871 wireless setup
frankm
Community Member
I am trying to get an 871 soho router wireless connections to work.
The SDM is useless.
I have tried to find docs on how and why and what to do - but no luck.
Been at the this for a week. Got the DSL and fw parts working, but not
wireless.
I have a Authentication Open setup - guest-mode enabled.
So I should be pretty wide open for connections.
I can see the SSID on a client PC, but cannot connect.
I'm running DHCP to clients
config below
bridge irb
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dot11Radio0
no ip address
ssid 1138
vlan 1
authentication open
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0
48.0 54.0
station-role root
no cdp enable
bridge-group 1
bridge-group 1 spanning-disabled
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
ip address 192.168.0.109 255.255.255.0
ip access-group 102 in
ip nat inside
ip virtual-reassembly
interface Dialer1
description $FW_OUTSIDE$
mtu 1492
ip address negotiated
ip access-group 103 in
ip inspect DEFAULT100 out
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username [email protected] password xxx
ppp ipcp dns request accept
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
logging trap debugging
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 100 remark auto-generated by Cisco SDM Express firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto-generated by Cisco SDM Express firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 deny ip 192.168.0.0 0.0.0.255 any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any
access-list 102 remark auto generated by SDM firewall configuration
access-list 102 remark SDM_ACL Category=1
access-list 102 deny ip host 255.255.255.255 any
access-list 102 deny ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration
access-list 103 remark SDM_ACL Category=1
access-list 103 deny ip 192.168.0.0 0.0.0.255 any
access-list 103 permit icmp any any echo-reply
access-list 103 permit icmp any any time-exceeded
access-list 103 permit icmp any any unreachable
access-list 103 deny ip 10.0.0.0 0.255.255.255 any
access-list 103 deny ip 172.16.0.0 0.15.255.255 any
access-list 103 deny ip 192.168.0.0 0.0.255.255 any
access-list 103 deny ip 127.0.0.0 0.255.255.255 any
access-list 103 deny ip host 255.255.255.255 any
access-list 103 deny ip host 0.0.0.0 any
access-list 103 deny ip any any log
dialer-list 1 protocol ip permit
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Stephen Rodriguez
no ip address
ssid 1138
no vlan 1
interface Vlan1
no ip address 192.168.0.109 255.255.255.0
no ip nat inside
bridge-group 1
interface BVI 1
ip nat inside
end
Cut these commands in. I'll assume that if you are doing DHCP from a server and not the router. If you wish to use the router, you'll need to configure a DHCP pool.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
15 Replies 15
a.hajhamad
Level 7
Level 7
The following commands will config wireless access using pre-shared key:
no ip address
encryption mode ciphers tkip // Encryption mode for WPA since WPA2 is not supported at Cisco 800 integrated routers
ssid Free // SSID name
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 Cisco123 // the pre-shared Key that will be used for users whom connect using wireless
I hope to be helpful!
Please rate if it does!
Abd Alqader
Thanks, I'll keep this for when I get to the security part. Right now I am just trying to get a wireless client connected. That's why I left the encryption / auth open, so I can start simple and once I get the connectivity working, I can add things. I can see the ssid broadcast but cannot connect.
No BVI interface?
What the client wireless adapter?
Two different machines - one is a usr pcmcia on a dell (winXP) and the other is a broadcom internal on a compaq (winXP)
I have the same problem with connectivity. I can see SSID, but unable to get ip address from DHCP pool.
I think ??? it has something with the bridge-group and the bvi. But I can't get ANY descriptions of what does what and fits where. It seesm that the BVI allows communication between routed (wan) and bridged (internal) topologies. The problem is: what to plug in and where and what else do I hose.
frankm
Community Member
Yep - no BVI - whatever that is. It was there when I called cisco tech support and was gone after he got out. I am finding VERY little info on how to configure this device. I can navigate the cli, but the pieces are greek to me. I see a lot of articles showing the config - but not what should be done and why.
i think, if you move the commands from your vlan 1 interface, and put them in a bvi interface, that should take care of it. just do this from the config prompt.
int bvi1
(then just take the commands off of interface vlan 1 and put them in bvi1)
I beleive you should use BVI interface, you should put DotRadio0 interface and vlan1 interface into bridge-group1 and remove the IP and NAT configurations from vlan 1 to bvi interface. Hope the following configuraiton example helps:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/85x87x/857swcg/eng/pt2/wireless.htm
Stephen Rodriguez
no ip address
ssid 1138
no vlan 1
interface Vlan1
no ip nat inside
bridge-group 1
interface BVI 1
ip nat inside
end
HTH,
Steve
WOO HOO !!!!!!!!!!!
Thanks to everyone for your help. I have pppoe connection, dns resolution, wireless connectivity, wired lan connectivity and encryption flying. Kinda like pulling teeth from a duck, but works. My last thing is mac filtering, but that should relatively easy.
Hey - again thanks. The config in the replied-to post got me almost all the way there.
Remember - for every item that you learn - it exposes 5 more things you didn't know that you didn't know. Therefore I am getting more and more incompetent.
You could also just give the radio interface its own IP address and make it a routed subnet. Skip the bvi config entirely. Just make sure to create an appropriate DHCP scope for it, and add subnet to any NAT rules or ACLS. The benefit here is that, among a lot of other things, you could apply QoS differently for wireless, different ACLs, and could even (depending on your setup) create a 'guest' SSID that routes directly out to the Internet.
description wireless internal net
ip address 192.168.2.1 255.255.255.0
! ip helper will forward DHCP broadcasts from
! the wireless subnet to a server on the wired subnet
! not necessary if using IOS DHCPD
ip helper-address 192.168.1.2
ip nat inside
ssid private
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description wired internal network
ip nat inside
vpn#show ip route connected
200.100.17.0..0/30 is subnetted, 1 subnets
C 200.100.17.16 is directly connected, FastEthernet4
C 192.168.1.0/24 is directly connected, Vlan1
C 192.168.2.0/24 is directly connected, Dot11Radio0
192.168.3.0/32 is subnetted, 1 subnets
C 192.168.3.1 is directly connected, Loopback1
mirosmanali
Community Member
I hope this may help you, note that in this scenario the DHCP was configured from the server, if your setup is not the same then you have to define the DHCP scope on the AP.
Current configuration : 1823 bytes
version 12.3
no service pad
service password-encryption
hostname AP_NAME
enable secret xxx
ip subnet-zero
ip domain name somecompany.com.sa
ip name-server [DNS Primary IP]
ip name-server [DNS Secondary IP]
no aaa new-model
dot11 ssid CORE_AP_HG4_01
vlan 2
authentication open
guest-mode
username Cisco password xxxxxxxx
bridge irb
bandwidth 55296
no ip address
no ip route-cache
encryption vlan 2 key 1 size 40bit xxx transmit-key
encryption vlan 2 mode wep mandatory
ssid AP_ITDPT
54.0
station-role root
interface Dot11Radio0.2
encapsulation dot1Q 2 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.2
no ip route-cache
bridge-group 1
interface BVI1
ip address 10.80.12.224 255.255.255.0
no ip route-cache
ip default-gateway 10.10.10.115 {Cisco Switch IP Address}
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
transport preferred all
transport output all
line vty 0 4
login local
transport input all
line vty 5 15
login
transport input all
end
Best of Luck
