9800 APs, Catalyst Centre Intel Reported Errors - Invalid IE (49)
Aaron Harrison
Since upgrading to 9800 (IOS : 17.12.5) series controllers, my Intel clients of al types, on various types of AP are frequently reporting 'errors' like so :
Frame Type: Beacon
Error: Invalid IE (49)
Has anyone see similar and managed to investigate?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Mark Elsen
   - @Aaron Harrison      To exclude driver issues :  use the latest intel wi-fi driver(s) on a specific device and check if that makes a
        difference
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
jucape2009
Community Member
same behavior, onboarding incomplete and the error is invalid IE (49) but the client is able to authenticate, so not sure if this is a cosmetic issue or real problem
  - @jucape2009          If the client has no further  wireless issues , I would say it's cosmetic
  M.
