9120EWC and Acksys Airlink V2
renaudlamy9276
here for a problem with new customer infrastructure using AP9120EWC, all is Ok except a Acksys Airlink V2 client, this module give the network to a wired equipment, the two have it owne IP adress, the Acksys is connected to the Cisco Wifi Wlan and it ping normaly, but the equipement behind wired by ethernet cable it not view by the network, so is it have some special configuration for that to enable or disable for working ? Acksys is here like a bridge to connect a ARJ45 device to the Wifi network, this issue is since the replacement of the infrastucture with 9120 Cisco, beefore that customer used old CIsco 2600 serie and it worked fine with it, so mabee it have a protocol issue or someting to enable to work with the new infrastrucuture, so if someone have a idea let me know.
Many thanks.
2 Accepted Solutions
docjb0221
You might need to enable passive client in the WLAN on the 9800 for this. I've had to do that in the past.
Rich R
Yep I was also going to suggest to consider passive client:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-9/config-guide/b_wl_17_9_cg/m_passive_client.html
marce1000
 - Try to disable/enable  (meaning check/test  the options)  P2P blocking according to this document : https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/16-12/config-guide/b_wl_16_12_cg/peer-to-peer-client-support.html
 M.
docjb0221
Rich R
renaudlamy9276
Enable passive client solve the issue, many thanks to all.
