9800 17.6.2 WLC, How to increase wifi speed
JWHolm81891
I have an employee WLAN that I used as a template and duplicated the configs (except security) for the public-facing WLANS. Getting a lot of complaints though on the lack of speed on the public-facing ones: D- 80Mbps U- 95Mbps. The employee WLAN speed is: D- 174Mbps U-252Mbps.
I have QoS on both set to Gold. I'm not sure what other settings to share, but like I state, they are the same on both in the WLC GUI. So, I don't understand why I'm not getting the same speeds.
10 Replies 10
Leo Laohoo
What model of AP was used in this test?
What wireless NIC was used in this test?
What radio (2.4 Ghz or 5.0 Ghz) was used in this test?
What Data Rates are enabled?
What model of AP was used in this test? 9115AXI-B
What wireless NIC was used in this test? unsure
What radio (2.4 Ghz or 5.0 Ghz) was used in this test? 5
What Data Rates are enabled? 802.11b/g
This information is useless.
Please provide relevant info.
okay, I guess I don't understand what you're asking then.
robertjulian027
Switch your Wi-Fi frequency band
Modern routers work primarily on two radio frequency bands: 2.4 GHz and 5 GHz. The band you use for your connections can affect your speeds and the quality of your connections at different distances from your router.
Whatever frequency band you’re on may be experiencing some temporary interference, so try switching to the other band. It will show up as a different Wi-Fi network on your device, usually with a label in the network name that identifies the network as either 2.4 Ghz or 5 Ghz.
The 2.4 GHz band is the most commonly accessed Wi-Fi connection. It’s used for many other wireless communications other than Wi-Fi, so the airwaves in this frequency can be a little crowded. This band trades speed for rangemeaning it’s better at passing through walls and other objects—whereas 5 GHz has better speeds but a shorter range.
The two frequency bands often appear as two separate Wi-Fi networks. To reorganize your connections, log off from the incorrect band and connect to the correct one on each device.
Connections best for 5 GHz band:
  • Gaming consoles
  • PCs
  • Smartphones
  • Smart TVs
Connections best for 2.4 GHz band:
  • Smart speakers
  • Smart home devices
  • Security cameras
The above reply is plagiarized from the following site and doesn't really apply to Cisco enterprise WiFi since one SSID can broadcast both frequencies, so there is no choosing which one to connect to.
https://www.highspeedinternet.com/resources/improve-your-wi-fi-speed-in-10-simple-steps
As for the issue at hand, what is the difference in security between the SSIDs? If you're using 802.1x on either, are devices on that SSID being put in a different VLAN than other? This could mean the public-facing SSID has traffic routed differently,potentially going through a firewall, slower set of network hardware, etc. than devices on the employee SSID.
Rich R
Well then the absolute maximum should be 54 Mbps - so I suspect that answer is not correct.
"show wireless client mac-address <MAC> detail" for a start.
Compare that for a client on employee versus public.
Also consider updating to 17.6.4.
Scott Fella
Your question doesn't provide enough information that can help.  Why not post your wlan config so we can see how you have configured that wlan?  Have you done testing, you should and post your finding.  Keep in mind what you also mentioned, everything is the same as another, except for security.  So it can possibly be due to how or what you have set on your security, or maybe your employees are also seeing the same except they are not sharing that.  You are probably placing guest on a different subnet, so that is another thing you need to look at.
  1. Did you test before you deployed?
  2. You should be onsite to ask questions and do further testing
  3. Like what others mentioned, part of troubleshooting is knowing what devices are connecting
  4. Use you own device and test also gathering the netsh report and reviewing that (Windows only) .
When using a Windows machine, use netsh
netsh wlan show wlanreport
Analyze the wireless network report - Microsoft Support
-Scott
Here are the configs for comparison of the slower WLAN vs the faster, (slower being first). I’m not a wireless guy except for configuring and deploying, so this is really going a bit deep for me, but I appreciate your help. I’m not sure what all I need to share to help you determine why I’m not getting the same speeds on both, so your patience with me is appreciated.
WLAN Profile Name     :Personal
Identifier                                     : 2
Description                                    :
Network Name (SSID)                            :Mobile
Status                                         : Enabled
Broadcast SSID                                 : Enabled
Advertise-Apname                               : Disabled
Universal AP Admin                             : Disabled
Max Associated Clients per WLAN                : 0
Max Associated Clients per AP per WLAN         : 0
Max Associated Clients per AP Radio per WLAN   : 200
OKC                                            : Enabled
Number of Active Clients                       : 110
CHD per WLAN                                   : Enabled
WMM                                            : Allowed
WiFi Direct Policy                             : Disabled
Channel Scan Defer Priority:
  Priority (default)                           : 5
  Priority (default)                           : 6
Scan Defer Time (msecs)                        : 100
Media Stream Multicast-direct                  : Disabled
CCX - AironetIe Support                        : Disabled
Peer-to-Peer Blocking Action                   : Disabled
Configured Radio Bands                         : All
Operational State of Radio Bands
    2.4ghz                                     : UP
    5ghz                                       : UP
    6ghz                                       : DOWN (Required config: Disable WPA2 and Enable WPA3 & dot11ax)
DTIM period for 802.11a radio                  :
DTIM period for 802.11b radio                  :
Local EAP Authentication                       : Disabled
Mac Filter Authorization list name             : Disabled
Mac Filter Override Authorization list name    : Disabled
Accounting list name                           :
802.1x authentication list name                : Disabled
802.1x authorization list name                 : Disabled
Security
    802.11 Authentication                      : Open System
    Static WEP Keys                            : Disabled
    Wi-Fi Protected Access (WPA/WPA2/WPA3)     : Enabled
        WPA (SSN IE)                           : Disabled
        WPA2 (RSN IE)                          : Enabled
            MPSK                               : Disabled
            EasyPSK                            : Disabled
            AES Cipher                         : Enabled
            CCMP256 Cipher                     : Disabled
            GCMP128 Cipher                     : Disabled
            GCMP256 Cipher                     : Disabled
            Randomized GTK                     : Disabled
        WPA3 (WPA3 IE)                         : Disabled
        Auth Key Management
            802.1x                             : Disabled
            PSK                                : Enabled
            CCKM                               : Disabled
            FT dot1x                           : Disabled
            FT PSK                             : Disabled
            Dot1x-SHA256                       : Disabled
            PSK-SHA256                         : Disabled
            SAE                                : Disabled
            OWE                                : Disabled
            SUITEB-1X                          : Disabled
            SUITEB192-1X                       : Disabled
    CCKM TSF Tolerance (msecs)                 : 1000
    OWE Transition Mode                        : Disabled
    OSEN                                       : Disabled
    FT Support                                 : Disabled
        FT Reassociation Timeout (secs)        : 20
        FT Over-The-DS mode                    : Disabled
    PMF Support                                : Optional
        PMF Association Comeback Timeout (secs): 1
        PMF SA Query Time (msecs)              : 200
    Web Based Authentication                   : Disabled
    Conditional Web Redirect                   : Disabled
    Splash-Page Web Redirect                   : Disabled
    Webauth On-mac-filter Failure              : Disabled
    Webauth Authentication List Name           : Disabled
    Webauth Authorization List Name            : Disabled
    Webauth Parameter Map                      : Disabled
Band Select                                    : Disabled
Load Balancing                                 : Disabled
Multicast Buffer                               : Disabled
Multicast Buffers (frames)                     : 0
IP Source Guard                                : Disabled
Assisted-Roaming
    Neighbor List                              : Enabled
    Prediction List                            : Disabled
    Dual Band Support                          : Disabled
IEEE 802.11v parameters
    Directed Multicast Service                 : Enabled
    BSS Max Idle                               : Enabled
        Protected Mode                         : Disabled
    Traffic Filtering Service                  : Disabled
    BSS Transition                             : Enabled
        Disassociation Imminent                : Disabled
            Optimised Roaming Timer (TBTTS)    : 40
            Timer (TBTTS)                      : 200
        Dual Neighbor List                     : Disabled
    WNM Sleep Mode                             : Disabled
802.11ac MU-MIMO                               : Enabled
802.11ax parameters
    802.11ax Operation Status                  : Enabled
    OFDMA Downlink                             : Enabled
    OFDMA Uplink                               : Enabled
    MU-MIMO Downlink                           : Enabled
    MU-MIMO Uplink                             : Enabled
    BSS Target Wake Up Time                    : Enabled
    BSS Target Wake Up Time Broadcast Support  : Enabled
802.11 protocols in 2.4ghz band
    Protocol                                   : dot11bg
Advanced Scheduling Requests Handling          : Enabled
mDNS Gateway Status                            : Bridge
WIFI Alliance Agile Multiband                  : Disabled
Device Analytics
    Advertise Support                          : Enabled
    Advertise Support for PC analytics         : Enabled
    Share Data with Client                     : Disabled
Client Scan Report (11k Beacon Radio Measurement)
    Request on Association                     : Disabled
    Request on Roam                            : Disabled
WiFi to Cellular Steering                      : Disabled
Locally Administered Address Configuration
    Deny LAA clients                           : Disabled
wlan Personal / Mobile
 no security ft adaptive
 security wpa psk set-key ascii 0 WLpersonal
 no security wpa akm dot1x
 security wpa akm psk
 security pmf optional
 no shutdown
FASTER VLAN (the one I’m trying to match)
WLAN Profile Name     : NPS-Managed
Identifier                                     : 10
Description                                    :
Network Name (SSID)                            : Managed
Status                                         : Enabled
OKC                                            : Enabled
Number of Active Clients                       : 26
WMM                                            : Allowed
Radio Policy                                   : 802.11a only
802.1x authentication list name                : DOT1X_AUTH_Cityof-MANAGED
Security
        WPA (SSN IE)                           : Enabled
            TKIP Cipher                        : Disabled
            MPSK                               : Disabled
            EasyPSK                            : Disabled
        Auth Key Management
            802.1x                             : Enabled
            PSK                                : Disabled
            CCKM                               : Disabled
            FT dot1x                           : Disabled
            FT PSK                             : Disabled
            SAE                                : Disabled
            OWE                                : Disabled
    OSEN                                       : Disabled
    FT Support                                 : Adaptive
    PMF Support                                : Disabled
Assisted-Roaming
            Timer (TBTTS)                      : 200
802.11ax parameters
    Protocol                                   : dot11bg
Device Analytics
wlan NPS-Managed 10 Managed
 radio dot11a
 security wpa wpa1
 security wpa wpa1 ciphers aes
 security dot1x authentication-list DOT1X_AUTH_MANAGED
 no shutdown
I am looking at doing testing.
Well when I ran a diff to compare, the other thing was that your Mobile SSID has 2.4GHz enabled, while the other SSID has 5GHz only.  Now if a device connects to 2.4GHz and you have only 20Mhz channel width vs 5GHz where depending on your ap model, can go up to 160MHz.  On 2.4GHz, I can see why they have slower speeds compared to devices on the other SSID with 802.11a only enabled.
Check speeds when connected to 5GHz on the Mobile SSID, another good configuration option is make sure you have band select enabled to help clients steer towards the 5GHz band.  Of course you don't need that on your Managed SSID because you are only using 5GHz.  Once you see that speeds are the same no matter what SSID as long as you are connected to 5GHz, make the deccision if you disable 2.4GHz on the Moble SSID or else enable Band Select.  You can also change the band select parameters to be a bit more aggressive to have more device connect to 5GHz vs 2.4GHz, but you need to take a look at the data on 2.4 vs 5 and make that change until you are happy with the outcome.
Configuration > Wireless > Advanced > Band Select | Cycle Count = I have mine set to 10
Keep it at default and slowly increase it, making sure that devices are still connecting.
-Scott
