881W not giving DHCP address to vlan 2 wireless
nate fitzgerald
Hi I have a cisco 881w with the following config on the wireless and wired, I can get a dhcp address on the wire on vlan 1 and get out but the vlan 2 should be handing out 172.16.31.x addresses to the wireless and is not any help would be great
ROUTER/WIRED CONFIG is attached
and WIRELESS/AP config is attached
nate fitzgerald
ALSO I AM NOT SURE HOW TO PASTE THE SCRIPT ON THIS SITE I ONLY COULD UPLOAD IT, LET ME KNOW THANKS
under the dhcp exclusions, remove the
ip dhcp excluded-address 172.16.31.0
it should read ip dhcp excluded-address 172.16.31.1.  You shouldn't need to exclude theip dhcp excluded-address 172.16.31.255 as this is the broadcast adn shodln't be given out.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
