9105axw-b EWC Conversion
PatrickMorgan
TL/DR:
9105axw-b
Problem 1 – How do I make space?
Problem 2 – Am I copying the file correctly?
I received a Catalyst 9105axw-b intending to use the 9800 Embedded Wireless Controller.   After reading several documents and watching the 9100 series videos, I was confident that I could convert the device.  Most of the documentation is aimed towards the other 9100 series devices and have directions with unacceptable commands, like config t.
I am having a difficult time getting the access point to allow me to tftp the IOS bin file.  Below is part of the show version output:
cisco C9105AXW-B ARMv7 Processor rev 5 (v7l) with 950528/456128K bytes of memory.
Processor board ID FGL2442L8DD
AP Running Image     : 8.10.130.0
Primary Boot Image   : 8.10.130.0
Backup Boot Image    : 8.10.130.0
Primary Boot Image Hash:
Backup  Boot Image Hash:
4 Multigigabit Ethernet interfaces
2 802.11 Radios
Radio Driver version : Broadcom BCA: 17.18 RC2.0
Radio FW version : 24203.103.r40354 0
NSS FW version : NA
Base ethernet MAC Address
Part Number                          : 0-000000-00
PCA Assembly Number                  : 074-123371-01
PCA Revision Number                  : 01
PCB Serial Number                    :
Top Assembly Part Number             : 074-123371-01
Top Assembly Serial Number           :
Top Revision Number                  : A0
Product/Model Number                 : C9105AXW-B
I have attempted several methods.  copy source dest doesn’t work in this IOS.-
  1. ap-type mobility-express tftp://192.168.1.245/9105/ap1g8 tftp://192.168.1.245/9105/C9800-AP-iosxe-wlc.bin
    This outputs a long string of blank lines with sporadic hyphen characters followed by invalid input detected.
  1. ap-type mobility-express tftp://192.168.1.245/9105/C9800-AP-iosxe-wlc.bin
    Output:
    39.9%
    curl: (23) Error
    transfer command failed (Error 23)
  2. archive download-sw /no-reload tftp://192.168.1.245/9105/C9800-AP-iosxe-wlc.bin
    Output:
    39.9%
    curl: (23) Error
    Image transfer failed
  3. Attempted u-boot xmodem with baud of 38400 ---- took too long
I am making an assumption that the device is running out of space.  I cannot seem to find the commands to delete, as it is handcuffed to what can be deleted and I am having trouble viewing the files.  Clearly my /tmp is 100% full (fixes with reload).  But I would like to have enough space to download and use the image.
show filesystems
Filesystem                Size      Used Available Use% Mounted on
devtmpfs                462.4M      4.0K    462.4M   0% /dev
/sysroot                                464.1M    129.8M    334.3M  28% /
tmpfs                     1.0M     44.0K    980.0K   4% /dev/shm
tmpfs                   464.1M         0    464.1M   0% /run
tmpfs                   464.1M         0    464.1M   0% /sys/fs/cgroup
/dev/ubivol/part1       171.3M     54.5M    116.7M  32% /part1
/dev/ubivol/part2       258.9M     56.1M    202.8M  22% /part2
none                    100.0M    100.0M     48.0K 100% /tmp
none                     10.0M         0     10.0M   0% /firmwarelog
none                      1.0M     44.0K    980.0K   4% /dev/shm
Any assistance would be welcome.
30 Replies 30
EvanC75
Be sure you connect to the terminal with the baud rate set to 1150200 instead of 9600 if using the newer firmware images.  Otherwise the garbled mess below appears.  I had thought I bricked the AP until I found this on another topic.
Regards.
