9130AX will not save pre-stage configuration
We have a batch of 9130AX's that will not save the pre stage configuration, no invalids are seen on the CLI.
Adding hostname does not change the device from MAC to given hostname and when sh cap cli conf is applied control names and IP's are missing even though they were applied with no invalids.
There appears to be 2 differences between the batch that work and the one that doesn't and they are the images 17.12.3 and 17.9.4.27 and on the packaging the is a small barcode with Rev.H0 on one and Rev.J0
Any thoughts please?
21 Replies 21
Scott Fella
Can you provide more information, do you have a controller or are you using EWC? Make sure your image matches if you are using EWC or not.  Also, its easier to create a CLI script using the mac or SN to configure the hostname once the ap has joined the controller.  You don't have to pre-stage this at all, just make sure the ap is able to join the controller.
You can run the show version on the two types of images you have, just to confirm if it has an EWC image.  In case you do and need to convert, take a look at this link.
https://www.cisco.com/c/en/us/support/docs/wireless/embedded-wireless-controller-on-catalyst-access-points/215303-embedded-wireless-controller-conversion.html#toc-hId-1622399608
-Scott
Mark Elsen
            - For the ones that don't work ==>  post the complete boot process of the AP ,
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Using the ap-type command has made no difference.
The AP will be on a controller when  deployed to site but when performing this task it is on the bench powered by a stand alone C9300X, I apply hostname, primary and secondary controller name and IP's, the hostname is required as the controller uses regex to find our templated hostname.
I have been doing these for approx 5 years (first the 3702 then 3802/4800 and now the 9000 series) and have not come across this issue before.
Please see below as requested.
Thank you.
VHTDynBWRes : 0
VHTSounding : 0
VHTGroupId : 0
Flash Commit : 1
VHT Capability
VHT Capability Info : 865069494
VHT MCS Rates : 0 0 0 0 0 0 0 255
HE Capable : true
HE Info
HE SuBFCapable : 1
HE MuBFCapable : 1
HE MbssidCapable : 0
HE AmpduTidBmap : 0
HE BSS_COLOR_DISABLED : 0
HE PARTIAL_BSS_COLOR : 0
HE BSS_Color : 1
HE DEFAULT_PE_DUR : 4
HE RTS_THRESHOLD : 1023
HE VHT_OPINFO_PRESENT : 0
HE CO_LOCATED_BSS : 0
HE ER_SU_DISABLE : 0
HE 80_80_CHANNEL_SUPPORT : 0
HE MCS Rates : AA FF AA FF AA FF AA FF AA FF AA FF
BSS Color Capable : Yes
Global BSS Color Config : Enabled
Configured BSS Color : 1
BSS Color Config Type : Automatic
OBSS PD Capable : Yes
OBSS PD Config : Disabled
Non-SRG OBSS PD Max : Not Yet Configured
SRG Capable : No
HE TWT Capable : Yes
HE TWT Config : Disabled
HE TWT Broadcast Support : Disabled
AP8C1E.8042.5104#
AP8C1E.8042.5104#
AP8C1E.8042.5104#
AP8C1E.8042.5104#
AP8C1E.8042.5104#
AP8C1E.8042.5104#
AP8C1E.8042.5104#
AP8C1E.8042.5104#
AP8C1E.8042.5104#[*05/19/2024 17:34:13.0449] chatter: Device wired0 notify down link UP
[*05/19/2024 17:34:13.0455] chatter: Device wired0 notify down link DOWN
[*05/19/2024 17:34:15.0549] chatter: Device wired0 notify up link DOWN
[*05/19/2024 17:34:18.6330] chatter: Device wired0 notify state change link UP
AP8C1E.8042.5104#
AP8C1E.8042.5104#
AP8C1E.8042.5104#
AP8C1E.8042.5104#
AP8C1E.8042.5104#reload
Proceed with reload? [confirm]
cli: AP Rebooting: CLI triggered reboot(reload command)
Stopping Cisco Power Daemon...
Stopping DHCPv6 client...
[ OK ] Stopped [ OK ] Stopped Security Auditing Service.
[ OK ] Stopped NTP_PROC daemon.
[ OK ] Stopped Cisco led service.
[ OK ] Stopped Serial Getty on ttyS0.
[ OK ] Stopped NSS Firmware Monitor daemon.
[ OK ] Stopped RHL monitor/reset daemon.
[ OK ] Stopped System Monitor service.
[ OK ] Stopped OpenSSH server daemon.
[ OK ] Stopped Cisco rtd service.
[ OK ] Stopped Hostapd process.
[ OK ] Stopped AP Trace daemon.
[ OK ] Stopped Fast CGI daemon.
[ OK ] Stopped Sensord daemon.
[ OK ] Stopped Cisco Power Daemon.
[ OK ] Stopped capwapd.
[ OK ] Stopped DNSmasq.
[ OK ] Stopped Clean Air daemon.
[ OK ] Stopped DHCPv6 client.
[ OK ] Stopped gRPC server daemon.
[ OK ] Stopped Cisco printkd.
[ OK ] Stopped Cisco klogd.
Stopping WCPD process...
Stopping Cisco brain service...
[ OK ] Stopped target sshd-keygen.target.
[ OK ] Removed slice system-serial\x2dgetty.slice.
[ OK ] Stopped Cisco brain service.
[ OK ] Stopped WCPD process.
[ OK ] Stopped target Basic System.
[ OK ] Stopped target Sockets.
[ OK ] Stopped target Slices.
[ OK ] Stopped target Paths.
[ OK ] Stopped target System Initialization.
[ OK ] Stopped Cisco sysctl service.
Stopping Cisco sysctl service...
[ OK ] Stopped Cisco ME service.
Stopping Cisco ME service...
Stopping Cisco synclogd...
[ OK ] Stopped Cisco Sku service.
Stopping Cisco Sku service...
Stopping Cisco pre-PoE negotiation...
Stopping RHL daemon...
[*05/19/2024 17:34:35.2790] wlan: [12896:D:dfs] WLAN_DEBUG_DFS : csc_wlan_dfs_sinfo_notify_handler_cb: Cisco DFS module Not available.
Stopping rsyslog client...
Stopping Cisco watchdog...
Stopping Cisco system time saving...
[*05/19/2024 17:34:35.5796]
[*05/19/2024 17:34:35.5796] Writing reload timestamp (Sun May 19 17:34:35 UTC 2024) to disk
[ OK ] Stopped Cisco Tam service.
Stopping Cisco Tam service...
[ OK ] Stopped Cisco certtime service.
Stopping Cisco certtime service...
Stopping Tam server...
[ OK ] Stopped Cisco watchdog.
[ OK ] Stopped Cisco pre-PoE negotiation.
[ OK ] Stopped rsyslog client.
[ OK ] Stopped Tam server.
[ OK ] Stopped Cisco synclogd.
[ OK ] Stopped RHL daemon.
[ OK ] Stopped Cisco system time saving.
[ OK ] Stopped Cisco FIPS QCA radio POST.
Stopping Cisco FIPS QCA radio POST...
[ OK ] Stopped Cisco S16platfomm.
Stopping Cisco S16platfomm...
Stopping qrtr service...
Stopping Cisco syslog service...
[ OK ] Stopped Cisco act2 check.
Stopping Cisco act2 check...
[ OK ] Stopped Cisco certificate create service.
Stopping Cisco certificate create service...
Stopping Cisco nolan USB service...
[ OK ] Stopped qrtr service.
[ OK ] Stopped Cisco syslog service.
[ OK ] Stopped Cisco nolan USB service.
Stopping Cisco nolan service...
[ OK ] Stopped Cisco Kclick.
Stopping Cisco Kclick...
[ OK ] Stopped Cisco S15platform.
Stopping Cisco S15platform...
[ OK ] Stopped Cisco nss service.
Stopping Cisco nss service...
[ OK ] Stopped Cisco pkg install service.
Stopping Cisco pkg install service...
[ OK ] Stopped Cisco nolan service.
[ OK ] Stopped Cisco S10 boot service.
Stopping Cisco S10 boot service...
[ OK ] Stopped target Local File Systems.
Unmounting /part2...
[*05/19/2024 17:34:36.0230] 2024-05-19 17:34:36 TAMS: [ERR] TAMS terminating due to signal 15 (Terminated)
[*05/19/2024 17:34:36.0233] 2024-05-19 17:34:36 TAMS: [ERR] select errno=4 - Interrupted system call
[ OK ] Stopped Cisco system time setup.
Stopping Cisco system time setup...
[ OK ] Stopped Cisco platform file generation.
Stopping Cisco platform file generation...
Unmounting /click...
Unmounting /pstore...
[ OK ] Stopped Cisco fips check.
Stopping Cisco fips check...
Unmounting /tmp...
[ OK ] Stopped Cisco seed generation.
Stopping Cisco seed generation...
Unmounting /sys/kernel/debug...
Unmounting /part1...
[ OK ] Unmounted /part2.
[ OK ] Unmounted /click.
[ OK ] Unmounted /pstore.
[ OK ] Unmounted /tmp.
[ OK ] Unmounted /sys/kernel/debug.
[ OK ] Unmounted /part1.
[ OK ] Reached target Unmount All Filesystems.
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped Cisco early mount.
Stopping Cisco early mount...
[ OK ] Stopped target Cisco File Systems (Pre).
[ OK ] Stopped Cisco UBIFS reformat/mount.
Stopping Cisco UBIFS reformat/mount...
[ OK ] Removed slice system.slice.
[ OK ] Removed slice -.slice.
[ OK ] Reached target Shutdown.
[05/19/2024 17:34:40.4099] qcom wdt: Set timeout to 30 seconds
[05/19/2024 17:34:40.4399] reboot: Restarting system
+w▒{▒▒▒M▒o▒n▒K▒▒▒▒W-w▒B▒▒!▒-?{▒N▒▒▒▒g▒▒▒▒c▒:▒▒Sw▒▒▒y▒▒Ͽ▒)rk/▒▒▒▒u▒z▒{▒/▒▒+▒▒ί▒▒n'o▒▒R^▒▒VsV׾▒▒s!▒▒▒R'▒▒▒)▒▒!▒▒▒▒▒Vg▒/▒n)▒▒o▒ͣ}▒{▒▒▒ok▒▒
Board type: C9130AX
U-Boot REL 2016.01 (btldr release 304) (Jun 22 2023 - 16:02:53 -0700)
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
DRAM: 2 GiB
Nand: Detected ONFI Micron TH58NYG3S0H 8G 1.8V 8-bit
qpic_nand: changing oobsize to 160 from 224 bytes
SF: Detected MX25U6435F with page size 256 Bytes, erase size 4 KiB, total 8 MiB
Scanning shenv data blocks
Total valid parts=4
Active shenv part[0:1], write_counter=28
MFG data loaded
PCI Link Intialized
In: serial@78B3000
Out: serial@78B3000
Err: serial@78B3000
machid: 8010001
SKU: Axel-I BID detected...
i2c_0 chip addresses: 30 48 70
Net: MAC0 addr:8c:1e:80:42:51:4
<DBG> Read AQR: phy_id=4, ID=0xffffffff, phy_addr=8
<DBG> Read AQR: phy_id=5, ID=0x31c31c23, phy_addr=0
PHY ID: 0x31c31c23... Found AQR114C B1 PHY.
Loaded 7 5 PHY firmware from flash
CRC check good on phy fw file (0x66D4)
PHYFW:Loading IRAM...........done.
PHYFW:Loading DRAM..............done.
phy fw image load good CRC-167 matches (0xF5A5)
PHY FW version 05.06.07
PHY ID1: 0x31c3
PHY ID2: 0x1c23
EDMA ver 1 hw init
eth0
Auto boot mode, use bootipq directly
APPS power cycled and restart reason is 0x10
Hit ESC key to stop autoboot: 0
WARNING: Bad preferred boot part2
Switching to alternate boot part1
Writing to Nand...
Erasing block 0x768000
Erasing at 0x76f000 -- 100% complete.
done
Specified BOOT: part1
ubi0: attaching mtd2
ubi0: scanning is finished
| part1: 1650 PEBs|
| part2: 2300 PEBs|
ubi0: attached mtd2 (name "mtd=0", size 1024 MiB)
ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 4096
ubi0: VID header offset: 4096 (aligned 4096), data offset: 8192
ubi0: good PEBs: 4096, bad PEBs: 0, corrupted PEBs: 0
ubi0: user volume: 2, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 3/1, WL threshold: 4096, image sequence number: 545420860
ubi0: available PEBs: 62, total reserved PEBs: 4034, PEBs reserved for bad PEB handling: 80
Booting from part1
Loading file 'part1/part.bin' to addr 0x54000000...
Done
Signature returns 0
Image signing verification success, continue to run...
Preferred boot heartbeat count: 1
Writing to Nand... done
## Loading kernel from FIT Image at 54000400 ...
Using 'C9130_config@0' configuration
Trying 'kernel@0' kernel subimage
Description: linux-qca-4.4-6e
Created: 2023-07-11 7:57:57 UTC
Type: Kernel Image
Compression: lzma compressed
Data Start: 0x540004c0
Data Size: 3420803 Bytes = 3.3 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x41080000
Entry Point: 0x41080000
Verifying Hash Integrity ... OK
## Loading ramdisk from FIT Image at 54000400 ...
Trying 'ramdisk@0' ramdisk subimage
Description: initramfs
Type: RAMDisk Image
Data Start: 0x543437ec
Data Size: 3779308 Bytes = 3.6 MiB
OS: Linux
Load Address: unavailable
Entry Point: unavailable
## Loading fdt from FIT Image at 54000400 ...
Trying 'fdt@0' fdt subimage
Description: C9130 fdt
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x546de35c
Data Size: 82372 Bytes = 80.4 KiB
Loading fdt from 0x546de35c to 0x4a3a7000
Booting using the fdt blob at 0x4a3a7000
Uncompressing Kernel Image ... OK
Loading Ramdisk to 49f65000, end 4a2ffaec ... OK
Loading Device Tree to 4a3a7000, end 4a3be1c3 ... OK
Using machid 0x8010001 from environment
Starting image ...
Jumping to AARCH64 kernel via monitor
[01/01/1970 00:00:00.0000] Booting Linux on physical CPU 0x0
[01/01/1970 00:00:00.0000] Linux version 4.4.60 (aut@build-lnx-044) (gcc version 5.3.1 (OpenWrt/Linaro GCC 5.3-2016.04 r48430) ) #1 SMP Tue Jul 11 00:04:38 PDT 2023
[01/01/1970 00:00:00.0000] Boot CPU: AArch64 Processor [410fd034]
[01/01/1970 00:00:00.0000] Ignoring memory range 0x40000000 - 0x41000000
[01/01/1970 00:00:00.0000] Kernel command line: console=ttyMSM0,9600n8 ubi.mtd=7 root=/dev/ram activepart=part1 activeboot=0 boardid=0xf swiotlb=1 crashkernel=128M@2816M
[01/01/1970 00:00:00.0000] CPU1: Booted secondary processor [410fd034]
[01/01/1970 00:00:00.0000] CPU2: Booted secondary processor [410fd034]
[01/01/1970 00:00:00.0000] CPU3: Booted secondary processor [410fd034]
[01/01/1970 00:00:00.0000] SMP: Total of 4 processors activated.
[01/01/1970 00:00:03.0499] TZ Log : Will warn on Access Violation, as paniconaccessviolation is not set
[01/01/1970 00:00:03.8999] buginf tty flushing thread started, ttyport=ffffffc076045000
[01/01/1970 00:00:03.8999] diag: IPC Logging disabled
[01/01/1970 00:00:03.8999] TRACK: P[0] PMask[4]
[01/01/1970 00:00:03.8999] TRACK: P[1] PMask[4]
[01/01/1970 00:00:03.8999] TRACK: P[2] PMask[4]
[01/01/1970 00:00:03.8999] TRACK: P[3] PMask[4]
[01/01/1970 00:00:04.1499] m25p80 spi32766.0: found mx25u6435f, expected n25q128a11
[01/01/1970 00:00:04.1499] clear_bam_transaction 885 NAND_ERR: atom_cnt: 1 ; chans_cnt: 1 ; comp_cnt: 0
[01/01/1970 00:00:04.4499] Skip QCA8074V1 in V2 platform
[01/01/1970 00:00:04.5599] ==================== CNSS DEBUGFS CREATE ===================
[01/01/1970 00:00:04.6199] ===================== BDF TESTING =====================
[01/01/1970 00:00:04.7099] cnss[2]: INFO: Platform driver probed successfully. plat ffffffc075db0018 tgt 0xfffe
[01/01/1970 00:00:04.7999] dwc3-of-simple 8af8800.usb3: Disable pipe clock as disable-ss is set
[01/01/1970 00:00:05.2099] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 800000 KHz
[01/01/1970 00:00:05.2099] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1017600 KHz
[01/01/1970 00:00:05.2899] subsys-restart: subsys_register(): Reading instance-id for qcom_q6v5_wcss failed
[01/01/1970 00:00:05.4099] subsys-restart: subsys_register(): Reading qcom,edge for qcom_q6v5_wcss failed
[*01/01/1970 00:00:08.8529] buginf() enabled.
[*01/01/1970 00:00:08.8622] Made it into bootsh: Jul 11 2023 00:45:00 T-81176d2ca1b2619ba72d25e37369f688ed7503a8-g81176d2c-aut
[*01/01/1970 00:00:18.1042] bootsh mini ramfs booted /bootpart/part1/ramfs_data_cisco.squashfs
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
[ OK ] Reached target Timers.
[ OK ] Reached target Cisco File Systems (Pre).
[ OK ] Created slice -.slice.
[ OK ] Created slice system.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Listening on Delayed Shutdown Socket.
[ OK ] Reached target Slices.
[ OK ] Created slice system-sshd\x2dkeygen.slice.
Starting Cisco UBIFS reformat/mount...
[*01/01/1970 00:00:42.5575] root: Cisco Axel file system mounting
[ OK ] Reached target Sockets.
[ OK ] Started Cisco UBIFS reformat/mount.
Starting Cisco early mount...
[ OK ] Started Cisco early mount.
[ OK ] Reached target Local File Systems (Pre).
Starting Cisco fips check...
Starting Cisco platform file generation...
Starting Cisco system time setup...
[*01/01/1970 00:00:43.6952] GCM-128 POST passed
[*01/01/1970 00:00:43.6952] GCM-256 POST passed
[*05/18/2024 23:59:59.0160] Last reload time: May 19 17:34:35 2024
[*05/19/2024 17:34:35.0003] Setting system time Sun May 19 17:34:35 UTC 2024
Starting Cisco seed generation...
[ OK ] Started Cisco fips check.
[ OK ] Started Cisco system time setup.
[ OK ] Started Cisco seed generation.
[ OK ] Started Cisco platform file generation.
[ OK ] Reached target Local File Systems.
[ OK ] Started Cisco system time saving.
Starting Cisco system time saving...
Starting qrtr service...
Starting Cisco act2 check...
Starting Cisco pkg install service...
Starting Cisco S10 boot service...
[ OK ] Started qrtr service.
[05/19/2024 17:34:41.3199] audit_printk_skb: 45 callbacks suppressed
[ OK ] Started Cisco pkg install service.
[ OK ] Started Cisco S10 boot service.
Starting Cisco nolan service...
[*05/19/2024 17:34:36.4604] 15
[*05/19/2024 17:34:36.5401] Active version: 17.9.4.27
[*05/19/2024 17:34:36.5428] Backup version: 17.9.4.27
[*05/19/2024 17:34:36.8191] ssdk_phy_driver_init[340]:INFO:dev_id = 0, phy_adress = 0, phy_id = 0x31c31c23 phytype match
[*05/19/2024 17:34:38.7363] Init NSS DP GMAC6 (base = 0x3a007000)
[*05/19/2024 17:34:38.8669] NSS firmware 1 booted
[*05/19/2024 17:34:38.8703] NSS firmware 0 booted
[*05/19/2024 17:34:39.3223] 254+0 records in
[*05/19/2024 17:34:39.3223] 254+0 records out
[*05/19/2024 17:34:39.3602] Found ETH PHY firmware ID=7 Format=7 Type=5
[*05/19/2024 17:34:40.4686] 11923+0 records in
[*05/19/2024 17:34:40.4686] 11923+0 records out
[*05/19/2024 17:34:40.5266] 254+0 records in
[*05/19/2024 17:34:40.5266] 254+0 records out
[*05/19/2024 17:34:40.5717] Found ETH PHY firmware ID=5 Format=7 Type=5
[*05/19/2024 17:34:41.0061]
[*05/19/2024 17:34:41.0061] Authenticating ACT2 ID:C9130
[*05/19/2024 17:34:41.0061] Authenticating SN:KWC28200PKQ
[*05/19/2024 17:34:41.0067]
[*05/19/2024 17:34:41.0067] (ACT2Boot) Hardware is Cisco (c) authentic
[*05/19/2024 17:34:41.0161] Seeding /dev/urandom from ACT2
[*05/19/2024 17:34:41.6196] 11326+0 records in
[*05/19/2024 17:34:41.6196] 11326+0 records out
[*05/19/2024 17:34:41.6706] 254+0 records in
[*05/19/2024 17:34:41.6706] 254+0 records out
[*05/19/2024 17:34:41.7634] Current value of FACTORY_RESET=0
[*05/18/2024 23:59:59.0131] Last reload time: May 19 17:34:35 2024
[*05/19/2024 17:34:35.0127] Initializing wired0 8C:1E:80:42:51:04 interface
[*05/19/2024 17:34:35.0571] device wired0 entered promiscuous mode
[*05/19/2024 17:34:35.4912] Reading ACT2 SUDI certificates
[*05/19/2024 17:34:35.7079] Last reload reason : 1: reload command
Starting Cisco watchdog...[05/19/2024 17:34:38.2299] qcom wdt: Set timeout to 32 seconds
Starting Cisco nss service...
[ OK ] Started Cisco nolan service.
[ OK ] Started Cisco watchdog.
[ OK ] Started Cisco nss service.
Starting Cisco S15platform...
[*05/19/2024 17:34:38.6615]
[*05/19/2024 17:34:38.6615] ACT2 Check passed
Starting Cisco Kclick...
Starting Cisco nolan USB service...
[ OK ] Started Cisco act2 check.
[ OK ] Started Cisco nolan USB service.
[ OK ] Started Cisco S15platform.
[05/19/2024 17:34:39.1499] Disabling lock debugging due to kernel taint
[*05/19/2024 17:34:39.1622] NTKM - ntkm_init - Nitro KM loaded
[ OK ] Started Cisco pre-PoE negotiation.
Starting Cisco pre-PoE negotiation...
[ OK ] Started Cisco Kclick.
Starting Cisco ME service...
Starting Cisco certificate create service...
Starting Cisco sysctl service...
Starting Cisco Sku service...
[*05/19/2024 17:34:39.9719] Cannot change rx-vlan-offload
[*05/19/2024 17:34:39.9849] Cannot change tx-vlan-offload
[ OK ] Started Cisco ME service.
[ OK ] Started Cisco certificate create service.
[ OK ] Started Cisco sysctl service.
[ OK ] Started Cisco Sku service.
[ OK ] Started Tam server.
Starting Tam server...
[*05/19/2024 17:34:40.5113] [mhitest][A]: [mhitest_init] --->
[*05/19/2024 17:34:40.5116] [mhitest][A]: [mhitest_init] <---done
Starting Cisco Tam service...
Starting Cisco certtime service...
[ OK ] Started Cisco Tam service.
Starting Cisco FIPS QCA radio POST...
Starting rsyslog client...
Starting Cisco S16platfomm...
Starting Cisco syslog service...
[ OK ] Started Cisco FIPS QCA radio POST.
[ OK ] Started rsyslog client.
[ OK ] Started Cisco S16platfomm.
[ OK ] Started Cisco syslog service.
Starting Cisco synclogd...
Starting RHL daemon...
[05/19/2024 17:34:41.5699] arch_setup_msi_irqs
[05/19/2024 17:34:41.5699] pcie_create_qgic_msi_irq:pos=0 irq=116, dev->msi[0]=116 116
[05/19/2024 17:34:41.6099] pcie_create_qgic_msi_irq:pos=1 irq=117, dev->msi[0]=116 117
[05/19/2024 17:34:41.6999] pcie_create_qgic_msi_irq:pos=2 irq=118, dev->msi[0]=116 118
[05/19/2024 17:34:41.7899] pcie_create_qgic_msi_irq:pos=3 irq=119, dev->msi[0]=116 119
[05/19/2024 17:34:41.7899] pcie_create_qgic_msi_irq:pos=4 irq=120, dev->msi[0]=116 120
[05/19/2024 17:34:41.7899] pcie_create_qgic_msi_irq:pos=5 irq=121, dev->msi[0]=116 121
[05/19/2024 17:34:41.7899] pcie_create_qgic_msi_irq:pos=6 irq=122, dev->msi[0]=116 122
[05/19/2024 17:34:41.7899] pcie_create_qgic_msi_irq:pos=7 irq=123, dev->msi[0]=116 123
[05/19/2024 17:34:42.0199] NXP-RHL-Driver 0000:01:00.0: RHL: AP SKU = 0, pow min,max = -4, 20
[05/19/2024 17:34:42.0199] , Rx Diversity =0, 6g AP = 0, Ithaca Esku =0
[05/19/2024 17:34:42.0399] NXP-RHL-Driver 0000:01:00.0: Final VSPA image size val 0xf34000
[ OK ] Started Cisco synclogd.
[ OK ] Started RHL daemon.
[* ] A start job is running for Cisco certtime service (21s / 2min 14s[** ] A start job is running for Cisco certtime service (22s / 2min 14s[*** ] A start job is running for Cisco certtime service (22s / 2min 14s[ *** ] A start job is running for Cisco certtime service (23s / 2min 14s[ *** ] A start job is running for Cisco certtime service (23s / 2min 14s[ ***] A start job is running for Cisco certtime service (24s / 2min 14s[ **] A start job is running for Cisco certtime service (24s / 2min 14s[ *] A start job is running for Cisco certtime service (25s / 2min 14s[ **] A start job is running for Cisco certtime service (25s / 2min 14s[ ***] A start job is running for Cisco certtime service (26s / 2min 14s[ *** ] A start job is running for Cisco certtime service (26s / 2min 14s[ *** ] A start job is running for Cisco certtime service (27s / 2min 14s[*** ] A start job is running for Cisco certtime service (27s / 2min 14s[** ] A start job is running for Cisco certtime service (28s / 2min 14s[* ] A start job is running for Cisco certtime service (28s / 2min 14s[** ] A start job is running for Cisco certtime service (29s / 2min 14s)[05/19/2024 17:34:55.8599] audit_printk_skb: 9 callbacks suppressed
[*** ] A start job is running for Cisco certtime service (29s / 2min 14s[ *** ] A start job is running for Cisco certtime service (30s / 2min 14s[ *** ] A start job is running for Cisco certtime service (30s / 2min 14s[ ***] A start job is running for Cisco certtime service (31s / 2min 14s[ **] A start job is running for Cisco certtime service (31s / 2min 14s[ *] A start job is running for Cisco certtime service (32s / 2min 14s[ **] A start job is running for Cisco certtime service (32s / 2min 14s[ ***] A start job is running for Cisco certtime service (33s / 2min 14s[ OK ] Started Cisco certtime service.
[ OK ] Reached target System Initialization.
[ OK ] Reached target Paths.
[ OK ] Reached target Basic System.
Starting Cisco klogd...
Starting RSYNC User Key Generation...
[ OK ] Started System Monitor service.
Starting System Monitor service...
[ OK ] Started Serial Getty on ttyS0.
Starting Serial Getty on ttyS0...
[ OK ] Reached target Login Prompts.
Starting Cisco brain service...
[*05/19/2024 17:34:41.8333] rhl_reset : got minor 53
[*05/19/2024 17:34:41.9615]
[*05/19/2024 17:34:41.9615] >>>> aq_fw_download /tmp/ethphyfw_0_AQR114C.cld miireg 0
[*05/19/2024 17:34:41.9615] CRC check good on image file (0x66D4)
[*05/19/2024 17:34:41.9615] PHYFW:Loading IRAM ...... ...... Done.
[*05/19/2024 17:34:41.9615] PHYFW:Loading DRAM ...... ...... Done.
[*05/19/2024 17:34:41.9615] PHYFW Image load good - CRC-16 matches (0xF5A5)
[*05/19/2024 17:34:41.9615] PHYFW Image loading complete!
[*05/19/2024 17:34:42.0503] V2H call back init
[*05/19/2024 17:34:42.0503] V2H callback registered
[*05/19/2024 17:34:42.9677]
[*05/19/2024 17:34:42.9677] SSDK Init OK!
[*05/19/2024 17:34:42.9677] operation done.
[*05/19/2024 17:34:49.1138]
[*05/19/2024 17:34:49.1138] Click sched monitor: schedulers = 2
[*05/19/2024 17:34:59.1027] starting tam services using ACT2...
[*05/19/2024 17:34:59.1027] TAM init done
Starting BLE init service...
Starting Clean Air daemon...
Starting Hostapd process...
Starting WCPD process...
[ OK ] Started NSS Firmware Monitor daemon.
Starting NSS Firmware Monitor daemon...
[ OK ] Started RHL monitor/reset daemon.
[*05/19/2024 17:35:02.2795] reset device opened
Starting RHL monitor/reset daemon...
Starting Cisco led service...
[ OK ] Started NTP_PROC daemon.
Starting NTP_PROC daemon...
Starting capwapd...
Starting AP Trace daemon...
Starting Fast CGI daemon...
Starting Security Auditing Service...
Starting Sensord daemon...
Starting Cisco image/firmware updater service...
Starting Cisco printkd...
Starting Cisco kexec...
Starting Cisco rtd service...
[ OK ] Started Cisco klogd.
[ OK ] Started RSYNC User Key Generation.
[ OK ] Started BLE init service.
[ OK ] Started Cisco led service.
[ OK ] Started Cisco image/firmware updater service.
[ OK ] Started Cisco printkd.
[ OK ] Started Cisco kexec.
Starting ntp file watcher...
[*05/19/2024 17:35:03.8383] No valid NTP source
[*05/19/2024 17:35:03.8383] No valid ntp server info file. Stop NTP!
[ OK ] Reached target sshd-keygen.target.
[*05/19/2024 17:35:04.0216] EEPROM Size = 65536
[*05/19/2024 17:35:04.0216] loading pow table from EEPROM to scratch buf
[*05/19/2024 17:35:04.0216] 10200 bytes copied from RHL EEPROM to scratch buf
Starting OpenSSH server daemon...
[ OK ] Started AP Trace daemon.
[*05/19/2024 17:35:04.3979] hostapd:Hostapd: DCDS not init cloud=0 webauth=255 255 init=0
[*05/19/2024 17:35:04.3980]
[ OK ] Started Fast CGI daemon.
[ OK ] Started Cisco rtd service.
[ OK ] Started OpenSSH server daemon.
[ OK ] Started Hostapd process.
[ OK ] Started Sensord daemon.
[*05/19/2024 17:35:04.8632] wlan: [4295:I:RPTR] qca_multi_link_init_module:
[*05/19/2024 17:35:04.8632] ******QCA Repeater Initialization Done***********
[*05/19/2024 17:35:04.9125] wlan: [4310:I:ANY] =======ol_if_register_[05/19/2024 17:35:05.2699] subsys-restart: subsys_start(): subsys_start:633, Setting state SUBSYS_ONLINE
[05/19/2024 17:35:05.2699] cnss[2]: INFO: Waiting for FW ready. Device: 0xfffe, FW ready timeout: 15 seconds
[05/19/2024 17:35:05.3999] cnss[2]: INFO: QMI WLFW service connected, state: 0x1
[05/19/2024 17:35:05.4999] diag: In diag_send_feature_mask_update, control channel is not open, p: 2, ffffffc00114c1a8
[05/19/2024 17:35:05.4999] cnss[2]: INFO: device_id : 65534 mem mode : [0]
[05/19/2024 17:35:05.7099] cnss[2]: INFO: platform name: Qualcomm Technologies, Inc. IPQ807x/AP-HK02
[05/19/2024 17:35:05.7099] cnss[2]: INFO: Target capability: chip_id: 0x0, chip_family: 0x0, board_id: 0xff, soc_id: 0xffffffff, fw_version: 0x2405885e, fw_build_timestamp: 2023-07-11 00:20, otp_version: 0x0 eeprom_caldata_read_timeout 0s
[05/19/2024 17:35:05.8999] cnss_wlfw_bdf_dnld_send_sync:753 LOAD BDF initiated folder:[] bdf_type:[0x5] override:[0x0]
[05/19/2024 17:35:05.8999] cnss_wlfw_load_bdf:605 LOAD BDF initiated folder:[IPQ8074/] bdf_type:[0x0] override:[0x0]
[05/19/2024 17:35:05.8999] cnss[2]: INFO: No board_id entry in device tree
[05/19/2024 17:35:05.8999] cnss[2]: INFO: BDF location : 0x4b0c0000
[05/19/2024 17:35:05.8999] cnss[2]: INFO: BDF IPQ8074/bdwlan.bin size 131072
[05/19/2024 17:35:06.1499] cnss_wlfw_bdf_dnld_send_sync:753 LOAD BDF initiated folder:[] bdf_type:[0x6] override:[0x0]
[05/19/2024 17:35:06.1499] cnss_wlfw_load_bdf:605 LOAD BDF initiated folder:[IPQ8074/] bdf_type:[0x2] override:[0x0]
[05/19/2024 17:35:06.1499] cnss[2]: INFO: per device BDF location : 0x4b0e0000
[05/19/2024 17:35:06.1499] cnss[2]: INFO: CALDATA IPQ8074/caldata.bin size 131072 offset 0x20000
[05/19/2024 17:35:06.1499] cnss[2]: INFO: FW ready received for device 0xfffe
[05/19/2024 17:35:06.2699] cnss[2]: INFO: Sending mode message, mode: MISSION(0), state: 0x7
[*05/19/2024 17:35:05.2834] wlan: [4310:I:ANY] [ol_ath_wifi_ssr]: ### SSR event 3 bus_type 1 ###
[*05/19/2024 17:35:05.4720] pid 4258's current affinity mask: f
[*05/19/2024 17:35:05.4720] pid 4258's new affinity mask: 1
[*05/19/2024 17:35:06.1643] wlan: [4310:I:ANY] pld_ahb_wlan_enable: cnss_mode: Mission mode
[*05/19/2024 17:35:06.4048] wlan: [4310:D:dfs] WLAN_DEBUG_DFS1 : dfs_psoc_obj_create_notification: DFS obj attach to psoc successfully
[*05/19/2024 17:35:06.4051] wlan: [4310:I:ANY] __ol_ath_attach: Booting with Dynamic HW Mode feature enabled
[*05/19/2024 17:35:06.4936] wlan: [4310:I:ANY] ol_target_init_complete: CDP soc attach success
[*05/19/2024 17:35:06.5576] wlan: [704:D:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_agile_soc_obj_init: dfs->dfs_psoc_idx: 0
[*05/19/2024 17:35:06.5577] wlan: [704:D:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_agile_soc_obj_init: dfs_soc_obj->num_dfs_privs: 1
[*05/19/2024 17:35:06.5589] wlan: [704:D:dfs] WLAN_DEBUG_DFS : wlan_dfs_pdev_obj_create_notification: Do not allocate DFS object for 2G, pdev_id = 1
[*05/19/2024 17:35:06.5602] wlan: [704:D:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_agile_soc_obj_init: dfs->dfs_psoc_idx: 1
[*05/19/2024 17:35:06.5602] wlan: [704:D:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_agile_soc_obj_init: dfs_soc_obj->num_dfs_privs: 2
[*05/19/2024 17:35:06.5612] wlan: [704:I:ANY] init_deinit_update_pdev_tgt_info: pdev id:0 wmi_handle:ffffffc074181c00
[*05/19/2024 17:35:06.5622] wlan: [704:F:DP] dp_rx_enable_mon_dest_frag: Feature DP_RX_MON_MEM_FRAG for mon_dest is disabled
[*05/19/2024 17:35:06.5691] wlan: [704:I:ANY] dp_rx_pdev_mon_status_buffers_alloc: repleneshing mon status buffers...
[*05/19/2024 17:35:06.5714] wlan: [704:I:ANY] init_deinit_update_pdev_tgt_info: Pdev = 0 Number of peers = 418 vdevs = 18
[*05/19/2024 17:35:06.5716] wlan: [704:I:ANY] init_deinit_update_pdev_tgt_info: pdev id:1 wmi_handle:ffffffc04c53d000
[*05/19/2024 17:35:06.5727] wlan: [704:F:DP] dp_rx_enable_mon_dest_frag: Feature DP_RX_MON_MEM_FRAG for mon_dest is disabled
[*05/19/2024 17:35:06.5795] wlan: [704:I:ANY] dp_rx_pdev_mon_status_buffers_alloc: repleneshing mon status buffers...
[*05/19/2024 17:35:06.5819] wlan: [704:I:ANY] init_deinit_update_pdev_tgt_info: Pdev = 1 Number of peers = 418 vdevs = 18
[*05/19/2024 17:35:06.5821] wlan: [704:I:ANY] init_deinit_update_pdev_tgt_info: pdev id:2 wmi_handle:ffffffc04c53dc00
[*05/19/2024 17:35:06.5831] wlan: [704:F:DP] dp_rx_enable_mon_dest_frag: Feature DP_RX_MON_MEM_FRAG for mon_dest is disabled
[*05/19/2024 17:35:06.5899] wlan: [704:I:ANY] dp_rx_pdev_mon_status_buffers_alloc: repleneshing mon status buffers...
[*05/19/2024 17:35:06.5923] wlan: [704:I:ANY] init_deinit_update_pdev_tgt_info: Pdev = 2 Number of peers = 418 vdevs = 18
[*05/19/2024 17:35:06.6930] wlan: [704:I:ANY] copy_fw_abi_version_tlv: copy_fw_abi_version_tlv: INIT_CMD version: 1, 0, 0x5f414351, 0x4c4d, 0x0, 0x0
[*05/19/2024 17:35:06.9525] wlan: [704:I:ANY] dp_peer_map_attach_wifi3: dp_peer_map_attach_wifi3 max_peers 1325, max_ast_index: 4112
[*05/19/2024 17:35:06.9540] wlan: [4310:I:ANY] ol_ath_update_wireless_modes: Wireless_modes = 391f9001 after update
[*05/19/2024 17:35:06.9542] wlan: [4310:I:ANY] acfg_attach: acfg_attach: 4594: Netlink socket created:ffffffc04c53f000
[*05/19/2024 17:35:06.9554] wlan: [4310:I:ANY] ol_ath_configure_cong_ctrl_max_msdus: pdev_idx = 0 tx_desc_limit = 32768
[*05/19/2024 17:35:06.9557] wlan: [0:I:ANY] ol_ath_twt_enable_complete_event_handler: twt enabled
[*05/19/2024 17:35:06.9573] wlan: [4310:I:ANY] ol_ath_update_wireless_modes: Wireless_modes = 680680c after update
[*05/19/2024 17:35:06.9574] wlan: [4310:I:ANY] ol_ath_pdev_regdmn_init: LDPC not supported in 5G HE CAP
[*05/19/2024 17:35:06.9582] wlan: [0:I:ANY] ol_ath_twt_enable_complete_event_handler: twt enabled
[*05/19/2024 17:35:06.9584] wlan: [4310:I:ANY] ol_ath_configure_cong_ctrl_max_msdus: pdev_idx = 1 tx_desc_limit = 32768
[*05/19/2024 17:35:06.9584] wlan: [4310:I:ANY] wlan_cfg80211_init: Number of 2G channels: 11
[*05/19/2024 17:35:06.9603] wlan: [4310:I:ANY] ol_ath_update_wireless_modes: Wireless_modes = 391f9001 after update
[*05/19/2024 17:35:06.9618] wlan: [0:I:ANY] ol_ath_twt_enable_complete_event_handler: twt enabled
[*05/19/2024 17:35:06.9618] wlan: [4310:I:ANY] ol_ath_configure_cong_ctrl_max_msdus: pdev_idx = 2 tx_desc_limit = 32768
[*05/19/2024 17:35:06.9628] wlan: [4310:E:QLD] qld_register: Handle or address is NULL
[*05/19/2024 17:35:06.9628] wlan: [4310:I:ANY] init_ath_pci_3_0: 6ath_ol_pci_wifi3.0 : (Atheros/multi-bss)
[*05/19/2024 17:35:07.6462] EEPROM Size = 65536
[*05/19/2024 17:35:07.6462] loading trx table from EEPROM to DTCM
[*05/19/2024 17:35:07.6462] 24480 bytes copied from RHL EEPROM to DTCM
[*05/19/2024 17:35:07.6462] loading ro1 table from EEPROM to DTCM
[*05/19/2024 17:35:07.6462] 12240 bytes copied from RHL EEPROM to DTCM
[*05/19/2024 17:35:07.6462] loading ro2 table from EEPROM to DTCM
User Access Verification
Username: [*05/19/2024 17:35:11.2077] chatter: Device wired0 notify up link DOWN
[*05/19/2024 17:35:11.6187] ip6_port srcr2, ip6local ::, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 2(slaac)
[*05/19/2024 17:35:12.6763] chpasswd: password for user changed
[*05/19/2024 17:35:13.0490] USB Device Disconnected from the AP
[*05/19/2024 17:35:13.5723] pid 6782's current affinity mask: f
[*05/19/2024 17:35:13.5723] pid 6782's new affinity mask: 3
[*05/19/2024 17:35:13.5842] device aptrace0 entered promiscuous mode
[*05/19/2024 17:35:14.0876] DOT11_TXP[0]:Domain configured: 1 class:E
[*05/19/2024 17:35:14.1409] DOT11_TXP[0]:Regdb file: /radio_fw/C9130AXI_power_table_mapping.txt
[*05/19/2024 17:35:14.1462] DOT11_TXP[0]:Domain configured: 12 class:E
[*05/19/2024 17:35:14.5243] chatter: Device wired0 notify state change link UP
[*05/19/2024 17:35:14.5303] DOT11_TXP[0]:Regdb file: /radio_fw/C9130AXI_power_table_mapping.txt
[*05/19/2024 17:35:14.5405] DOT11_TXP[0]:Domain configured: 12 class:E
[*05/19/2024 17:35:14.9400] DOT11_TXP[0]:Regdb file: /radio_fw/C9130AXI_power_table_mapping.txt
[*05/19/2024 17:35:15.4242] DOT11_DRV[3]: Skip Radio3, driver is not implemented - wcp/RadDrv3 :: Dot11AthDriverNL80211
[*05/19/2024 17:35:15.4842] DOT11_DRV[3]: vendor_set_slot_capability: slot 3, radio_service_type 0
[*05/19/2024 17:35:15.4975] DOT11_DRV[0]: vendor_set_slot_capability: slot 0, radio_service_type 0
[*05/19/2024 17:35:15.4976] DOT11_DRV[0]: Init Radio0
[*05/19/2024 17:35:15.5107] DOT11_DRV[0]: set_channel Channel set to 6
[*05/19/2024 17:35:15.5200] DOT11_DRV[1]: vendor_set_slot_capability: slot 1, radio_service_type 1
[*05/19/2024 17:35:15.5201] DOT11_DRV[1]: Init Radio1
[*05/19/2024 17:35:15.5379] DOT11_DRV[1]: Stop Radio1 - Begin
[*05/19/2024 17:35:15.5400] DOT11_DRV[1]: Stop Radio1 - End
[*05/19/2024 17:35:15.5411] DOT11_DRV[1]: set_channel Channel set to 36
[*05/19/2024 17:35:15.5436] DOT11_DRV[2]: vendor_set_slot_capability: slot 2, radio_service_type 0
[*05/19/2024 17:35:15.5436] DOT11_DRV[2]: Init Radio2
[*05/19/2024 17:35:15.5516]
[*05/19/2024 17:35:15.5516] Assertion failure radio_id < num_of_radios() in get_wgb_uplink_instance at 1830
[*05/19/2024 17:35:15.5516] get_wgb_uplink_instance Wrong radio id 2
[*05/19/2024 17:35:15.5530] DOT11_DRV[4]: off_channel timeout but no req in progress
[*05/19/2024 17:35:16.1171] DOT11_DRV[0]: set_channel Channel set to 1
[*05/19/2024 17:35:16.1213] DOT11_DRV[0]: set_channel Channel set to 1
[*05/19/2024 17:35:16.1300] DOT11_DRV[0]: Channel set to 1, width 20
[*05/19/2024 17:35:16.1300] DOT11_DRV[0]: Channel set to 1 skipped
[*05/19/2024 17:35:16.2197] DOT11_DRV[0]: Channel set to 1, width 20
[*05/19/2024 17:35:16.2197] DOT11_DRV[0]: Channel set to 1 skipped
[*05/19/2024 17:35:16.2498] DOT11_DRV[1]: set_channel Channel set to 36
[*05/19/2024 17:35:16.2624] DOT11_DRV[1]: set_channel Channel set to 36
[*05/19/2024 17:35:16.2644] DOT11_DRV[1]: Channel set to 36, width 20
[*05/19/2024 17:35:16.2644] DOT11_DRV[1]: Channel set to 36 skipped
[*05/19/2024 17:35:16.2806] DOT11_DRV[1]: Channel set to 36, width 20
[*05/19/2024 17:35:16.2806] DOT11_DRV[1]: Channel set to 36 skipped
[*05/19/2024 17:35:17.3612] ip6_port srcr2, ip6local fe80::fb8:c62b:85ea:133d, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 2(slaac)
[*05/19/2024 17:35:24.0388] AP is in good condition, BLE is off
[*05/19/2024 17:35:24.0388] Set radio wifi0 power 4 antenna chain 4 15 0
[*05/19/2024 17:35:24.0388] Set radio wifi1 power 4 antenna chain 8 255 0
[*05/19/2024 17:35:24.0388] Set radio wifi2 power 4 antenna chain 4 15 0
[*05/19/2024 17:35:24.0388] set_sys_cond_state: condition good state 1
Username:
Starting capwapd...
Username: [*05/19/2024 17:36:12.4767] chatter: Device wired0 notify down link UP
[*05/19/2024 17:36:12.4772] chatter: Device wired0 notify down link DOWN
[*05/19/2024 17:36:14.4867] chatter: Device wired0 notify up link DOWN
[*05/19/2024 17:36:18.1042] chatter: Device wired0 notify state change link UP
[*05/19/2024 17:37:54.7634] chatter: Device wired0 notify down link UP
[*05/19/2024 17:37:54.7641] chatter: Device wired0 notify down link DOWN
[*05/19/2024 17:37:56.7737] chatter: Device wired0 notify up link DOWN
[*05/19/2024 17:38:00.0643] chatter: Device wired0 notify state change link UP
sensord psage_base init: RHB Sage base ptr 29030000
sensord split_glue psage_base: RHB Sage base ptr 29030000
sensord split_glue sage_addr: RHB Sage base ptr 29030000
sensord crim: RHB Sage base ptr 29030000
[*05/19/2024 17:39:37.0297] chatter: Device wired0 notify down link UP
[*05/19/2024 17:39:37.0305] chatter: Device wired0 notify down link DOWN
[*05/19/2024 17:39:39.0401] chatter: Device wired0 notify up link DOWN
[*05/19/2024 17:39:43.0343] chatter: Device wired0 notify state change link UP
[*05/19/2024 17:41:19.2845] chatter: Device wired0 notify down link UP
[*05/19/2024 17:41:19.2852] chatter: Device wired0 notify down link DOWN
[*05/19/2024 17:41:21.2946] chatter: Device wired0 notify up link DOWN
[*05/19/2024 17:41:24.9942] chatter: Device wired0 notify state change link UP
[*05/19/2024 17:43:01.5445] chatter: Device wired0 notify down link UP
[*05/19/2024 17:43:01.5452] chatter: Device wired0 notify down link DOWN
[*05/19/2024 17:43:03.5546] chatter: Device wired0 notify up link DOWN
[*05/19/2024 17:43:06.9542] chatter: Device wired0 notify state change link UP
[*05/19/2024 17:44:43.7913] chatter: Device wired0 notify down link UP
[*05/19/2024 17:44:43.7920] chatter: Device wired0 notify down link DOWN
[*05/19/2024 17:44:45.8014] chatter: Device wired0 notify up link DOWN
[*05/19/2024 17:44:49.9142] chatter: Device wired0 notify state change link UP
[*05/19/2024 17:46:26.0405] chatter: Device wired0 notify down link UP
[*05/19/2024 17:46:26.0413] chatter: Device wired0 notify down link DOWN
[*05/19/2024 17:46:28.0505] chatter: Device wired0 notify up link DOWN
[*05/19/2024 17:46:31.8742] chatter: Device wired0 notify state change link UP
[*05/19/2024 17:48:08.2861] chatter: Device wired0 notify down link UP
[*05/19/2024 17:48:08.2867] chatter: Device wired0 notify down link DOWN
[*05/19/2024 17:48:10.2963] chatter: Device wired0 notify up link DOWN
[*05/19/2024 17:48:13.8342] chatter: Device wired0 notify state change link UP
[*05/19/2024 17:49:50.5375] chatter: Device wired0 notify down link UP
[*05/19/2024 17:49:50.5381] chatter: Device wired0 notify down link DOWN
[*05/19/2024 17:49:52.5475] chatter: Device wired0 notify up link DOWN
[*05/19/2024 17:49:55.7942] chatter: Device wired0 notify state change link UP
[*05/19/2024 17:51:32.7923] chatter: Device wired0 notify down link UP
[*05/19/2024 17:51:32.7930] chatter: Device wired0 notify down link DOWN
[*05/19/2024 17:51:34.8028] chatter: Device wired0 notify up link DOWN
[*05/19/2024 17:51:38.7642] chatter: Device wired0 notify state change link UP
[*05/19/2024 17:53:15.0439] chatter: Device wired0 notify down link UP
[*05/19/2024 17:53:15.0446] chatter: Device wired0 notify down link DOWN
[*05/19/2024 17:53:17.0538] chatter: Device wired0 notify up link DOWN
[*05/19/2024 17:53:20.7242] chatter: Device wired0 notify state change link UP
[*05/19/2024 17:54:57.3031] chatter: Device wired0 notify down link UP
[*05/19/2024 17:54:57.3039] chatter: Device wired0 notify down link DOWN
[*05/19/2024 17:54:59.3132] chatter: Device wired0 notify up link DOWN
[*05/19/2024 17:55:02.6842] chatter: Device wired0 notify state change link UP
[*05/19/2024 17:56:39.5578] chatter: Device wired0 notify down link UP
[*05/19/2024 17:56:39.5585] chatter: Device wired0 notify down link DOWN
[*05/19/2024 17:56:41.5680] chatter: Device wired0 notify up link DOWN
[*05/19/2024 17:56:45.6442] chatter: Device wired0 notify state change link UP
[*05/19/2024 17:58:21.8113] chatter: Device wired0 notify down link UP
[*05/19/2024 17:58:21.8119] chatter: Device wired0 notify down link DOWN
[*05/19/2024 17:58:23.8213] chatter: Device wired0 notify up link DOWN
[*05/19/2024 17:58:27.6042] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:00:04.0674] chatter: Device wired0 notify down link UP
[*05/19/2024 18:00:04.0680] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:00:06.0775] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:00:09.5643] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:01:46.3260] chatter: Device wired0 notify down link UP
[*05/19/2024 18:01:46.3267] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:01:48.3361] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:01:52.5242] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:03:28.5806] chatter: Device wired0 notify down link UP
[*05/19/2024 18:03:28.5816] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:03:30.5912] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:03:34.4842] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:05:10.8427] chatter: Device wired0 notify down link UP
[*05/19/2024 18:05:10.8433] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:05:12.8526] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:05:16.4444] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:06:53.1033] chatter: Device wired0 notify down link UP
[*05/19/2024 18:06:53.1040] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:06:55.1134] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:06:58.4042] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:08:35.3641] chatter: Device wired0 notify down link UP
[*05/19/2024 18:08:35.3648] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:08:37.3743] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:08:41.3742] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:10:17.6161] chatter: Device wired0 notify down link UP
[*05/19/2024 18:10:17.6167] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:10:19.6262] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:10:23.3342] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:11:59.8723] chatter: Device wired0 notify down link UP
[*05/19/2024 18:11:59.8730] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:12:01.8828] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:12:05.2942] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:13:42.1360] chatter: Device wired0 notify down link UP
[*05/19/2024 18:13:42.1367] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:13:44.1463] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:13:48.2542] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:15:24.3901] chatter: Device wired0 notify down link UP
[*05/19/2024 18:15:24.3909] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:15:26.4004] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:15:30.2142] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:17:06.6448] chatter: Device wired0 notify down link UP
[*05/19/2024 18:17:06.6454] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:17:08.6546] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:17:12.1743] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:18:48.9001] chatter: Device wired0 notify down link UP
[*05/19/2024 18:18:48.9009] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:18:50.9106] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:18:55.1342] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:20:31.1600] chatter: Device wired0 notify down link UP
[*05/19/2024 18:20:31.1606] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:20:33.1700] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:20:37.0942] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:22:13.4137] chatter: Device wired0 notify down link UP
[*05/19/2024 18:22:13.4143] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:22:15.4237] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:22:19.0543] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:23:55.6715] chatter: Device wired0 notify down link UP
[*05/19/2024 18:23:55.6721] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:23:57.6814] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:24:02.0142] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:25:37.9249] chatter: Device wired0 notify down link UP
[*05/19/2024 18:25:37.9256] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:25:39.9349] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:25:43.9642] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:27:20.1761] chatter: Device wired0 notify down link UP
[*05/19/2024 18:27:20.1768] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:27:22.1859] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:27:25.9242] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:29:02.4266] chatter: Device wired0 notify down link UP
[*05/19/2024 18:29:02.4274] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:29:04.4368] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:29:07.8842] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:30:44.6867] chatter: Device wired0 notify down link UP
[*05/19/2024 18:30:44.6873] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:30:46.6967] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:30:50.8442] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:32:26.9437] chatter: Device wired0 notify down link UP
[*05/19/2024 18:32:26.9445] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:32:28.9541] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:32:32.8043] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:34:09.2010] chatter: Device wired0 notify down link UP
[*05/19/2024 18:34:09.2016] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:34:11.2112] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:34:14.7642] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:35:51.4546] chatter: Device wired0 notify down link UP
[*05/19/2024 18:35:51.4553] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:35:53.4644] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:35:56.7242] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:37:33.7100] chatter: Device wired0 notify down link UP
[*05/19/2024 18:37:33.7107] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:37:35.7200] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:37:39.6943] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:39:15.9698] chatter: Device wired0 notify down link UP
[*05/19/2024 18:39:15.9705] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:39:17.9799] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:39:21.6542] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:40:58.2235] chatter: Device wired0 notify down link UP
[*05/19/2024 18:40:58.2242] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:41:00.2338] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:41:03.6142] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:42:40.4776] chatter: Device wired0 notify down link UP
[*05/19/2024 18:42:40.4782] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:42:42.4876] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:42:46.5743] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:44:22.7320] chatter: Device wired0 notify down link UP
[*05/19/2024 18:44:22.7327] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:44:24.7425] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:44:28.5342] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:46:04.9920] chatter: Device wired0 notify down link UP
[*05/19/2024 18:46:04.9927] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:46:07.0023] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:46:10.4942] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:47:47.2443] chatter: Device wired0 notify down link UP
[*05/19/2024 18:47:47.2450] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:47:49.2544] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:47:53.4544] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:49:29.5017] chatter: Device wired0 notify down link UP
[*05/19/2024 18:49:29.5023] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:49:31.5119] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:49:35.4142] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:51:11.7613] chatter: Device wired0 notify down link UP
[*05/19/2024 18:51:11.7619] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:51:13.7712] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:51:17.3742] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:52:54.0101] chatter: Device wired0 notify down link UP
[*05/19/2024 18:52:54.0109] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:52:56.0206] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:53:00.3343] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:54:36.2633] chatter: Device wired0 notify down link UP
[*05/19/2024 18:54:36.2640] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:54:38.2734] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:54:42.2843] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:56:18.5242] chatter: Device wired0 notify down link UP
[*05/19/2024 18:56:18.5248] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:56:20.5341] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:56:24.2442] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:58:00.7826] chatter: Device wired0 notify down link UP
[*05/19/2024 18:58:00.7834] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:58:02.7935] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:58:06.2043] chatter: Device wired0 notify state change link UP
[*05/19/2024 18:59:43.0446] chatter: Device wired0 notify down link UP
[*05/19/2024 18:59:43.0453] chatter: Device wired0 notify down link DOWN
[*05/19/2024 18:59:45.0547] chatter: Device wired0 notify up link DOWN
[*05/19/2024 18:59:49.1642] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:01:25.2927] chatter: Device wired0 notify down link UP
[*05/19/2024 19:01:25.2934] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:01:27.3029] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:01:31.1242] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:03:07.5482] chatter: Device wired0 notify down link UP
[*05/19/2024 19:03:07.5489] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:03:09.5587] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:03:13.0843] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:04:49.8132] chatter: Device wired0 notify down link UP
[*05/19/2024 19:04:49.8147] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:04:51.8241] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:04:56.0442] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:06:32.0745] chatter: Device wired0 notify down link UP
[*05/19/2024 19:06:32.0752] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:06:34.0844] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:06:38.0042] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:08:14.3271] chatter: Device wired0 notify down link UP
[*05/19/2024 19:08:14.3278] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:08:16.3372] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:08:19.9643] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:09:56.5855] chatter: Device wired0 notify down link UP
[*05/19/2024 19:09:56.5862] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:09:58.5958] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:10:02.9342] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:11:38.8466] chatter: Device wired0 notify down link UP
[*05/19/2024 19:11:38.8472] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:11:40.8568] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:11:44.8843] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:13:21.0966] chatter: Device wired0 notify down link UP
[*05/19/2024 19:13:21.0974] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:13:23.1068] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:13:26.8442] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:15:03.3484] chatter: Device wired0 notify down link UP
[*05/19/2024 19:15:03.3491] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:15:05.3583] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:15:08.8042] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:16:45.6127] chatter: Device wired0 notify down link UP
[*05/19/2024 19:16:45.6134] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:16:47.6227] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:16:51.7642] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:18:27.8691] chatter: Device wired0 notify down link UP
[*05/19/2024 19:18:27.8697] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:18:29.8791] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:18:33.7243] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:20:10.1233] chatter: Device wired0 notify down link UP
[*05/19/2024 19:20:10.1240] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:20:12.1333] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:20:15.6842] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:21:52.3798] chatter: Device wired0 notify down link UP
[*05/19/2024 19:21:52.3806] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:21:54.3898] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:21:58.6442] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:23:34.6352] chatter: Device wired0 notify down link UP
[*05/19/2024 19:23:34.6360] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:23:36.6466] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:23:40.6042] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:25:16.8973] chatter: Device wired0 notify down link UP
[*05/19/2024 19:25:16.8980] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:25:18.9075] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:25:22.5642] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:26:59.1574] chatter: Device wired0 notify down link UP
[*05/19/2024 19:26:59.1582] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:27:01.1676] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:27:05.5242] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:28:41.4048] chatter: Device wired0 notify down link UP
[*05/19/2024 19:28:41.4054] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:28:43.4148] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:28:47.4743] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:30:23.6615] chatter: Device wired0 notify down link UP
[*05/19/2024 19:30:23.6622] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:30:25.6716] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:30:29.4342] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:32:05.9209] chatter: Device wired0 notify down link UP
[*05/19/2024 19:32:05.9216] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:32:07.9310] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:32:11.3942] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:33:48.1725] chatter: Device wired0 notify down link UP
[*05/19/2024 19:33:48.1732] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:33:50.1822] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:33:54.3543] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:35:30.4194] chatter: Device wired0 notify down link UP
[*05/19/2024 19:35:30.4202] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:35:32.4294] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:35:36.3142] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:37:12.6736] chatter: Device wired0 notify down link UP
[*05/19/2024 19:37:12.6742] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:37:14.6836] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:37:18.2742] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:38:54.9311] chatter: Device wired0 notify down link UP
[*05/19/2024 19:38:54.9319] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:38:56.9413] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:39:01.2343] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:40:37.1806] chatter: Device wired0 notify down link UP
[*05/19/2024 19:40:37.1846] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:40:39.1941] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:40:43.1942] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:42:19.4377] chatter: Device wired0 notify down link UP
[*05/19/2024 19:42:19.4384] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:42:21.4478] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:42:25.1542] chatter: Device wired0 notify state change link UP
[*05/19/2024 19:44:01.6925] chatter: Device wired0 notify down link UP
[*05/19/2024 19:44:01.6932] chatter: Device wired0 notify down link DOWN
[*05/19/2024 19:44:03.7027] chatter: Device wired0 notify up link DOWN
[*05/19/2024 19:44:07.1143] chatter: Device wired0 notify state change link UP
[01/01/1970 00:00:00.0000] Kernel command line: console=ttyMSM0,9600n8 root=/dev/ram boardid=0x14 activepart=part1 cnss2.bdf_pci0=0xab cnss2.bdf_pci1=0xaa swiotlb=1 crashkernel=128M@2816M
[01/01/1970 00:00:03.1799] TZ Log : Will warn on Access Violation, as paniconaccessviolation is not set
[01/01/1970 00:00:04.0499] buginf tty flushing thread started, ttyport=ffffffc01f11e000
[01/01/1970 00:00:04.0499] diag: IPC Logging disabled
[01/01/1970 00:00:04.0599] TRACK: P[0] PMask[4]
[01/01/1970 00:00:04.0599] TRACK: P[1] PMask[4]
[01/01/1970 00:00:04.0599] TRACK: P[2] PMask[4]
[01/01/1970 00:00:04.0599] TRACK: P[3] PMask[4]
[01/01/1970 00:00:04.1799] clear_bam_transaction 885 NAND_ERR: atom_cnt: 1 ; chans_cnt: 1 ; comp_cnt: 0
[01/01/1970 00:00:04.4699] <DBG> qca_phy_gpio_set: GPIO number=0x2c, Start
[01/01/1970 00:00:04.5799] <DBG> qca_phy_gpio_set: GPIO number=0x2c , END
[01/01/1970 00:00:04.6899] Skip QCA8074V1 in V2 platform
[01/01/1970 00:00:04.6899] ==================== CNSS DEBUGFS CREATE ===================
[01/01/1970 00:00:04.6899] ===================== BDF TESTING =====================
[01/01/1970 00:00:04.6899] cnss[2]: INFO: Platform driver probed successfully. plat ffffffc07b598018 tgt 0xfffe
[01/01/1970 00:00:04.6899] cnss[27]: INFO: Platform driver probed successfully. plat ffffffc07b5a0018 tgt 0x1104
[01/01/1970 00:00:04.6899] cnss[28]: INFO: Platform driver probed successfully. plat ffffffc07b5b0018 tgt 0x1104
[01/01/1970 00:00:04.6899] dwc3-of-simple 8af8800.usb3: Disable pipe clock as disable-ss is set
[01/01/1970 00:00:05.0499] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 800000 KHz
[01/01/1970 00:00:05.0499] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1017600 KHz
[01/01/1970 00:00:05.0499] subsys-restart: subsys_register(): Reading instance-id for qcom_q6v5_wcss failed
[01/01/1970 00:00:05.0499] subsys-restart: subsys_register(): Reading qcom,edge for qcom_q6v5_wcss failed
[*01/01/1970 00:00:07.7988] buginf() enabled.
[*01/01/1970 00:00:07.8081] Made it into bootsh: Jul 11 2023 00:45:00 T-81176d2ca1b2619ba72d25e37369f688ed7503a8-g81176d2c-aut
[*01/01/1970 00:00:18.0280] bootsh mini ramfs booted /bootpart/part1/ramfs_data_cisco.squashfs
Welcome to Cisco.
available at:
Cisco Systems, Inc.
export@cisco.com.
[*01/01/1970 00:00:42.4972] root: Cisco Axel file system mounting
[*12/16/2023 23:59:59.0161] Last reload time: Feb 4 19:57:19 2025
[*02/04/2025 19:57:19.0003] Setting system time Tue Feb 4 19:57:19 UTC 2025
[*02/04/2025 19:57:19.0431] GCM-128 POST passed
[*02/04/2025 19:57:19.0431] GCM-256 POST passed
[*02/04/2025 19:57:20.3580] 20
[02/04/2025 19:57:21.0499] cnss[2]: INFO: Setting daemon_support=1 for instance_id 0x2
[02/04/2025 19:57:21.0499] cnss[27]: INFO: Setting daemon_support=1 for instance_id 0x27
[02/04/2025 19:57:21.1299] cnss[28]: INFO: Setting daemon_support=1 for instance_id 0x28
[02/04/2025 19:57:21.2299] cnss[27]: INFO: Setting cold_boot_support=1 for instance_id 0x27
[02/04/2025 19:57:21.3199] cnss[28]: INFO: Setting cold_boot_support=1 for instance_id 0x28
[02/04/2025 19:57:23.1699] audit_printk_skb: 48 callbacks suppressed
[*02/04/2025 19:57:20.5338] Active version: 17.9.4.27
[*02/04/2025 19:57:20.5366] Backup version: 17.9.4.27
[*02/04/2025 19:57:20.8201] ssdk_phy_driver_init[340]:INFO:dev_id = 0, phy_adress = 0, phy_id = 0x31c31c23 phytype match
[*02/04/2025 19:57:22.7[02/04/2025 19:57:20.6099] qcom wdt: Set timeout to 32 seconds
[02/04/2025 19:57:21.5699] Disabling lock debugging due to kernel taint
[*02/04/2025 19:57:21.5950] NTKM - ntkm_init - Nitro KM loaded
[*02/04/2025 19:57:22.2669] Seeding /dev/urandom from ACT2
[*02/04/2025 19:57:22.2808] Cannot change rx-vlan-offload
[*02/04/2025 19:57:22.2834] Cannot change tx-vlan-offload
[*02/04/2025 19:57:22.6373] Reading ACT2 SUDI certificates
[*02/04/2025 19:57:22.9197] [mhitest][A]: [mhitest_init] --->
[*02/04/2025 19:57:22.9199] [mhitest][A]: [mhitest_init] <---done
[*02/04/2025 19:57:24.0888]
[*02/04/2025 19:57:24.0888] ACT2 Check passed
Starting Cisco Tam service...[02/04/2025 19:57:24.4399] audit_printk_skb: 15 callbacks suppressed
[* ] A start job is running for Cisco certtime service (20s / 2min 11s[** ] A start job is running for Cisco certtime service (21s / 2min 11s[*** ] A start job is running for Cisco certtime service (21s / 2min 11s[ *** ] A start job is running for Cisco certtime service (22s / 2min 11s[ *** ] A start job is running for Cisco certtime service (22s / 2min 11s[ ***] A start job is running for Cisco certtime service (23s / 2min 11s[ **] A start job is running for Cisco certtime service (23s / 2min 11s[ *] A start job is running for Cisco certtime service (24s / 2min 11s[ **] A start job is running for Cisco certtime service (24s / 2min 11s[ ***] A start job is running for Cisco certtime service (25s / 2min 11s[ *** ] A start job is running for Cisco certtime service (25s / 2min 11s[ *** ] A start job is running for Cisco certtime service (26s / 2min 11s[*** ] A start job is running for Cisco certtime service (26s / 2min 11s[** ] A start job is running for Cisco certtime service (27s / 2min 11s[* ] A start job is running for Cisco certtime service (27s / 2min 11s[** ] A start job is running for Cisco certtime service (28s / 2min 11s[*** ] A start job is running for Cisco certtime service (28s / 2min 11s[ *** ] A start job is running for Cisco certtime service (29s / 2min 11s[ *** ] A start job is running for Cisco certtime service (29s / 2min 11s[ ***] A start job is running for Cisco certtime service (30s / 2min 11s[ **] A start job is running for Cisco certtime service (30s / 2min 11s[ *] A start job is running for Cisco certtime service (31s / 2min 11s[ **] A start job is running for Cisco certtime service (31s / 2min 11s[ ***] A start job is running for Cisco certtime service (32s / 2min 11s[ *** ] A start job is running for Cisco certtime service (32s / 2min 11s[ *** ] A start job is running for Cisco certtime service (33s / 2min 11s)[*02/04/2025 19:57:25.8191]
[*02/04/2025 19:57:25.8191] >>>> aq_fw_download /tmp/ethphyfw_0_AQR114C.cld miireg 0
[*02/04/2025 19:57:25.8191] CRC check good on image file (0x2ECC)
[*02/04/2025 19:57:25.8191] PHYFW:Loading IRAM ...... ...... Done.
[*02/04/2025 19:57:25.8191] PHYFW:Loading DRAM ...... ...... Done.
[*02/04/2025 19:57:25.8191] PHYFW Image load good - CRC-16 matches (0x5A66)
[*02/04/2025 19:57:25.8191] PHYFW Image loading complete!
[*02/04/2025 19:57:26.8250]
[*02/04/2025 19:57:26.8250] SSDK Init OK!
[*02/04/2025 19:57:26.8250] operation done.
[*02/04/2025 19:57:31.5374]
[*02/04/2025 19:57:31.5374] Click sched monitor: schedulers = 2
[*02/04/2025 19:57:45.0925] starting tam services using ACT2...
[*02/04/2025 19:57:45.0925] TAM init done
[*02/04/2025 19:57:46.5514]
[*02/04/2025 19:57:46.5514] [2/4/2025 19:58:47] updt_util: PHY firmware is up to date
Starting capwapd...
[ OK ] Started Qsensord daemon.
Starting Qsensord daemon...
[*02/04/2025 19:57:47.9952] taskset: invalid number '0xe'
[*02/04/2025 19:57:48.9120] No valid NTP source
[*02/04/2025 19:57:48.9120] No valid ntp server info file. Stop NTP!
[*02/04/2025 19:57:49.2902] hostapd:Hostapd: DCDS not init cloud=0 webauth=255 255 init=0
Starting ntp watcher...
[*02/04/2025 19:57:49.7075] wlan: [4233:I:RPTR] qca_multi_link_init_module:
[*02/04/2025 19:57:49.7075] ******QCA Repeater Initialization Done***********
[*02/04/2025 19:57:49.7470] wlan: [4252:I:ANY] =======ol_if_register_wifi3_0==========
[*02/04/2025 19:57:49.7470] wlan: [4252:I:ANY] [ol_ath_wifi_ssr]: ### SSR eve[02/04/2025 19:57:50.0899] subsys-restart: subsys_start(): subsys_start:633, Setting state SUBSYS_ONLINE
[02/04/2025 19:57:50.0999] cnss[2]: INFO: QMI WLFW service connected, state: 0x1
[02/04/2025 19:57:50.0999] cnss[2]: INFO: device_id : 65534 mem mode : [0]
[02/04/2025 19:57:50.0999] cnss[2]: INFO: platform name: Cisco System, Inc. IPQ807x/C9166
[02/04/2025 19:57:50.0999] diag: In diag_send_feature_mask_update, control channel is not open, p: 2, ffffffc00114c1a8
[02/04/2025 19:57:50.0999] cnss[2]: INFO: Target capability: chip_id: 0x0, chip_family: 0x0, board_id: 0xff, soc_id: 0xffffffff, fw_version: 0x2405885e, fw_build_timestamp: 2023-07-11 00:20, otp_version: 0x0 eeprom_caldata_read_timeout 0s
[02/04/2025 19:57:50.0999] cnss_wlfw_bdf_dnld_send_sync:753 LOAD BDF initiated folder:[] bdf_type:[0x5] override:[0x0]
[02/04/2025 19:57:50.0999] cnss_wlfw_load_bdf:605 LOAD BDF initiated folder:[IPQ8074/] bdf_type:[0x0] override:[0x0]
[02/04/2025 19:57:50.0999] cnss[2]: INFO: No board_id entry in device tree
[02/04/2025 19:57:50.0999] cnss[2]: INFO: BDF location : 0x4b0c0000
[02/04/2025 19:57:50.0999] cnss[2]: INFO: BDF IPQ8074/bdwlan.bin size 131072
[02/04/2025 19:57:50.0999] cnss_wlfw_bdf_dnld_send_sync:753 LOAD BDF initiated folder:[] bdf_type:[0x6] override:[0x0]
[02/04/2025 19:57:50.0999] cnss_wlfw_load_bdf:605 LOAD BDF initiated folder:[IPQ8074/] bdf_type:[0x2] override:[0x0]
[02/04/2025 19:57:50.0999] cnss[2]: INFO: per device BDF location : 0x4b0e0000
[02/04/2025 19:57:50.0999] cnss[2]: INFO: CALDATA IPQ8074/caldata.bin size 131072 offset 0x20000
[02/04/2025 19:57:51.6499] cnss[2]: INFO: Waiting for FW ready. Device: 0xfffe, FW ready timeout: 15 seconds
[02/04/2025 19:57:51.7599] cnss[2]: INFO: FW ready received for device 0xfffe
[02/04/2025 19:57:51.8699] cnss[2]: INFO: Sending mode message, mode: MISSION(0), state: 0x7
nt 2 bus_type 1 ###
[*02/04/2025 19:57:51.6647] wlan: [4252:I:ANY] [ol_ath_wifi_ssr]: ### SSR event 3 bus_type 1 ###
[*02/04/2025 19:57:51.8838] wlan: [4252:I:ANY] pld_ahb_wlan_enable: cnss_mode: Mission mode
[*02/04/2025 19:57:51.9749] wlan: [4252:D:dfs[02/04/2025 19:57:52.3299] subsys-restart: subsys_register(): Reading instance-id for QCN9000_PCI0 failed
[02/04/2025 19:57:52.3799] subsys-restart: subsys_register(): Reading qcom,edge for QCN9000_PCI0 failed
[02/04/2025 19:57:52.4999] arch_setup_msi_irqs
[02/04/2025 19:57:52.6099] pcie_create_qgic_msi_irq:pos=0 irq=115, dev->msi[0]=115 115
[02/04/2025 19:57:52.6499] pcie_create_qgic_msi_irq:pos=1 irq=116, dev->msi[0]=115 116
[02/04/2025 19:57:52.7399] pcie_create_qgic_msi_irq:pos=2 irq=117, dev->msi[0]=115 117
[02/04/2025 19:57:52.8399] pcie_create_qgic_msi_irq:pos=3 irq=118, dev->msi[0]=115 118
[02/04/2025 19:57:52.9299] pcie_create_qgic_msi_irq:pos=4 irq=119, dev->msi[0]=115 119
[02/04/2025 19:57:53.0199] pcie_create_qgic_msi_irq:pos=5 irq=120, dev->msi[0]=115 120
[02/04/2025 19:57:53.1099] pcie_create_qgic_msi_irq:pos=6 irq=121, dev->msi[0]=115 121
[02/04/2025 19:57:53.1999] pcie_create_qgic_msi_irq:pos=7 irq=122, dev->msi[0]=115 122
[02/04/2025 19:57:53.2899] pcie_create_qgic_msi_irq:pos=8 irq=123, dev->msi[0]=115 123
[02/04/2025 19:57:53.3899] pcie_create_qgic_msi_irq:pos=9 irq=124, dev->msi[0]=115 124
[02/04/2025 19:57:53.4799] pcie_create_qgic_msi_irq:pos=10 irq=125, dev->msi[0]=115 125
[02/04/2025 19:57:53.5699] pcie_create_qgic_msi_irq:pos=11 irq=126, dev->msi[0]=115 126
[02/04/2025 19:57:53.6699] pcie_create_qgic_msi_irq:pos=12 irq=127, dev->msi[0]=115 127
[02/04/2025 19:57:53.7599] pcie_create_qgic_msi_irq:pos=13 irq=128, dev->msi[0]=115 128
[02/04/2025 19:57:53.8499] pcie_create_qgic_msi_irq:pos=14 irq=129, dev->msi[0]=115 129
[02/04/2025 19:57:53.9399] pcie_create_qgic_msi_irq:pos=15 irq=130, dev->msi[0]=115 130
[*02/04/2025 19:57:51.9980] wlan: [42[02/04/2025 19:57:54.2599] subsys-restart: subsys_start(): subsys_start:633, Setting state SUBSYS_ONLINE
[02/04/2025 19:57:54.2599] cnss[27]: INFO: Waiting for FW ready. Device: 0x1104, FW ready timeout: 15 seconds
[02/04/2025 19:57:54.3799] cnss[27]: INFO: QMI WLFW service connected, state: 0x11
[02/04/2025 19:57:54.4899] cnss[27]: INFO: device_id : 4356 mem mode : [0]
[02/04/2025 19:57:54.5699] cnss[27]: INFO: platform name: Cisco System, Inc. IPQ807x/C9166
[02/04/2025 19:57:54.6599] cnss[27]: INFO: Target capability: chip_id: 0x0, chip_family: 0x0, board_id: 0xff, soc_id: 0xffffffff, fw_version: 0x2405885e, fw_build_timestamp: 2023-07-11 00:30, otp_version: 0x0 eeprom_caldata_read_timeout 0s
[02/04/2025 19:57:54.8799] cnss_wlfw_bdf_dnld_send_sync:753 LOAD BDF initiated folder:[qcn9000/] bdf_type:[0x5] override:[0xab]
[02/04/2025 19:57:54.9999] cnss[27]: INFO: Downloading BDF: qcn9000/bdwlan.bab, size: 131072
[02/04/2025 19:57:55.1499] cnss_wlfw_bdf_dnld_send_sync:753 LOAD BDF initiated folder:[qcn9000/] bdf_type:[0x6] override:[0xab]
[02/04/2025 19:57:55.2399] cnss[27]: INFO: Downloading BDF: qcn9000/caldata_1.bin, size: 131072
[02/04/2025 19:57:55.4299] cnss[27]: INFO: FW ready received for device 0x1104
[02/04/2025 19:57:55.4699] cnss[27]: INFO: Sending mode message, mode: MISSION(0), state: 0x17
52:I:ANY] ol_target_init_complete: CDP soc attach success
[*02/04/2025 19:57:51.9991] wlan: [42:D:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_agile_soc_obj_init: dfs->dfs_psoc_idx: 0
[*02/04/2025 19:57:51.9991] wlan: [42:D:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_agile_soc_obj_init: dfs_soc_obj->num_dfs_privs: 1
[*02/04/2025 19:57:51.9991] wlan: [42:D:dfs] WLAN_DEBUG_DFS : csc_wlan_dfs_sinfo_notify_handler_cb: Cisco DFS module Not available.
[*02/04/2025 19:57:52.0004] wlan: [42:D:dfs] WLAN_DEBUG_DFS : wlan_dfs_pdev_obj[02/04/2025 19:57:56.1499] subsys-restart: subsys_register(): Reading instance-id for QCN9000_PCI1 failed
[02/04/2025 19:57:56.1799] subsys-restart: subsys_register(): Reading qcom,edge for QCN9000_PCI1 failed
[02/04/2025 19:57:56.2999] arch_setup_msi_irqs
[02/04/2025 19:57:56.4099] pcie_create_qgic_msi_irq:pos=0 irq=132, dev->msi[0]=132 132
[02/04/2025 19:57:56.4599] pcie_create_qgic_msi_irq:pos=1 irq=133, dev->msi[0]=132 133
[02/04/2025 19:57:56.5499] pcie_create_qgic_msi_irq:pos=2 irq=134, dev->msi[0]=132 134
[02/04/2025 19:57:56.6499] pcie_create_qgic_msi_irq:pos=3 irq=135, dev->msi[0]=132 135
[02/04/2025 19:57:56.7399] pcie_create_qgic_msi_irq:pos=4 irq=136, dev->msi[0]=132 136
[02/04/2025 19:57:56.8299] pcie_create_qgic_msi_irq:pos=5 irq=137, dev->msi[0]=132 137
[02/04/2025 19:57:56.9199] pcie_create_qgic_msi_irq:pos=6 irq=138, dev->msi[0]=132 138
[02/04/2025 19:57:57.0099] pcie_create_qgic_msi_irq:pos=7 irq=139, dev->msi[0]=132 139
[02/04/2025 19:57:57.0999] pcie_create_qgic_msi_irq:pos=8 irq=140, dev->msi[0]=132 140
[02/04/2025 19:57:57.1999] pcie_create_qgic_msi_irq:pos=9 irq=141, dev->msi[0]=132 141
[02/04/2025 19:57:57.2899] pcie_create_qgic_msi_irq:pos=10 irq=142, dev->msi[0]=132 142
[02/04/2025 19:57:57.3799] pcie_create_qgic_msi_irq:pos=11 irq=143, dev->msi[0]=132 143
[02/04/2025 19:57:57.4699] pcie_create_qgic_msi_irq:pos=12 irq=144, dev->msi[0]=132 144
[02/04/2025 19:57:57.5699] pcie_create_qgic_msi_irq:pos=13 irq=145, dev->msi[0]=132 145
[02/04/2025 19:57:57.6599] pcie_create_qgic_msi_irq:pos=14 irq=146, dev->msi[0]=132 146
[02/04/2025 19:57:57.7499] pcie_create_qgic_msi_irq:pos=15 irq=147, dev->msi[0]=132 147
[*02/04/2025 19:57:52.0014] wlan: [42:I:ANY] init_deinit_update_pdev_tgt_info: pdev id:0 wmi_handle:ffffffc0586bdc00
[*02/04/2025 19:57:52.0023] wlan: [42:F:DP] dp_rx_enable_mon_dest_fr[02/04/2025 19:57:58.1399] subsys-restart: subsys_start(): subsys_start:633, Setting state SUBSYS_ONLINE
[02/04/2025 19:57:58.1499] cnss[28]: INFO: QMI WLFW service connected, state: 0x11
[02/04/2025 19:57:58.1499] cnss[28]: INFO: device_id : 4356 mem mode : [0]
[02/04/2025 19:57:58.1999] cnss[28]: INFO: platform name: Cisco System, Inc. IPQ807x/C9166
[02/04/2025 19:57:58.1999] cnss[28]: INFO: Target capability: chip_id: 0x0, chip_family: 0x0, board_id: 0xff, soc_id: 0xffffffff, fw_version: 0x2405885e, fw_build_timestamp: 2023-07-11 00:30, otp_version: 0x0 eeprom_caldata_read_timeout 0s
[02/04/2025 19:57:58.1999] cnss_wlfw_bdf_dnld_send_sync:753 LOAD BDF initiated folder:[qcn9000/] bdf_type:[0x5] override:[0xaa]
[02/04/2025 19:57:58.1999] cnss[28]: INFO: Downloading BDF: qcn9000/bdwlan.baa, size: 131072
[02/04/2025 19:57:58.3199] cnss_wlfw_bdf_dnld_send_sync:753 LOAD BDF initiated folder:[qcn9000/] bdf_type:[0x6] override:[0xaa]
[02/04/2025 19:57:58.3199] cnss[28]: INFO: Downloading BDF: qcn9000/caldata_2.bin, size: 131072
[02/04/2025 19:57:59.1999] cnss[28]: INFO: Waiting for FW ready. Device: 0x1104, FW ready timeout: 15 seconds
[02/04/2025 19:57:59.2999] cnss[28]: INFO: FW ready received for device 0x1104
[02/04/2025 19:57:59.4099] cnss[28]: INFO: Sending mode message, mode: MISSION(0), state: 0x17
[*02/04/2025 19:57:52.0097] wlan: [42:I:ANY] dp_rx_pdev_mon_status_buffers_alloc: repleneshing mon status buffers...
[*02/04/2025 19:57:52.0124] wlan: [42:I:ANY] init_deinit_update_pdev_tgt_info: Pdev = 0 Number of peers = 418 vdevs = 18
[*02/04/2025 19:57:52.0125] wlan: [42:I:ANY] init_deinit_update_pdev_tgt_info: pdev id:1 wmi_handle:ffffffc052a7dc00
[*02/04/2025 19:57:52.0135] wlan: [42:F:DP] dp_rx_enable_mon_dest_frag: Feature DP_RX_MON_MEM_FRAG for mon_dest is disabled
[*02/04/2025 19:57:52.0205] wlan: [42:I:ANY] dp_rx_pdev_mon_status_buffers_alloc: repleneshing mon status buffers...
[*02/04/2025 19:57:52.0229] wlan: [42:I:ANY] init_deinit_update_pdev_tgt_info: Pdev = 1 Number of peers = 418 vdevs = 18
[*02/04/2025 19:57:52.1236] wlan: [42:I:ANY] copy_fw_abi_version_tlv: copy_fw_abi_version_tlv: INIT_CMD version: 1, 0, 0x5f414351, 0x4c4d, 0x0, 0x0
[*02/04/2025 19:57:52.3347] wlan: [42:I:ANY] dp_peer_map_attach_wifi3: dp_peer_map_attach_wifi3 max_peers 889, max_ast_index: 2064
[*02/04/2025 19:57:52.3360] wlan: [4252:I:ANY] ol_ath_update_wireless_modes: Wireless_modes = f97f9001 after update
[*02/04/2025 19:57:52.3363] wlan: [4252:I:ANY] acfg_attach: acfg_attach: 4594: Netlink socket created:ffffffc079a70c00
[*02/04/2025 19:57:52.3380] wlan: [0:I:ANY] ol_ath_twt_enable_complete_event_handler: twt enabled
[*02/04/2025 19:57:52.3382] wlan: [4252:I:ANY] ol_ath_configure_cong_ctrl_max_msdus: pdev_idx = 0 tx_desc_limit = 32768
[*02/04/2025 19:57:52.3400] wlan: [4252:I:ANY] ol_ath_update_wireless_modes: Wireless_modes = 680680c after update
[*02/04/2025 19:57:52.3401] wlan: [4252:I:ANY] ol_ath_pdev_regdmn_init: LDPC not supported in 5G HE CAP
[*02/04/2025 19:57:52.3409] wlan: [0:I:ANY] ol_ath_twt_enable_complete_event_handler: twt enabled
[*02/04/2025 19:57:52.3412] wlan: [4252:I:ANY] ol_ath_configure_cong_ctrl_max_msdus: pdev_idx = 1 tx_desc_limit = 32768
[*02/04/2025 19:57:52.3413] wlan: [4252:I:ANY] wlan_cfg80211_init: Number of 2G channels: 11
[*02/04/2025 19:57:52.3423] wlan: [4252:E:QLD] qld_register: Handle or address is NULL
[*02/04/2025 19:57:52.5074] wlan: [4252:I:ANY] [ol_ath_wifi_ssr]: ### SSR event 2 bus_type 0 ###
[*02/04/2025 19:57:54.2720] wlan: [4252:I:ANY] [ol_ath_wifi_ssr]: ### SSR event 3 bus_type 0 ###
[*02/04/2025 19:57:55.5844] wlan: [4252:D:dfs] WLAN_DEBUG_DFS1 : dfs_psoc_obj_create_notification: DFS obj attach to psoc successfully
[*02/04/2025 19:57:55.5945] wlan: [4252:F:ANY] dp_config_full_mon_mode: Configure full monitor mode val: 1
[*02/04/2025 19:57:55.6086] wlan: [4252:I:ANY] ol_target_init_complete: CDP soc attach success
[*02/04/2025 19:57:55.6101] wlan: [42:D:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_agile_soc_obj_init: dfs->dfs_psoc_idx: 0
[*02/04/2025 19:57:55.6102] wlan: [42:D:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_agile_soc_obj_init: dfs_soc_obj->num_dfs_privs: 1
[*02/04/2025 19:57:55.6112] wlan: [42:I:ANY] init_deinit_update_pdev_tgt_info: pdev id:0 wmi_handle:ffffffc052129c00
[*02/04/2025 19:57:55.6128] wlan: [42:F:DP] dp_rx_enable_mon_dest_frag: Feature DP_RX_MON_MEM_FRAG for mon_dest is disabled
[*02/04/2025 19:57:55.6199] wlan: [42:I:ANY] dp_rx_pdev_mon_status_buffers_alloc: repleneshing mon status buffers...
[*02/04/2025 19:57:55.6222] wlan: [42:I:ANY] init_deinit_update_pdev_tgt_info: Pdev = 0 Number of peers = 417 vdevs = 17
[*02/04/2025 19:57:55.7225] wlan: [42:I:ANY] copy_fw_abi_version_tlv: copy_fw_abi_version_tlv: INIT_CMD version: 1, 0, 0x5f414351, 0x4c4d, 0x0, 0x0
[*02/04/2025 19:57:56.1597] wlan: [42:I:ANY] dp_peer_map_attach_wifi3: dp_peer_map_attach_wifi3 max_peers 451, max_ast_index: 1040
[*02/04/2025 19:57:56.1610] wlan: [4252:I:ANY] ol_ath_update_wireless_modes: Wireless_modes = f97f9001 after update
[*02/04/2025 19:57:56.1629] wlan: [4252:I:ANY] ol_ath_pri20_cfg_blockchanlist_parse: cfg block channel list is empty
[*02/04/2025 19:57:56.1630] wlan: [4252:I:ANY] ol_ath_configure_cong_ctrl_max_msdus: pdev_idx = 0 tx_desc_limit = 32768
[*02/04/2025 19:57:56.1637] wlan: [0:I:ANY] ol_ath_twt_enable_complete_event_handler: twt enabled
[*02/04/2025 19:57:56.1640] wlan: [4252:E:QLD] qld_register: Handle or address is NULL
[*02/04/2025 19:57:56.3084] wlan: [4252:I:ANY] [ol_ath_wifi_ssr]: ### SSR event 2 bus_type 0 ###
[*02/04/2025 19:57:59.2001] wlan: [4252:I:ANY] [ol_ath_wifi_ssr]: ### SSR event 3 bus_type 0 ###
[*02/04/2025 19:57:59.5259] wlan: [4252:D:dfs] WLAN_DEBUG_DFS1 : dfs_psoc_obj_create_notification: DFS obj attach to psoc successfully
[*02/04/2025 19:57:59.5361] wlan: [4252:F:ANY] dp_config_full_mon_mode: Configure full monitor mode val: 1
[*02/04/2025 19:57:59.5494] wlan: [4252:I:ANY] ol_target_init_complete: CDP soc attach success
[*02/04/2025 19:57:59.5511] wlan: [42:D:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_agile_soc_obj_init: dfs->dfs_psoc_idx: 0
[*02/04/2025 19:57:59.5511] wlan: [42:D:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_agile_soc_obj_init: dfs_soc_obj->num_dfs_privs: 1
[*02/04/2025 19:57:59.5522] wlan: [42:I:ANY] init_deinit_update_pdev_tgt_info: pdev id:0 wmi_handle:ffffffc0483d7400
[*02/04/2025 19:57:59.5533] wlan: [42:F:DP] dp_rx_enable_mon_dest_frag: Feature DP_RX_MON_MEM_FRAG for mon_dest is disabled
[*02/04/2025 19:57:59.5604] wlan: [42:I:ANY] dp_rx_pdev_mon_status_buffers_alloc: repleneshing mon status buffers...
[*02/04/2025 19:57:59.5628] wlan: [42:I:ANY] init_deinit_update_pdev_tgt_info: Pdev = 0 Number of peers = 417 vdevs = 17
[*02/04/2025 19:57:59.6630] wlan: [42:I:ANY] copy_fw_abi_version_tlv: copy_fw_abi_version_tlv: INIT_CMD version: 1, 0, 0x5f414351, 0x4c4d, 0x0, 0x0
[*02/04/2025 19:58:00.0813] wlan: [42:I:ANY] dp_peer_map_attach_wifi3: dp_peer_map_attach_wifi3 max_peers 451, max_ast_index: 1040
[*02/04/2025 19:58:00.0825] wlan: [4252:I:ANY] ol_ath_update_wireless_modes: Wireless_modes = fffff80d after update
[*02/04/2025 19:58:00.0825] wlan: [4252:I:ANY] ol_ath_update_ext_caps: Both bands supported case 3, default to populate 5G HE caps
[*02/04/2025 19:58:00.0826] wlan: [4252:I:ANY] ol_ath_pdev_regdmn_init: Band 2G or 5G check failed. LDPC is not updated. Supported bands = 3
[*02/04/2025 19:58:00.0849] wlan: [4252:I:ANY] ol_ath_pri20_cfg_blockchanlist_parse: cfg block channel list is empty
[*02/04/2025 19:58:00.0849] wlan: [4252:I:ANY] ol_ath_configure_cong_ctrl_max_msdus: pdev_idx = 0 tx_desc_limit = 32768
[*02/04/2025 19:58:00.0850] wlan: [4252:I:ANY] wlan_cfg80211_init: Number of 2G channels: 11
[*02/04/2025 19:58:00.0859] wlan: [0:I:ANY] ol_ath_twt_enable_complete_event_handler: twt enabled
[*02/04/2025 19:58:00.0861] wlan: [4252:E:QLD] qld_register: Handle or address is NULL
[*02/04/2025 19:58:00.0862] wlan: [4252:I:ANY] init_ath_pci_3_0: 6ath_ol_pci_wifi3.0 : (Atheros/multi-bss)
[*02/04/2025 19:58:02.8612] wlan: [5866:E:MBSSIE] osif_mbssid_sanity_check: mbssid sanity required for AP VAPs only
[*02/04/2025 19:58:03.0680] wlan: [5956:E:MBSSIE] ieee80211_ucfg_set_txvap: VAP0 is either smart monitor 0 or special vap 1, not configuring
[*02/04/2025 19:58:04.2256] chatter: Device wired0 notify up link DOWN
[*02/04/2025 19:58:04.4680] In write handler 'run' for 'srcr2/srcr_wireless_iface_enable :: Script':
[*02/04/2025 19:58:04.4681] no element named 'es3'
[*02/04/2025 19:58:04.4681] no element named 'm_es3'
[*02/04/2025 19:58:04.9570] ip6_port srcr2, ip6local ::, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 2(slaac)
[ OK ] Started Security Auditing Service.
[*02/04/2025 19:58:07.8938] pid 4201's current affinity mask: f
[*02/04/2025 19:58:07.8938] pid 4201's new affinity mask: 1
[*02/04/2025 19:58:08.0479] chatter: Device wired0 notify state change link UP
[*02/04/2025 19:58:08.1240] CW9166I_RW_ctl_2G.bin
[*02/04/2025 19:58:08.2014] CW9166I_RW_pine_ctl_2G.bin
[*02/04/2025 19:58:08.3025] CW9166I_RW_pine_ctl_5G.bin
[*02/04/2025 19:58:08.4375] CW9166I_RW_P_ctl_5G.bin
[*02/04/2025 19:58:08.4832] CW9166I_RW_S_ctl_5G.bin
[*02/04/2025 19:58:08.9746] chpasswd: password for user changed
[*02/04/2025 19:58:09.0089] device aptrace0 entered promiscuous mode
Username: [*02/04/2025 19:58:09.1508] pid 8418's current affinity mask: f
[*02/04/2025 19:58:09.1508] pid 8418's new affinity mask: 3
[*02/04/2025 19:58:09.5591] DOT11_TXP[0]:Domain configured: 59 class:RW
[*02/04/2025 19:58:09.5594] DOT11_TXP[0]:wcp/dot11_tx_power_6g :: Dot11TxPowerConfig: Error opening input file:/radio_fw/WIFI_TXPWR_R6.csv
[*02/04/2025 19:58:09.6200] DOT11_TXP[0]:wcp/dot11_tx_power_6g :: Dot11TxPowerConfig: PWR TABLE /radio_fw/WIFI_TXPWR_R6.csv NOT LOADED for RW domain
[*02/04/2025 19:58:09.6201] DOT11_TXP[0]:wcp/dot11_tx_power_6g :: Dot11TxPowerConfig: TXPOWER CONFIG FAILURE
[*02/04/2025 19:58:09.6296] DOT11_TXP[0]:Regdb file: /radio_fw/CW9166I_power_table_mapping.txt
[*02/04/2025 19:58:09.6338] DOT11_TXP[0]:Domain configured: 59 class:RW
[*02/04/2025 19:58:09.6340] DOT11_TXP[0]:wcp/dot11_tx_power_6g_rad2 :: Dot11TxPowerConfig: Error opening input file:/radio_fw/WIFI_TXPWR_R6.csv
[*02/04/2025 19:58:09.6973] DOT11_TXP[0]:wcp/dot11_tx_power_6g_rad2 :: Dot11TxPowerConfig: PWR TABLE /radio_fw/WIFI_TXPWR_R6.csv NOT LOADED for RW domain
[*02/04/2025 19:58:09.6974] DOT11_TXP[0]:wcp/dot11_tx_power_6g_rad2 :: Dot11TxPowerConfig: TXPOWER CONFIG FAILURE
[*02/04/2025 19:58:09.7064] DOT11_TXP[0]:Regdb file: /radio_fw/CW9166I_power_table_mapping.txt
[*02/04/2025 19:58:09.7112] DOT11_TXP[1]:Domain configured: 59 class:RW
[*02/04/2025 19:58:09.7964] DOT11_TXP[1]:wcp/dot11_tx_power_5g :: Dot11TxPowerConfig: PWR TABLE /radio_fw/WIFI_TXPWR_R5.csv NOT LOADED for RW domain
[*02/04/2025 19:58:09.7965] DOT11_TXP[1]:wcp/dot11_tx_power_5g :: Dot11TxPowerConfig: TXPOWER CONFIG FAILURE
[*02/04/2025 19:58:09.8056] DOT11_TXP[1]:Regdb file: /radio_fw/CW9166I_power_table_mapping.txt
[*02/04/2025 19:58:09.8108] DOT11_TXP[0]:Domain configured: 58 class:RW
[*02/04/2025 19:58:09.8839] DOT11_TXP[0]:Regdb file: /radio_fw/CW9166I_power_table_mapping.txt
[*02/04/2025 19:58:09.9041] DOT11_TXP[2]:Domain configured: 59 class:RW
[*02/04/2025 19:58:09.9907] DOT11_TXP[2]:wcp/dot11_tx_power_5g_rad2 :: Dot11TxPowerConfig: PWR TABLE /radio_fw/WIFI_TXPWR_X5.csv NOT LOADED for RW domain
[*02/04/2025 19:58:09.9908] DOT11_TXP[2]:wcp/dot11_tx_power_5g_rad2 :: Dot11TxPowerConfig: TXPOWER CONFIG FAILURE
[*02/04/2025 19:58:10.0006] DOT11_TXP[2]:Regdb file: /radio_fw/CW9166I_power_table_mapping.txt
[*02/04/2025 19:58:10.3973] DOT11_DRV[3]: Skip Radio3, driver is not implemented - wcp/RadDrv3 :: Dot11AthDriverNL80211
[*02/04/2025 19:58:10.4780] ip6_port srcr2, ip6local fe80::560d:322b:7d5f:5b00, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:[02/04/2025 19:58:11.9999] Removing device for chan:LOOPBACK
[02/04/2025 19:58:12.0699] mhi_reset_data_chan rp (null) wp (null)
[02/04/2025 19:58:12.1399] mhi_test_rp_wp chan_name = DIAG rp (null) wp (null)
[02/04/2025 19:58:12.2299] mhi_test_rp_wp chan_name = DIAG rp (null) wp (null)
[02/04/2025 19:58:12.3299] mhi_reset_data_chan rp (null) wp (null)
[02/04/2025 19:58:12.4399] mhi_test_rp_wp chan_name = DIAG rp (null) wp (null)
[02/04/2025 19:58:12.5299] mhi_test_rp_wp chan_name = DIAG rp (null) wp (null)
[02/04/2025 19:58:12.6299] subsys-restart: subsystem_restart_dev(): Restart sequence requested for qcom_q6v5_wcss, restart_level = RELATED.
[02/04/2025 19:58:12.7499] subsys-restart: __subsystem_restart_dev(): Restarting qcom_q6v5_wcss [level=RELATED]!
[02/04/2025 19:58:12.8899] subsys-restart: __subsystem_restart_dev(): **************track->p_state 0 dev->track.state=1*****************
[02/04/2025 19:58:13.0199] subsys-restart: __subsystem_restart_dev(): __subsystem_restart_dev:1098, Setting state SUBSYS_CRASHED
[02/04/2025 19:58:13.1499] Removing device for chan:IPCR
[02/04/2025 19:58:13.2799] mhi_reset_data_chan rp ffffff80103f5080 wp ffffff80103f5070
[02/04/2025 19:58:13.3399] mhi_reset_data_chan rp ffffff80103f3060 wp ffffff80103f3060
[02/04/2025 19:58:13.4299] subsys-restart: subsystem_restart_wq_func(): [kworker/0:1:426]: Starting restart sequence for qcom_q6v5_wcss
[02/04/2025 19:58:13.4299] cnss[27]: INFO: QMI WLFW service disconnected, state: 0x906
[*02/04/2025 19:58:10[02/04/2025 19:58:13.8099] subsys-restart: subsystem_restart_dev(): Restart sequence requested for QCN9000_PCI0, restart_level = RELATED.
[02/04/2025 19:58:13.8399] subsys-restart: __subsystem_restart_dev(): Restarting QCN9000_PCI0 [level=RELATED]!
[02/04/2025 19:58:13.8799] subsys-restart: subsystem_shutdown(): [kworker/0:1:426]: Shutting down qcom_q6v5_wcss
[02/04/2025 19:58:13.9099] subsys-restart: subsystem_shutdown(): subsystem_shutdown:553, Setting state SUBSYS_OFFLINE
[02/04/2025 19:58:13.9099] subsys-restart: subsystem_restart_wq_func(): subsystem_restart_wq_func:994, Setting state SUBSYS_RESTARTING
[02/04/2025 19:58:13.9699] cnss[2]: INFO: QMI WLFW service disconnected, state: 0x0
[02/04/2025 19:58:14.4699] subsys-restart: __subsystem_restart_dev(): **************track->p_state 0 dev->track.state=1*****************
[02/04/2025 19:58:14.5699] subsys-restart: __subsystem_restart_dev(): __subsystem_restart_dev:1098, Setting state SUBSYS_CRASHED
.5284] CRIT-MeshChannelMgr[2]: Failed to initialize the channel list
[*02/04/2025 19:58:10.5284] CRIT-MeshChannelMgr[2]: Failed[02/04/2025 19:58:14.9099] subsys-restart: subsystem_powerup(): [kworker/0:1:426]: Powering up qcom_q6v5_wcss
to initialize the current channel
[*02/04/2025 19:58:10.5362] DOT11_TXP[1]:The channel list is empty for slot - 1 for the conf[02/04/2025 19:58:15.3299] subsys-restart: subsystem_powerup(): subsystem_powerup:593, Setting state SUBSYS_ONLINE
[02/04/2025 19:58:15.3399] cnss[2]: INFO: Waiting for FW ready. Device: 0xfffe, FW ready timeout: 15 seconds
[02/04/2025 19:58:15.4599] cnss[2]: INFO: QMI WLFW service connected, state: 0x1
[02/04/2025 19:58:15.5799] cnss[2]: INFO: device_id : 65534 mem mode : [0]
[02/04/2025 19:58:15.6599] cnss[2]: INFO: platform name: Cisco System, Inc. IPQ807x/C9166
[02/04/2025 19:58:15.7399] cnss[2]: INFO: Target capability: chip_id: 0x0, chip_family: 0x0, board_id: 0xff, soc_id: 0xffffffff, fw_version: 0x2405885e, fw_build_timestamp: 2023-07-11 00:20, otp_version: 0x0 eeprom_caldata_read_timeout 0s
[02/04/2025 19:58:15.9599] cnss_wlfw_bdf_dnld_send_sync:753 LOAD BDF initiated folder:[] bdf_type:[0x5] override:[0x302]
[02/04/2025 19:58:16.0899] cnss_wlfw_load_bdf:605 LOAD BDF initiated folder:[IPQ8074/] bdf_type:[0x0] override:[0x302]
[02/04/2025 19:58:16.2199] cnss[2]: INFO: Using Boardid from bootargs:0x302
[02/04/2025 19:58:16.3399] cnss[2]: INFO: BDF location : 0x4b0c0000
[02/04/2025 19:58:16.4199] cnss[2]: INFO: BDF IPQ8074/bdwlan.b302 size 131072
[02/04/2025 19:58:16.4899] cnss_wlfw_bdf_dnld_send_sync:753 LOAD BDF initiated folder:[] bdf_type:[0x6] override:[0x302]
[02/04/2025 19:58:16.5699] cnss_wlfw_load_bdf:605 LOAD BDF initiated folder:[IPQ8074/] bdf_type:[0x2] override:[0x302]
[02/04/2025 19:58:16.6999] cnss[2]: INFO: per device BDF location : 0x4b0e0000
[02/04/2025 19:58:16.8199] cnss[2]: INFO: CALDATA IPQ8074/caldata.bin size 131072 offset 0x20000
[02/04/2025 19:58:16.9999] cnss[2]: INFO: FW ready received for device 0xfffe
[02/04/2025 19:58:17.0299] cnss[2]: INFO: Sending mode message, mode: MISSION(0), state: 0x7
igured reg-domain
[*02/04/2025 19:58:10.5363] DOT11_DRV[1]: vendor_set_slot_capability: slot 1, radio_service_type 0
[*02/04/2025 19:58:10.5363] DOT11_DRV[1]: Init Radio1
[*02/04/2025 19:58:10.5565] DOT11_TXP[1]:The channel list is empty for slot - 1 for the configured reg-domain
[*02/04/2025 19:58:10.5566] DOT11_DRV[1]: set_channel Channel set to 36
[*02/04/2025 19:58:10.5596] DOT11_DRV[4]: Init Radio4
[*02/04/2025 19:58:10.5856] DOT11_DRV[4]: wcp/AuxRadDrv4 :: Dot11BaseDriver: Failed opening CTL binary file:/lib/firmware/CTL/pine_ctl_6G.bin
[*02/04/2025 19:58:10.5857] DOT11_DRV[4]: Load power table failed, not sending ctl table
[*02/04/2025 19:58:10.5936] CRIT-MeshChannelMgr[1]: Failed to initialize the channel list
[*02/04/2025 19:58:10.5936] CRIT-MeshChannelMgr[1]: Failed to initialize the current channel
[*02/04/2025 19:58:10.5957] DOT11_DRV[3]: vendor_set_slot_capability: slot 3, radio_s[02/04/2025 19:58:18.0899] subsys-restart: subsystem_restart_wq_func(): [kworker/0:1:426]: Restart sequence for qcom_q6v5_wcss completed.
[02/04/2025 19:58:18.1599] subsys-restart: subsystem_restart_wq_func(): subsystem_restart_wq_func:1033, Setting state SUBSYS_NORMAL
[02/04/2025 19:58:18.1599] subsys-restart: subsystem_restart_wq_func(): [kworker/2:0:19]: Starting restart sequence for QCN9000_PCI0
[02/04/2025 19:58:18.1599] subsys-restart: subsystem_shutdown(): [kworker/2:0:19]: Shutting down QCN9000_PCI0
[02/04/2025 19:58:18.1599] cnss[27]: INFO: Skipping shutdown to wait for dump collection
[02/04/2025 19:58:18.1599] subsys-restart: subsystem_shutdown(): subsystem_shutdown:553, Setting state SUBSYS_OFFLINE
[02/04/2025 19:58:18.1599] subsys-restart: subsystem_restart_wq_func(): subsystem_restart_wq_func:994, Setting state SUBSYS_RESTARTING
[02/04/2025 19:58:18.9199] In DW:arch_teardown_msi_irqs
[02/04/2025 19:58:19.0399] pcie_destroy_qgic_msi_irq:pos=0 irq=115, dev->msi[0]=115
[02/04/2025 19:58:19.1099] pcie_destroy_qgic_msi_irq:pos=1 irq=116, dev->msi[0]=115
[02/04/2025 19:58:19.1999] pcie_destroy_qgic_msi_irq:pos=2 irq=117, dev->msi[0]=115
[02/04/2025 19:58:19.2799] pcie_destroy_qgic_msi_irq:pos=3 irq=118, dev->msi[0]=115
[02/04/2025 19:58:19.3699] pcie_destroy_qgic_msi_irq:pos=4 irq=119, dev->msi[0]=115
[02/04/2025 19:58:19.4499] pcie_destroy_qgic_msi_irq:pos=5 irq=120, dev->msi[0]=115
[02/04/2025 19:58:19.5399] pcie_destroy_qgic_msi_irq:pos=6 irq=121, dev->msi[0]=115
[02/04/2025 19:58:19.6299] pcie_destroy_qgic_msi_irq:pos=7 irq=122, dev->msi[0]=115
[02/04/2025 19:58:19.7199] pcie_destroy_qgic_msi_irq:pos=8 irq=123, dev->msi[0]=115
[02/04/2025 19:58:19.8099] pcie_destroy_qgic_msi_irq:pos=9 irq=124, dev->msi[0]=115
[02/04/2025 19:58:19.8999] pcie_destroy_qgic_msi_irq:pos=10 irq=125, dev->msi[0]=115
[02/04/2025 19:58:19.9899] pcie_destroy_qgic_msi_irq:pos=11 irq=126, dev->msi[0]=115
[02/04/2025 19:58:20.0699] pcie_destroy_qgic_msi_irq:pos=12 irq=127, dev->msi[0]=115
[02/04/2025 19:58:20.1599] pcie_destroy_qgic_msi_irq:pos=13 irq=128, dev->msi[0]=115
[02/04/2025 19:58:20.2499] pcie_destroy_qgic_msi_irq:pos=14 irq=129, dev->msi[0]=115
[02/04/2025 19:58:20.3399] pcie_destroy_qgic_msi_irq:pos=15 irq=130, dev->msi[0]=115
[02/04/2025 19:58:20.4599] subsys-restart: subsystem_powerup(): [kworker/2:0:19]: Powering up QCN9000_PCI0
[02/04/2025 19:58:20.5299] arch_setup_msi_irqs
[02/04/2025 19:58:20.6299] pcie_create_qgic_msi_irq:pos=0 irq=115, dev->msi[0]=115 115
[02/04/2025 19:58:20.6799] pcie_create_qgic_msi_irq:pos=1 irq=116, dev->msi[0]=115 116
[02/04/2025 19:58:20.7699] pcie_create_qgic_msi_irq:pos=2 irq=117, dev->msi[0]=115 117
[02/04/2025 19:58:20.8699] pcie_create_qgic_msi_irq:pos=3 irq=118, dev->msi[0]=115 118
[02/04/2025 19:58:20.9599] pcie_create_qgic_msi_irq:pos=4 irq=119, dev->msi[0]=115 119
[02/04/2025 19:58:21.0499] pcie_create_qgic_msi_irq:pos=5 irq=120, dev->msi[0]=115 120
[02/04/2025 19:58:21.1399] pcie_create_qgic_msi_irq:pos=6 irq=121, dev->msi[0]=115 121
[02/04/2025 19:58:21.2299] pcie_create_qgic_msi_irq:pos=7 irq=122, dev->msi[0]=115 122
[02/04/2025 19:58:21.3199] pcie_create_qgic_msi_irq:pos=8 irq=123, dev->msi[0]=115 123
[02/04/2025 19:58:21.4199] pcie_create_qgic_msi_irq:pos=9 irq=124, dev->msi[0]=115 124
[02/04/2025 19:58:21.5099] pcie_create_qgic_msi_irq:pos=10 irq=125, dev->msi[0]=115 125
[02/04/2025 19:58:21.5999] pcie_create_qgic_msi_irq:pos=11 irq=126, dev->msi[0]=115 126
[02/04/2025 19:58:21.6899] pcie_create_qgic_msi_irq:pos=12 irq=127, dev->msi[0]=115 127
[02/04/2025 19:58:21.7899] pcie_create_qgic_msi_irq:pos=13 irq=128, dev->msi[0]=115 128
[02/04/2025 19:58:21.8799] pcie_create_qgic_msi_irq:pos=14 irq=129, dev->msi[0]=115 129
[02/04/2025 19:58:21.9799] pcie_create_qgic_msi_irq:pos=15 irq=130, dev->msi[0]=115 130
ervice_type 0
[*02/04/2025 19:58:10.6060] DOT11_DRV[0]: vendor_set_slot_capability: slot 0, radio_service_type 0
[*02/04/2025 [02/04/2025 19:58:22.2299] subsys-restart: subsystem_powerup(): subsystem_powerup:593, Setting state SUBSYS_ONLINE
[02/04/2025 19:58:22.2899] cnss[27]: INFO: Waiting for FW ready. Device: 0x1104, FW ready timeout: 15 seconds
[02/04/2025 19:58:22.2899] cnss[27]: INFO: QMI WLFW service connected, state: 0x11
[02/04/2025 19:58:22.2899] cnss[27]: INFO: device_id : 4356 mem mode : [0]
[02/04/2025 19:58:22.2999] cnss[27]: INFO: platform name: Cisco System, Inc. IPQ807x/C9166
[02/04/2025 19:58:22.2999] cnss[27]: INFO: Target capability: chip_id: 0x0, chip_family: 0x0, board_id: 0xff, soc_id: 0xffffffff, fw_version: 0x2405885e, fw_build_timestamp: 2023-07-11 00:30, otp_version: 0x0 eeprom_caldata_read_timeout 0s
[02/04/2025 19:58:22.2999] cnss_wlfw_bdf_dnld_send_sync:753 LOAD BDF initiated folder:[qcn9000/] bdf_type:[0x5] override:[0xab]
[02/04/2025 19:58:22.2999] cnss[27]: INFO: Downloading BDF: qcn9000/bdwlan.bab, size: 131072
[02/04/2025 19:58:22.4199] cnss_wlfw_bdf_dnld_send_sync:753 LOAD BDF initiated folder:[qcn9000/] bdf_type:[0x6] override:[0xab]
[02/04/2025 19:58:22.4199] cnss[27]: INFO: Downloading BDF: qcn9000/caldata_1.bin, size: 131072
[02/04/2025 19:58:23.4099] cnss[27]: INFO: FW ready received for device 0x1104
[02/04/2025 19:58:23.5099] cnss[27]: INFO: Sending mode message, mode: MISSION(0), state: 0x17
19:58:10.6060] DOT11_DRV[0]: Init Radio0
[*02/04/2025 19:58:10.6192] DOT11_DRV[0]: set_channel Channel set to 6
[*02/04/2025 19:58:10.6222] DOT11_TXP[2]:The channel list is empty for slot - 2 for the configured reg-domain
[*02/04/2025 19:58:10.6223] DOT11_DRV[2]: vendor_set_slot_capability: slot 2, radio_service_type 0
[*02/04/2025 19:58:10.6224] DOT11_DRV[2]: Init Radio2
[*02/04/2025 19:58:10.6578] DOT11_DRV[2]: wcp/RadDrv2 :: Dot11AthDriverNL80211: Failed opening CTL binary file:/lib/firmware/CTL/ctl_6G.bin
[*02/04/2025 19:58:10.6578] DOT11_DRV[2]: Load power table failed, not sending ctl table
[*02/04/2025 19:58:10.6586] DOT11_TXP[2]:The channel list is empty for slot - 2 for the configured reg-domain
[*02/04/2025 19:58:10.6588] DOT11_DRV[2]: set_channel Channel set to 5
[*02/04/2025 19:58:10.6711] DOT11_DRV[[02/04/2025 19:58:24.4999] subsys-restart: subsystem_restart_wq_func(): [kworker/2:0:19]: Restart sequence for QCN9000_PCI0 completed.
[02/04/2025 19:58:24.5599] subsys-restart: subsystem_restart_wq_func(): subsystem_restart_wq_func:1033, Setting state SUBSYS_NORMAL
[02/04/2025 19:58:24.7299] ieee80211_chan2mode: 9 callbacks suppressed
4]: off_channel timeout but no req in progress
[*02/04/2025 19:58:11.4336] DOT11_DRV[0]: set_channel Channel set to 1
[*02/04/2025 19:58:11.4433] DOT11_DRV[0]: set_channel Channel set to 1
[*02/04/2025 19:58:11.4456] DOT11_DRV[0]: Channel set to 1, width 20
[*02/04/2025 19:58:11.4456] DOT11_DRV[0]: Channel set to 1 skipped
[*02/04/2025 19:58:11.5320] DOT11_DRV[0]: Channel set to 1, width 20
[*02/04/2025 19:58:11.5320] DOT11_DRV[0]: Channel set to 1 skipped
[*02/04/2025 19:58:11.5588] DOT11_TXP[1]:The channel list is empty for slot - 1 for the configured reg-domain
[*02/04/2025 19:58:11.5601] DOT11_TXP[1]:The channel list is empty for slot - 1 for the configured reg-domain
[*02/04/2025 19:58:11.5607] DOT11_TXP[1]:The channel list is empty for slot - 1 for the configured reg-domain
[*02/04/2025 19:58:11.5608] DOT11_DRV[1]: set_channel Channel set to 36
[*02/04/2025 19:58:11.5637] DOT11_TXP[1]:The channel list is empty for slot - 1 for the configured reg-domain
[*02/04/2025 19:58:11.5638] DOT11_DRV[1]: set_channel Channel set to 36
[*02/04/2025 19:58:11.5745] DOT11_DRV[1]: Channel set to 36, width 20
[*02/04/2025 19:58:11.5746] DOT11_DRV[1]: Channel set to 36 skipped
[*02/04/2025 19:58:11.5769] DOT11_TXP[1]:The channel list is empty for slot - 1 for the configured reg-domain
[*02/04/2025 19:58:11.5787] DOT11_DRV[1]: Channel set to 36, width 20
[*02/04/2025 19:58:11.5787] DOT11_DRV[1]: Channel set to 36 skipped
[*02/04/2025 19:58:11.5965] DOT11_DRV[2]: 6G band on Radio 2 is not supported in regulatory domain 59 on AP type 132
[*02/04/2025 19:58:11.7212] DOT11_TXP[1]:wcp/dot11_tx_power_5g :: Dot11TxPowerConfig: PWR TABLE /radio_fw/WIFI_TXPWR_R5.csv NOT LOADED for RW domain
[*02/04/2025 19:58:11.7212] DOT11_TXP[1]:wcp/dot11_tx_power_5g :: Dot11TxPowerConfig: TXPOWER CONFIG FAILURE
[*02/04/2025 19:58:11.8400] DOT11_TXP[2]:wcp/dot11_tx_power_5g_rad2 :: Dot11TxPowerConfig: PWR TABLE /radio_fw/WIFI_TXPWR_X5.csv NOT LOADED for RW domain
[*02/04/2025 19:58:11.8401] DOT11_TXP[2]:wcp/dot11_tx_power_5g_rad2 :: Dot11TxPowerConfig: TXPOWER CONFIG FAILURE
[*02/04/2025 19:58:11.8403]
[*02/04/2025 19:58:11.8403] **** XOR 5G_6G radio band switching started ****
[*02/04/2025 19:58:11.9020] wlan: [8557:I:ANY] ol_ath_set_config_param: Setting Co-hosted mode
[*02/04/2025 19:58:11.9128] DOT11_DRV[2]: wcp/RadDrv2 :: Dot11AthDriverNL80211: MBSSID is disabled on slot 2
[*02/04/2025 19:58:11.9129] DOT11_TXP[1]:The channel list is empty for slot - 1 for the configured reg-domain
[*02/04/2025 19:58:11.9129] DOT11_CFG[1]: Update validated lowband channel:36, chanwidth:20, extChan:0
[*02/04/2025 19:58:11.9162] DOT11_TXP[2]:The channel list is empty for slot - 2 for the configured reg-domain
[*02/04/2025 19:58:11.9173] DOT11_TXP[2]:The channel list is empty for slot - 2 for the configured reg-domain
[*02/04/2025 19:58:11.9178] DOT11_TXP[2]:The channel list is empty for slot - 2 for the configured reg-domain
[*02/04/2025 19:58:11.9179] DOT11_DRV[2]: set_channel Channel set to 100
[*02/04/2025 19:58:11.9182] DOT11_TXP[2]:The channel list is empty for slot - 2 for the configured reg-domain
[*02/04/2025 19:58:11.9182] DOT11_DRV[2]: set_channel Channel set to 100
[*02/04/2025 19:58:11.9184] DOT11_DRV[2]: Channel set to 100, width 20
[*02/04/2025 19:58:11.9185] DOT11_DRV[2]: Channel set to 100 skipped
[*02/04/2025 19:58:11.9216] DOT11_TXP[2]:The channel list is empty for slot - 2 for the configured reg-domain
[*02/04/2025 19:58:11.9220] DOT11_DRV[2]: Channel set to 100, width 20
[*02/04/2025 19:58:11.9221] DOT11_DRV[2]: Channel set to 100 skipped
[*02/04/2025 19:58:12.0109] wlan: [3181:I:ANY] [ol_ath_wifi_ssr]: ### SSR event 9 bus_type 0 ###
[*02/04/2025 19:58:13.1561] wlan: [1192:I:ANY] [ol_ath_wifi_ssr]: ### SSR event 9 bus_type 1 ###
[*02/04/2025 19:58:13.6783] wlan: [426:I:ANY] [ol_ath_wifi_ssr]: ### SSR event 0 bus_type 1 ###
[*02/04/2025 19:58:13.6814] wlan: [426:I:ANY] Resetting the radio
[*02/04/2025 19:58:14.0277]
[*02/04/2025 19:58:14.0278] +=== Store Radio Firmware ramdump to q6dump.bin
[*02/04/2025 19:58:14.9252] 1536+1 records in
[*02/04/2025 19:58:14.9252] 1536+1 records out
[*02/04/2025 19:58:15.0022]
[*02/04/2025 19:58:15.0022] +=== Cleaned up Radio Firmware ramdump q6dump.bin
[*02/04/2025 19:58:15.0028] DOT11_DRV[1]: *** FW crash 0 times in the last 5 seconds, total 1 times ***
[*02/04/2025 19:58:17.0554] AP is in good condition, BLE is off
[*02/04/2025 19:58:17.0554] Set radio wifi2 power 4 antenna chain 4 15 0
[*02/04/2025 19:58:17.0554] Set radio wifi0 power 4 antenna chain 4 15 0
[*02/04/2025 19:58:17.0554] Set radio wifi1 power 4 antenna chain 4 15 0
[*02/04/2025 19:58:17.0554] set_sys_cond_state: condition good state 1
[*02/04/2025 19:58:17.1306] wlan: [6:F:DP] dp_rx_enable_mon_dest_frag: Feature DP_RX_MON_MEM_FRAG for mon_dest is disabled
[*02/04/2025 19:58:17.1412] wlan: [6:F:DP] dp_rx_enable_mon_dest_frag: Feature DP_RX_MON_MEM_FRAG for mon_dest is disabled
[*02/04/2025 19:58:18.1647] wlan: [19:I:ANY] [ol_ath_wifi_ssr]: ### SSR event 0 bus_type 0 ###
[*02/04/2025 19:58:18.1652] wlan: [19:I:ANY] Resetting the radio
[*02/04/2025 19:58:18.2324] wlan: [19:E:MBSSIE] ieee80211_mbssid_update_mbssie_cache: Not AP mode. Return
[*02/04/2025 19:58:18.3310]
[*02/04/2025 19:58:18.3310] +=== Store Radio Firmware ramdump to q6dump.bin
[*02/04/2025 19:58:18.9221] 1041+3 records in
[*02/04/2025 19:58:18.9221] 1041+3 records out
[*02/04/2025 19:58:19.0626]
[*02/04/2025 19:58:19.0626] +=== Cleaned up Radio Firmware ramdump q6dump.bin
[*02/04/2025 19:58:19.1129] DOT11_DRV[2]: *** FW crash 0 times in the last 9 seconds, total 1 times ***
[*02/04/2025 19:58:19.1231] DOT11_DRV[1]: Init Radio1
[*02/04/2025 19:58:19.1360] DOT11_TXP[1]:The channel list is empty for slot - 1 for the configured reg-domain
[*02/04/2025 19:58:19.1361] DOT11_DRV[1]: set_channel Channel set to 36
[*02/04/2025 19:58:19.1477] iwpriv apr1v0 qdf_cv_lvl 2555904
[*02/04/2025 19:58:19.1565] iwpriv apr1v0 qdf_cv_lvl 2555912
[*02/04/2025 19:58:19.1750] DOT11_DRV[0]: Init Radio0
[*02/04/2025 19:58:19.3924] DOT11_DRV[0]: set_channel Channel set to 1
[*02/04/2025 19:58:19.3951] iwpriv apr0v0 qdf_cv_lvl 2555904
[*02/04/2025 19:58:19.4677] iwpriv apr0v0 qdf_cv_lvl 2555912
[*02/04/2025 19:58:23.6427] wlan: [6:F:DP] dp_rx_enable_mon_dest_frag: Feature DP_RX_MON_MEM_FRAG for mon_dest is disabled
[*02/04/2025 19:58:24.7272]
[*02/04/2025 19:58:24.7272] **** XOR 5G_6G radio band switching ended ****
[*02/04/2025 19:58:24.7273]
[*02/04/2025 19:58:24.7379] DOT11_DRV[2]: Init Radio2
[*02/04/2025 19:58:24.7429] wlan: [8372:I:ANY] ol_ath_ucfg_set_country: ol_ath_ucfg_set_country: Unable to set country code
[*02/04/2025 19:58:24.8522] wlan: [8372:I:ANY] ieee80211_chan2mode: ieee80211_chan2mode: cannot map channel to mode; freq 0 flags 0x0
[*02/04/2025 19:58:24.8684] wlan: [8372:I:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_init_precac_list: ieee=114 bw=160
[*02/04/2025 19:58:24.8684] wlan: [8372:I:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_init_precac_list: ieee=134 bw=40
[*02/04/2025 19:58:24.8684] wlan: [8372:I:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_init_precac_list: ieee=140 bw=20
[*02/04/2025 19:58:24.8698] wlan: [8372:I:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_init_precac_list: ieee=114 bw=160
[*02/04/2025 19:58:24.8698] wlan: [8372:I:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_init_precac_list: ieee=134 bw=40
[*02/04/2025 19:58:24.8698] wlan: [8372:I:dfs] WLAN_DEBUG_DFS_ALWAYS : dfs_init_precac_list: ieee=140 bw=20
[*02/04/2025 19:58:24.8708] DOT11_DRV[2]: wcp/RadDrv2 :: Dot11AthDriverNL80211: Failed opening CTL binary file:/lib/firmware/CTL/ctl_6G.bin
[*02/04/2025 19:58:24.8708] DOT11_DRV[2]: Load power table failed, not sending ctl table
[*02/04/2025 19:58:24.8710] wlan: [8372:I:ANY] ol_ath_vap_set_param: HE AUTORATE GI LTF 0x207
[*02/04/2025 19:58:24.8712] wlan: [8372:I:ANY] ol_ath_vap_set_param: HE AUTORATE GI LTF 0x207
[*02/04/2025 19:58:24.8713] wlan: [8372:I:ANY] ol_ath_vap_set_param: HE AUTORATE GI LTF 0x207
[*02/04/2025 19:58:24.8714] wlan: [8372:I:ANY] ol_ath_vap_set_param: HE AUTORATE GI LTF 0x207
[*02/04/2025 19:58:24.8715] wlan: [8372:I:ANY] ol_ath_vap_set_param: HE AUTORATE GI LTF 0x207
[*02/04/2025 19:58:24.8716] wlan: [8372:I:ANY] ol_ath_vap_set_param: HE AUTORATE GI LTF 0x207
[*02/04/2025 19:58:24.8717] wlan: [8372:I:ANY] ol_ath_vap_set_param: HE AUTORATE GI LTF 0x207
[*02/04/2025 19:58:24.8718] wlan: [8372:I:ANY] ol_ath_vap_set_param: HE AUTORATE GI LTF 0x207
[*02/04/2025 19:58:24.8719] wlan: [8372:I:ANY] ol_ath_vap_set_param: HE AUTORATE GI LTF 0x207
[*02/04/2025 19:58:24.8720] wlan: [8372:I:ANY] ol_ath_vap_set_param: HE AUTORATE GI LTF 0x207
[*02/04/2025 19:58:24.8721] wlan: [8372:I:ANY] ol_ath_vap_set_param: HE AUTORATE GI LTF 0x207
[*02/04/2025 19:58:24.8722] wlan: [8372:I:ANY] ol_ath_vap_set_param: HE AUTORATE GI LTF 0x207
[*02/04/2025 19:58:24.8728] DOT11_TXP[2]:The channel list is empty for slot - 2 for the configured reg-domain
[*02/04/2025 19:58:24.8729] DOT11_DRV[2]: set_channel Channel set to 100
[*02/04/2025 19:58:24.8730] wlan: [8372:I:dfs] vdev[0]: Mgt Rate:6000(kbps)
[*02/04/2025 19:58:24.8730] wlan: [8372:I:dfs] vdev[1]: Mgt Rate:6000(kbps)
[*02/04/2025 19:58:24.8731] wlan: [8372:I:dfs] vdev[2]: Mgt Rate:6000(kbps)
[*02/04/2025 19:58:24.8731] wlan: [8372:I:dfs] vdev[3]: Mgt Rate:6000(kbps)
[*02/04/2025 19:58:24.8731] wlan: [8372:I:dfs] vdev[4]: Mgt Rate:6000(kbps)
[*02/04/2025 19:58:24.8731] wlan: [8372:I:dfs] vdev[5]: Mgt Rate:6000(kbps)
[*02/04/2025 19:58:24.8732] wlan: [8372:I:dfs] vdev[6]: Mgt Rate:6000(kbps)
[*02/04/2025 19:58:24.8732] wlan: [8372:I:dfs] vdev[7]: Mgt Rate:6000(kbps)
[*02/04/2025 19:58:24.8732] wlan: [8372:I:dfs] vdev[8]: Mgt Rate:6000(kbps)
[*02/04/2025 19:58:24.8733] wlan: [8372:I:dfs] vdev[9]: Mgt Rate:6000(kbps)
[*02/04/2025 19:58:24.8733] wlan: [8372:I:dfs] vdev[10]: Mgt Rate:6000(kbps)
[*02/04/2025 19:58:24.8733] wlan: [8372:I:dfs] vdev[11]: Mgt Rate:6000(kbps)
[*02/04/2025 19:58:24.8733] wlan: [8372:I:dfs] vdev[12]: Mgt Rate:6000(kbps)
[*02/04/2025 19:58:24.8734] wlan: [8372:I:dfs] vdev[13]: Mgt Rate:6000(kbps)
[*02/04/2025 19:58:24.8734] wlan: [8372:I:dfs] vdev[14]: Mgt Rate:6000(kbps)
[*02/04/2025 19:58:24.8734] wlan: [8372:I:dfs] vdev[15]: Mgt Rate:6000(kbps)
[*02/04/2025 19:58:24.8857] iwpriv apr2v0 qdf_cv_lvl 2555904
[*02/04/2025 19:58:24.8948] iwpriv apr2v0 qdf_cv_lvl 2555912
[*02/04/2025 19:59:05.3962] chatter: Device wired0 notify down link UP
[*02/04/2025 19:59:05.3966] chatter: Device wired0 notify down link DOWN
[*02/04/2025 19:59:07.4061] chatter: Device wired0 notify up link DOWN
[*02/04/2025 19:59:11.4379] chatter: Device wired0 notify state change link UP
[*02/04/2025 20:00:47.6546] chatter: Device wired0 notify down link UP
[*02/04/2025 20:00:47.6551] chatter: Device wired0 notify down link DOWN
[*02/04/2025 20:00:49.6653] chatter: Device wired0 notify up link DOWN
[*02/04/2025 20:00:53.4479] chatter: Device wired0 notify state change link UP
[*02/04/2025 20:02:29.9148] chatter: Device wired0 notify down link UP
[*02/04/2025 20:02:29.9155] chatter: Device wired0 notify down link DOWN
[*02/04/2025 20:02:31.9250] chatter: Device wired0 notify up link DOWN
[*02/04/2025 20:02:35.4778] chatter: Device wired0 notify state change link UP
[*02/04/2025 20:04:12.1839] chatter: Device wired0 notify down link UP
[*02/04/2025 20:04:12.1846] chatter: Device wired0 notify down link DOWN
[*02/04/2025 20:04:14.1946] chatter: Device wired0 notify up link DOWN
[*02/04/2025 20:04:17.5078] chatter: Device wired0 notify state change link UP
[*02/04/2025 20:05:54.4422] chatter: Device wired0 notify down link UP
[*02/04/2025 20:05:54.4428] chatter: Device wired0 notify down link DOWN
[*02/04/2025 20:05:56.4526] chatter: Device wired0 notify up link DOWN
[*02/04/2025 20:06:00.5379] chatter: Device wired0 notify state change link UP
      - Does it work when provisioning the AP through DHCP , for getting an IP address and controller discovery  ?
       https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/97066-dhcp-option-43-00.html
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
The AP is powered via a stand alone non production switch, it will not save the provisioning syntax, this is not an issue with it communicating with the WLC.
You mean the AP gets PoE power from the switch or the switch is running EWC to provide WLC service?
So how exactly are you doing this "pre stage configuration"?
Meaning on WLC or on AP CLI?
What commands are you using?
Do the APs have tag persistence enabled?
There appears to be 2 differences between the batch that work and the one that doesn't and they are the images 17.12.3 and 17.9.4.27
Just to clarify?
17.12.3 - working
17.9.4.27 - not working
Assuming that is the case then very likely a bug that has since been fixed.  17.9.4 is quite old now - see the TAC recommended releases link below.
ps: for long console output much better to put it in a text file (.txt) and attach here rather than pasting thousands of lines into replies!
 @PeterMcGuire93487 - That way of deploying APs is not common. I would propose a test in a 'free' environment with WLC and DHCP server available. Check if the AP still behaves in a strange fashion or not (just for  testing),
 M.
       Beauty and terror
      Just keep going
       No feeling is final
I think you sort of figured out your answer.  5 years ago, you can go in and set the hostname and other variables, but with the newer ap's, that way of doing things as you already know is not going to work.  The best thing you can do while you are pre-staging, is label the ap, capture the mac address and SN, i'm assuming you have a scanner, and then when you are ready to deploy, you can configure all that information through the CLI.  The 9800 is different and requires tags. You can try what @Mark Elsen mentioned, but you really need to look at a different way with these ap's.
-Scott
Thanks for the input everyone. These are the commands I have been using without any issues, for this project we have used them on over 2000 AP's without any issues but now I'm having problems with a 1000 still to do!
capwap ap hostname xx-xxx-AP006-01
capwap ap primary-base xx-xxx-WLC-CL-1 xx.xx.xx.xxx
capwap ap secondary-base xx-xxx-WLC-CL-1 xx.xx.xx.xxx
ap capwap
Try the command and the error message will appear that the hostname cannot be changed unless the AP has joined the controller.
The controller details will get rejected because the AP has no IP address.
We have done over 2000 so far with no issues hence my request for help.
With what OS, AireOS or IOS-XE?
@Leo Laohoo just tested on 9172 running 17.15.2b without IP:
HOSTNAME#capwap ap hostname NEWHOSTNAME
Please note that if AP is already associated to WLC,
the new hostname will only reflect on WLC after AP
dis-associates and rejoins.
So it does allow the change (on latest code) but warns (not an error) that it will only take effect after re-joining WLC.  The console prompt only changes to the new name after the next attempt at discovery (CAPWAP restart).
Setting the primary/secondary controller doesn't give any error or warning and like the hostname only takes effect on the next CAPWAP restart:
HOSTNAME#capwap ap primary-base WLC 1.2.3.4
HOSTNAME#sh capwap client configuration | inc controller
Primary controller name : OLDWLC
Primary controller IP : 5.6.7.8
Secondary controller name :
Tertiary controller name :
HOSTNAME#
[*02/19/2025 22:08:54.6096] CAPWAP State: Discovery
[*02/19/2025 22:08:54.6106] Not sending discovery request, AP does not have an IP!!
[*02/19/2025 22:09:04.6142] Discovery failed 18 times. Check Release/Renew DHCP. is_ap_in_capwap_mode:[1]dhcp_renew:[0]
[*02/19/2025 22:09:04.6143] Discovery failed. dhcp_renew being set to true
[*02/19/2025 22:09:04.8143] ethernet_port , ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*02/19/2025 22:09:05.9457] ethernet_port wired0, ip 0.0.0.0, netmask 0.0.0.0, gw 0.0.0.0, mtu 0, bcast 0.0.0.0, dns1 0.0.0.0, vid 0, static_ip_failover false, dhcp_vlan_failover false
[*02/19/2025 22:09:05.9929] Check whether client_ip_table entry need to be cleared 1
[*02/19/2025 22:09:14.6165]
[*02/19/2025 22:09:14.6165] CAPWAP State: Discovery
[*02/19/2025 22:09:14.6175] Not sending discovery request, AP does not have an IP!! HOSTNAME#sh capwap client configuration | inc controller
Primary controller name : WLC
Primary controller IP : 1.2.3.4
So (at least on the latest code version) it allows the changes even when the AP has no IP address.
So I revert to my previous reply which is likely that the observed problem was a bug which has been subsequently fixed.  So the answer, as usual, is to update to the latest version of code and check again.  The fact that it apparently works on 17.12.3 suggests that that will solve the problem.  Therefore, logically, the likely solution is update the code version if you want these commands to work!
