871 wireless setup
frankm
Community Member
I am trying to get an 871 soho router wireless connections to work.
The SDM is useless.
I have tried to find docs on how and why and what to do - but no luck.
Been at the this for a week. Got the DSL and fw parts working, but not
wireless.
I have a Authentication Open setup - guest-mode enabled.
So I should be pretty wide open for connections.
I can see the SSID on a client PC, but cannot connect.
I'm running DHCP to clients
config below
bridge irb
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dot11Radio0
no ip address
ssid 1138
vlan 1
authentication open
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0
48.0 54.0
station-role root
no cdp enable
bridge-group 1
bridge-group 1 spanning-disabled
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
ip address 192.168.0.109 255.255.255.0
ip access-group 102 in
ip nat inside
ip virtual-reassembly
interface Dialer1
description $FW_OUTSIDE$
mtu 1492
ip address negotiated
ip access-group 103 in
ip inspect DEFAULT100 out
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username [email protected] password xxx
ppp ipcp dns request accept
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
logging trap debugging
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 100 remark auto-generated by Cisco SDM Express firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto-generated by Cisco SDM Express firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 deny ip 192.168.0.0 0.0.0.255 any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any
access-list 102 remark auto generated by SDM firewall configuration
access-list 102 remark SDM_ACL Category=1
access-list 102 deny ip host 255.255.255.255 any
access-list 102 deny ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration
access-list 103 remark SDM_ACL Category=1
access-list 103 deny ip 192.168.0.0 0.0.0.255 any
access-list 103 permit icmp any any echo-reply
access-list 103 permit icmp any any time-exceeded
access-list 103 permit icmp any any unreachable
access-list 103 deny ip 10.0.0.0 0.255.255.255 any
access-list 103 deny ip 172.16.0.0 0.15.255.255 any
access-list 103 deny ip 192.168.0.0 0.0.255.255 any
access-list 103 deny ip 127.0.0.0 0.255.255.255 any
access-list 103 deny ip host 255.255.255.255 any
access-list 103 deny ip host 0.0.0.0 any
access-list 103 deny ip any any log
dialer-list 1 protocol ip permit
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
15 Replies 15
Just want to add my working version to the pool. What's posted here did not work for me, but the thread was very helpful.
Also helpful was this link:
http://www.velocityreviews.com/forums/t295238-cisco-871-wireless-setup-questions.html
Mine is a 877 Wireless with Adv Security - only 1 VLAN allowed.
hostname
boot-start-marker
boot system flash:/c870-advsecurityk9-mz.124-4.T7.bin
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address
ip dhcp pool
network
dns-server
default-router
no ip domain lookup
ip domain name
bridge irb
interface ATM0
no ip address
no ip mroute-cache
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
switchport mode trunk
speed 100
interface FastEthernet1
speed 100
interface FastEthernet2
speed 100
interface FastEthernet3
speed 100
no ip address
no ip route-cache cef
no ip route-cache
encryption vlan 1 mode ciphers tkip
ssid
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
no snmp trap link-status
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
no ip redirects
no ip proxy-arp
ip route-cache flow
bridge-group 1
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname
ppp chap password
interface Dialer0
no ip address
no cdp enable
interface BVI1
ip address INSIDE DATA LAN ADDRESS
no ip redirects
no ip proxy-arp
ip nat inside
ip classless
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map RMAP_1 interface Dialer1 overload
no cdp run
route-map RMAP_1 permit 1
match ip address NONAT
control-plane
bridge 1 route ip
