9800 admin cli authentication
Wes Schochet
Level 7
Level 7
Hi All-
I am working on my first 9800 implementation and set up a 9800-C in the lab.  I am having issues using radius to log in to the controller.
I can log in via WEB GUI using radius credentials,  I am using ISE as the radius server.  I see good radius transactions and the av-pair (shell:priv-lvl=15) is returned from ISE when I log in via web GUI.
When I try to log in via CLI, no request is sent to the radius server.  aaa / RADIUS debug shows:
AAA/AUTHEN/LOGIN (000044CE): Pick method list ' Permanent Local'
and there is no transaction in the RADIUS log.
Current config is:
c9800-test-1.stp#show run aaa
aaa authentication login authentication_login local group ise_radius_grp
aaa authentication dot1x authentication_dot1x group ise_radius_grp
aaa authorization exec authentication_login local group ise_radius_grp
username admin privilege 15 secret 9 $x$012345abcde#
aaa server radius dynamic-author
client 10.28.16.77 server-key 7 012345abcde
client 10.18.16.77 server-key 7 012345abcde
radius server isepsn1
address ipv4 10.1.2.3 auth-port 1645 acct-port 1646
key 7 012345abcde
radius server isepsn2
address ipv4 10.1.2.4 auth-port 1645 acct-port 1646
key 7 012345abcde
radius-server load-balance method least-outstanding
aaa group server radius ise_radius_grp
server name isepsn1
server name isepsn2
aaa local authentication authentication_login authorization authentication_login
aaa new-model
aaa session-id common
Also, on the console, I am always automatically logged in.
What did I miss?  Thanks in advance.
Wes
Rafael E
what about the VTY lines?
paolo-9800(config)#line vty 0 15
paolo-9800(config-line)#login authentication radAutheMethod
paolo-9800(config-line)#authorization exec radAuthzMethod
You can check this document.
Saludos,
Rafael - TAC
JPavonM
Your aaa methods do not match that defined under vty lines (you are missing deffinition of radAutheMethod/radAuthzMethod:
line vty 0 15
-Jesus
*** Please Rate Helpful Responses ***
