLC onsite (2504/5508s) and a backup WLC (5508)/Lync Server in the central datacenter.
