9800 17.8.1 6GHz DCA other than Best(DBS)
Hi guys! Does any have found how to change channel width for 6GHz to ohter than "Best(DBS)"? 20MHz, 40MHz, 80MHz and 160MHz options are disabled when I created a new 6GHz rf-profile. Only con modify max width in "Configuration > Radio Configurations > RRM > 6GHz > DCA" but I want and rf-profile with fixed channel width.
Regards!
DATHOZ
Edgar, did you find a solution to set the channel width static?
Rasika Nayanajith
If you use RRM It is not allowed to set anything other than "Best" in 6GHz.
Individual AP level you can manually configure it.
Rasika
*** Pls rate all useful responses ***
